Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
05-03-2016, 08:45 AM | #1 (permalink) |
Switches setup / preflight check switch SE
I want to add a preflight switch check on switch SE. Strangely enough when I set the preflight position to Top/On, the status is alway marked as fault X. So it's checking the reveresed setting.
It works fine with SH and SA.... Guess I'm overlooking something. |
05-03-2016, 08:59 AM | #2 (permalink) |
Just change the Pre-flight condition to bottom/off.
Helis: Oxy 4 Max (day + night), Gaui X3 380, Oxy2 FE 215, Oxy2 Sport 190 Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2 Sims: RealFlight & AccuRC |
05-03-2016, 09:13 AM | #3 (permalink) |
It's a known issue/bug.
Some switches show as being ON in the UP position, others show as being ON in the DOWN position. There's nothing you can do about it. You need to treat each switch as a separate item... |
05-03-2016, 09:25 AM | #4 (permalink) | |
1. Take off the backplade 2. Unplug the battery (just to be sure not to short something out) 3. Unscrew the collar on the front around the switch 4. Carefully push back on the switch and rotate (no need to get it all the way out, but you might have to unplug the ribbon cable temporally) |
05-03-2016, 09:25 AM | #5 (permalink) |
Tried the other way around, same issue. Also tried reversing the switch (in the software), no change.
Will reverse them later on perhaps. Disabled the check for now. |
05-03-2016, 09:36 AM | #6 (permalink) | |
Have you done this yourself? |
05-03-2016, 09:45 AM | #8 (permalink) |
Yes I have the exact model shown (red thou) and I been modifying it extensively
05-03-2016, 09:50 AM | #9 (permalink) |
Indeed, correct. I was only focussing on the checks/status on the setup screen, in the end, in stead of restarting the TX for the actual check. Did that already more than a dozen times... Clear now. When reversed (bottom/off), the preflight check is performed as expected.
05-03-2016, 10:00 AM | #10 (permalink) | ||
The only reason why I won't just go and try it out again right away, is that I'd have to reprogram each switch's function/s for each model. Sadly I think this boat has sailed for me :-( Quote:
