Old 04-25-2013, 10:01 AM   #21 (permalink)
BUMP... Can the editing be released?
This really should be a sticky anyway
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote Quick reply to this message
Old 04-25-2013, 01:17 PM   #22 (permalink)
Great work! Yeah, unfortunately editing of a post is limited to the 1st 30 days or so.
Perhaps consider using the per-user based blog feature. Obviously you can update your blog any time you like. Perhaps ask admin to edit 1st post so you can add text to advise others to visit your blog. Just a suggestion.
Old 04-25-2013, 06:03 PM   #23 (permalink)
Some Solar DS654 feedback from me...
I've had bad luck with them, even after doing the "foam" mod to keep the servo motor from backing out.
The airframe I got was used so I do not know how many flights were on it. First crash, one of the servos stopped working completely, no buzz, nothing. The heli main shaft broke so this servo issue resulted from the subsequent crash. I took the servo apart and I did not notice anything obvious. I.e. all of the power wires were still soldered on.
Replaced that servo and today this same airframe went in. This time I think the crash was caused by the servo (this was not the new replacement). Elevator servo was completely locked up and I could not physically move the servo arm. Took it apart and turns out the servo motor itself is completely seized. The servo motor pinion/shaft will not move at all.
Pete
lovespicyfood is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 07:16 AM   #24 (permalink)
Default Installing MKS DS470 cyclics and DS480 tail servo
We need to remove material from the frame, marked with red, in order to mount the elevator servo.
Tools needed for this
Done. This is not for the faint of heart or those who have never seen a Dremel before
We also need to cut away a little where the servo horn moves upward.
ID:	431559   Click image for larger version
ID:	431560   Click image for larger version
ID:	431561   Click image for larger version
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 06-28-2013, 07:21 AM   #25 (permalink)
Default Part II
Cut away some from the corner as marked for the front elevator servo
Add shim between the servo and frame (blue in the pic) in order to have the link running straight
Modifying the servo horns is some work. The holes don't match up perfectly with the stockers. Tried first with the 2nd inner hole, but it does then not clear. So we have to user the inner one. Cut off the excess, and you must also dremel down the "raised part" in order for the ball link to sit properly and moove freely. For the tail I used the 2nd hole if I remember correctly. Make that one at least as far out as stock in order to have enough movement.
The treads of the balls are 1.9mm so I drilled the holes in the horns up to 1.6mm. Apply some Loctite and mount the balls.
ID:	431563   Click image for larger version
ID:	431564   Click image for larger version
ID:	431565   Click image for larger version
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 07:30 AM   #26 (permalink)
Default Part III
Mounted!
I use these servos in my 450X too, and they seem both good and crash resistant.
The only thing I'm not 100% satisfied with is the tail performance. It seems to me that cyclic servos are not at all that critical. But it for sure is for the tail servo. My conclusion is that it may be worth getting a very good spec 20 gram servo (these are 10g) for the tail, for instance the MKS DS95i.
Notice how I also flipped the tail servo and reversed it (horn rearwards), in order to get better right/left weight balance. And more forward COG (this heli is a bit tail heavy).
Thx for looking!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 09:48 AM   #27 (permalink)
Great info here. A little heads up Shyguy, using loctite on plastic is a no no. Use super glue as your "plastic loctite."
HeliHoverAP is offline        Reply With Quote Quick reply to this message
Old 06-28-2013, 10:23 AM   #28 (permalink)
Good tip, thx!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 12:32 PM   #29 (permalink)
Originally Posted by SHYguy View Post
[IMG]
Mounted!
I had to do similar but a bit less cutting to my frame to install the Turnigy S306G servos.
For good 20g tail servo, try the Turnigy S306G. Very good deadband performance and good speed (although spec doesn't suggests so), speedy and torquey. Coreless motor (i.e. very responsive). And very cheap to boot.
