Old 04-22-2010, 08:56 AM   #1 (permalink)
Thumbs up Align 700E - Hot off the press...
All,
Here it is. Just started building the 700E Combo.
It's a very easy build, and it goes together without problems. Compared to the 700N this heli can almost be built with one hand tied on the back.
Below are photos of the current status, about 1 hour into the build. I will update more as the build progresses.
Canopy
Motor changed to 510KV
ESC Mount
Cool serial number
ID:	152586   Click image for larger version
ID:	152587   Click image for larger version
ID:	152588   Click image for larger version
ID:	152589   Click image for larger version
Name:	Battery holder.jpg
ID:	152591   Click image for larger version
Name:	Battery slide.jpg
ID:	152592   Click image for larger version
Name:	ESC Mount.jpg
ID:	152593   Click image for larger version
ID:	152594   Click image for larger version
Name:	Main shaft.jpg
ID:	152596   Click image for larger version
Edvard R is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 08:58 AM   #2 (permalink)
Nice, I look forward to your flight reports
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 09:30 AM   #3 (permalink)
Any chance you can scan and post the manual?
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 10:07 AM   #4 (permalink)
The bellcranks have 4 holes instead of 3 it looks like, but can you also tell HOW LONG AND WIDE the battery tray is please thanks, and is it the same shape canopy and the 700N or different.
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 10:17 AM   #5 (permalink)
Hmmmm, I already converted my 700N so I wasn't going to get this, but now I am getting a little courious.
Duke600 is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 10:23 AM   #6 (permalink)
Must... build... heli...
later
Old 04-22-2010, 10:27 AM   #7 (permalink)
Canopy is very different from the N-version. Much slimmer and a bit longer.
The frames are 60 mm apart. Tray is around 74 mm high.
The inner hole is for FBL and the outer is for FB.
Old 04-22-2010, 10:54 AM   #8 (permalink)
The helis are shipping world wide today:
Old 04-22-2010, 10:56 AM   #9 (permalink)
Wouldn't mind if one of those pallets fell off a truck in front of my house.
miamiheli is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 10:56 AM   #10 (permalink)
OMG!! thats a site to see.
Trex 700N, Trex 450PRO
"Why buy one when you can buy two for twice the price"
A.Delaney is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 12:24 PM   #11 (permalink)
100k retail worth of heli's there.
shannimal is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 12:26 PM   #12 (permalink)
spotted mine in there
tomcarpenter is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 12:28 PM   #13 (permalink)
OK - enough for today...
Got the servos in and tail on.
ID:	152613   Click image for larger version
ID:	152614   Click image for larger version
Old 04-22-2010, 12:55 PM   #14 (permalink)
What a beautiful machine, well worth the wait
flyrtm is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 02:12 PM   #15 (permalink)
Edvard, on the previous pictures I notice a screw going into the tail boom block. Did you mod that to secure the boom or is that from the factory. I know that you can mod the booms to "capture" the tail boom so it cant get slung out. I just didn't know if Align is now building the tail boom with a built in option so you don't have to do the mod. Thanks.
Old 04-22-2010, 02:38 PM   #16 (permalink)
Hmmm. I wonder what KDE will come up with?
Battery tray?
Esc Tray?
Bottom plate?
Old 04-22-2010, 02:46 PM   #17 (permalink)
Duke - you are spot on! I am already eager to start the development process, so the manual is a huge help to get started!
The good news is, most of the KDE Direct upgrades from the T700N line fit the new helicopter:
Main Drive Gear, 115T, M1.0: http://www.kdedirect.com/TREX700NMDGM1.html
Performance Tail Upgrade V2: http://www.kdedirect.com/TREX600600N700NPTUV2.html
Vertical Stabilizer Mount: http://www.kdedirect.com/TREX700NVSM.html
KDE Direct 1917H/1Y-N42 S2 Brushless Motor: http://www.kdedirect.com/KDE1917H-N42.html
- as luck would have it, the latest production run of motors utilizes M4 x 30mm spacing, which is perfect for the TREX 700E and the kV is almost identical (520kV versus 510kV for the ALIGN 700M).
RevCo MOD1.0, 6mm Bore Pinion Gear: http://www.kdedirect.com/PartsandAccessories.html
I'm not sure about a Bottom Plate, as the concept ALIGN uses looks in the images to be solid (carbon tray with Aluminum crossbars similar to the ALIGN 450PRO), but there may be an opportunity for something exciting to produce.
Old 04-22-2010, 03:00 PM   #18 (permalink)
Smile
Subscribed....
bloftin is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 03:18 PM   #19 (permalink)
81 ps
T-Rex 700N: JR DS8717HV; Vortex VX1+Outrage BL9188HV; Outrage BL9080HV/Throttle; Gryphon regulator; SG Pro; OS MAX 91HZ-R
T-Rex 700E: JR DS8717HV; Spartan Quark+Outrage BL9188HV; CC ICE HV 160A; RCM-BL750MX (450KV); WR Super BEC
T-Rex 250SE 350Watts
QYT001 is offline        Reply With Quote Quick reply to this message
Old 04-22-2010, 05:45 PM   #20 (permalink)
AJ
Default Re: Align 700E - Hot off the press...
What ESC will you be using?
AJ is offline        Reply With Quote Quick reply to this message
