Old 04-03-2012, 10:55 PM   #61 (permalink)
shorten the links more, they cam wind in further than you think
Also do you have the balls and link rods on the grips as short as they can go?
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 04-03-2012, 10:58 PM   #62 (permalink)
Originally Posted by Mike2112 View Post
Deet, do you know if the new head is lighter, or heavier than the original Align FBL head that comes in the 3G kit?
I didn't measure it, but it must be
The shaft is shorter, there is no swash lock.
The grips and arms would probably be about the same weight
the block looks shorter so probably lighter too
Only thing that might add weight would be the links
My current RTF weigh is 1.9 kgs exactly, I did post a RTF weight recently on another thread, that may give you an idea
Dave
Old 04-05-2012, 08:48 PM   #63 (permalink)
Just installed the new thrust bearings...still not smooth???? I guess the next step is checking the bearings in the grips. They were new grips, bearings should be good? This is turning into a project!
pmikeyg is offline        Reply With Quote Quick reply to this message
Old 04-06-2012, 06:33 PM   #64 (permalink)
your doing something wrong
I've lost count of the number of Align heads I've built and never had any notchyness
Other brands of head yes...
I have fixed notchy heads, usually its the order the bits were fitted, or loctite getting into bearings
Dave
Old 04-06-2012, 08:22 PM   #65 (permalink)
Again Deet, you were right on the money. I thought they were all the way in, but alas I was wrong.
Thanks again!
Doug
The opinions expressed here are merely that, opinions, so keep your feathers down.
2Drum is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 06:49 AM   #66 (permalink)
Subscribed, thanks for putting this list together. I just wish I had read your thread before.
Thanks Deet
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450
iKon, because I am connected to my heli. Are you connected to yours?
RCHN #15
PauloG is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 09:01 AM   #67 (permalink)
Does anyone know where I can get the shorter jesus bolt and screw for the head?
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 09:05 AM   #68 (permalink)
+1 I'd like to know too...
snjbird is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 09:35 AM   #69 (permalink)
Let me get this straight also. If you already have a head from an esp, all you need are the DFC kit, jesus bolt for the head and the main shaft spacer??
MSH, Cyclone
Old 04-07-2012, 09:52 AM   #70 (permalink)
So I did some measuring. The jesus bolt for the main shaft is a Socket screw M2.5X19mm. I put that throught the dfc head and it looks like a M2.5X14m would get the job done. Can anyone measure their screw to confirm this? If this is correct, A Main Hobbies has it, but I'm sure you could get it anywhere. Here is a link.
http://www.amainhobbies.com/product_...-Cap-Screws-10
MSH, Cyclone
Old 04-07-2012, 11:56 AM   #71 (permalink)
forced auto today second time this has happend.having troulbe getting the ball links in uk so we found its the same from 600 elevator link,but you only get one in a packet so you have to buy two packs.i no thier has to be a week link somewhere i think the threaded bar could do with being a bit longer.
500espbx 550ebx 600lenbx logo 400se v/b 7c futaba
hooverit is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 05:18 PM   #72 (permalink)
the jesus bolt comes with the kit
yes you need the spacers
you will also need the Pro grips if you have the ESP head
all you use from the ESP head is the feathering shaft, brass spacers, and thrust bearings
Dave
Old 04-07-2012, 09:55 PM   #73 (permalink)
are you saying that the ball links are coming loose from the link rod? or is that because of a crash or another problem?
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/AR7210bx Oxy 2 FE micro Ikon2 Talon 25 BA 8-1 servos
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 gen2
krauley is offline        Reply With Quote Quick reply to this message
Old 04-08-2012, 04:42 AM   #74 (permalink)
I found a bad outter bearing on one of the blade holders. I contacted the shop I bought them from and they are sending me a new set. The inner race of the bearing was dented/dimpled.
Old 04-09-2012, 05:01 AM   #75 (permalink)
I've crashed several times with my compass head and mostly inverted but never had a bendt link / Delrin links
that didn't look good hooverit
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 01:43 PM   #76 (permalink)
ITS HERE!!!!
now just waiting on my sk-720
rdarby777 is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 03:06 PM   #77 (permalink)
Originally Posted by rdarby777 View Post
ITS HERE!!!!
Hmmmm, lucky guy! Just report how well both sistems match!
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 06:20 PM   #78 (permalink)
ITS HERE!!!!
Heh first thing i thought when i saw the parts and the local was son of a gun best not be messing with my mailbox
Name:	DFC500 parts.jpg
now just waiting on ar7200bx
Old 04-09-2012, 06:34 PM   #79 (permalink)
So I'm taking a counter IED course this week and today during our practical application they asked us what a DFC was, I had to hold my breath ( by the way, DFC stands for directional fragmentation charge )
USMC - EXPEDITIONARY AIRFIELDS - MCAS MIRAMAR
Align Trex 500 Scorpion 3226-1400 powered missile
Wildcards is offline        Reply With Quote Quick reply to this message
Old 04-09-2012, 06:49 PM   #80 (permalink)
That doesn't sound so fun when using it as a helicopter related term