Old 06-28-2013, 12:39 PM   #30 (permalink)
Am looking at it but I have already a 95i, I would think that is THE micro servo to beat?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 12:49 PM   #31 (permalink)
I'm sure the 95i must be good. The Turnigy S306G and KST 115/215 clone the MKS and also uses coreless motor (which is a must for tail performance, except of course brushless is even better). I have no complain with TGY/KST as tail servo.
EDIT: correction. It's 115 not 125.
Old 06-28-2013, 12:59 PM   #32 (permalink)
I'm working on a list of sticky candidates, will request an admin. Got any suggestions shoot me a PM!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 01:02 PM   #33 (permalink)
I'm sure the 95i must be good. The Turnigy S306G and KST 125/215 clone the MKS and also uses coreless motor (which is a must for tail performance, except of course brushless is even better). I have no complain with TGY/KST as tail servo.
Are there any with BL motor this small?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 06-28-2013, 02:30 PM   #34 (permalink)
I don't think so. I think heli this size even a good coreless double-bearing servo is good enough.
Old 06-29-2013, 05:49 PM   #35 (permalink)
Ordered 5 of these to try:
http://www.hobbyking.com/hobbyking/s...dProduct=29043
Each servo costs the same as the DS76 gear set!! and they get great reviews.
If I break one I'll just swap the servo out. The HXT900 gear set may also fit and they are really cheap.
Lets just hope they fit and do the job. My stock cyclics have had it - one burned out and one has developed slop.
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 07-01-2013, 03:57 AM   #36 (permalink)
Thumbs up And boom!!!
That was it for me! The MKS DS95i tail servo turned this heli into a heli that I'm satisfied with! Tail holds ROCK SOLID now! Not wag, shakes - nothing!
So for me the conclusion is that for a perfect tail you need a good 20g servo. These are known to be good:
  • MKS DS95i
  • Turnigy S306G
  • KST 125/215
(the Turnigy and KSTs are clones of the MKS servo, I cannot personally confirm those but others like dCH can)
http://www.mks-servo.com.tw/goods.php?goods_id=ds95i
Turnigy TGY-306G:
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
KST 215:
http://www.kstsz.com/threestyle/ksts.../13531946.html
But the KST 125 (at least the one available now) seems to be a wing servo:
http://www.kstsz.com/threestyle/ksts.../11159673.html
-so I don't think this is an option. Do you guys mean this, the 115?
http://www.kstsz.com/threestyle/ksts.../11159685.html
At the same time I will then myself advise against these as tail servo optons:
  • MKS DS480
  • stock tail servo
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 07-02-2013, 12:23 PM   #37 (permalink)
  • MKS DS480
  • stock tail servo
Oops sorry. I meant KST 115 (non HV version of 215).
Old 07-03-2013, 01:23 PM   #38 (permalink)
And my new servos turned up
Only reason I decided to change was because one of my stock servos burnt out and I didn't want to pay the sort of money they want for a replacement. Instead I have opted for these HKSCM9-6 from Hobby King:
Almost a straight swap for the stock servos. Very little to do. Positioned the ball at same distance as stock arm and got the blue light at 6 degrees.
Took them for two flights and they fly just like stock servos.
Only weigh 10g and best part is they only cost $3!!!! same price as a stock servo gear set! Oh and they can run at 6V.
Next job for me; fit the zyx-s as the BX is about to be moved into my new Mini-Protos
Blade 180CFX | 300X
Old 07-03-2013, 02:08 PM   #39 (permalink)
Great! The White Knight from the UK!
Now go crash so we can see how they hold up!
What's that "blue light" you're talking about?... Wait, just checked the manual: Step L!
I've always skipped that one, I must start doing that I understand now
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 07-03-2013, 03:03 PM   #40 (permalink)
Yep, step J in fact. I don't really care how they crash at $3 each
I don't normally crash anyway unless a servo burns out on me
Blade 180CFX | 300X
