Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 12-21-2007, 10:07 AM   #1 (permalink)
Default Just got my Hurricane 500
How can I tell how old my kit is? I bought it new in the box, but second hand from a guy who won it at a raffle his RC club put on.
Also what is the deal with the ESC and BEC? How should I wire this stuff, I have the 2 3 cell 2200 packs, but what do I wire the BEC to? The kit only came with a motor and a ESC that seems to have a external BEC attached to it under shrink wrap....
GyroRon is offline        Reply With Quote Quick reply to this message
Old 12-21-2007, 11:53 AM   #2 (permalink)
Your kit is a bit older if it has the separate BEC. If you will want to use that BEC, you will need a separate 2S pack to run it.
Or you can pick up a Dimension Engineering SportBEC or Castle Creations CC-BEC and run it off the main pack.
Watch the Finless videos, there are some issues with the links and screws that you will want to deal with.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 12-21-2007, 12:14 PM   #3 (permalink)
I just looked at the ESC again and and kit contents and there is no separate BEC, only a ESC with a lead out of it for the reciever, a pair of leads to the battery and a trio of leads to the motor.
I assume you just solder onto the battery harness I need to make to have 2 three cell batterys supply the 6 cell voltage into the ESC and that is it?????????
What else do I need to confirm before putting this together and flying it? I am not into hard 3d.... just a loop or roll and normal mode flying.
I have the servos that came with a Spektrum DX-7 radio with the factory servo arms, will this be okay or do I need different arms or anything?
Thanks Ron
Old 12-21-2007, 02:33 PM   #4 (permalink)
If all you have is an EC you will have to make the decision to get a BEC that will plug directly into the battery or a regulator that will use a separate reciver battery to power the rcvr and servos.
There are benifits to both...BEC no separate battery, just play and play (fly) no extra weight.
Reg & battery...little extra weight but steady power to rcvr, bec has to be able to handle the 22v and reduce to rcvr volatage... I like the separate battery becuse I can power the servos and make adjustments without powering up the motor.
But you do add another possible failure point.
I run BEC's on all my planks, and on an ECO8 but my Hurri came with the regulator and power lights, so far I have no complaints with it.
You also have to make a "series" harness for the main batteries.....using 3 deans conn....two male and 1 female.. wired + batt - to + batt - to + batt - There is a thread or picture somewhere in the forum.
mjdee14 is offline        Reply With Quote Quick reply to this message
Old 12-21-2007, 03:03 PM   #5 (permalink)
here is a pick of a series connector. or is this one paralell? i can't remember and am an electrical idiot.
AMA# 906249
i'm now down to one heli (align sev2) but have an arsenal of 120+ mph jets. hmm...i think i see a pattern here lol.
istandalone is offline        Reply With Quote Quick reply to this message
Old 12-21-2007, 03:04 PM   #6 (permalink)
So then this esc does not have a built in bec that will handle the 6 cell incoming voltage?
Old 12-21-2007, 04:18 PM   #7 (permalink)
Correct...it does not have a BEC
Old 12-21-2007, 04:32 PM   #8 (permalink)
That is a series connector.
Terry
Old 12-21-2007, 06:21 PM   #9 (permalink)
Well I feel ripped.... I thought this kit came with a BEC and even a special battery for running it. I have a BEC from Lightflightrc.com I wonder if it would work and if so, what is the best way to wire it in?
Old 12-21-2007, 06:22 PM   #10 (permalink)
I asked Dave at Lightflight about using this BEC with 6 cells and he said it SHOULD work.... But was designed for up to 5 cells.
Old 12-21-2007, 06:26 PM   #11 (permalink)
Arrrr..... I just dug into the manual for this thing and guess what.... none of it is in english.
Old 12-22-2007, 01:25 AM   #12 (permalink)
Do you mean the 550 or the BEC - 550 manual here - http://www.gaui.com.tw/en/H550_Instruction_Manual.pdf you can get a BEC that will take up to 8S from Dimension for about $30
