300X Blade 300X Helicopters Information and Help |
02-20-2015, 12:21 PM | #21 (permalink) |
60 hz vs 200hz & 270 hz on sh-0257mg?
you said the 0257's were recommended to be run at 60hz but your attachment of picture showed the chart of sh-0257mg is blue 200 hz for swash plate frequency and is red 270 hz for rudder (tail) frequency. i am confused. or i may have misunderstood you on something else due to my weak english?
02-20-2015, 12:35 PM | #22 (permalink) | |
off the point for my curious, will these savox 63's and 64 work well with oxy 3 helicopter kit between same size of 250 class? i notice many oxy 3 pilots use the kst ds215mg servos. my another question, which savox servos model that are matched to same size and capacity of kst ds215's servos? |
02-20-2015, 05:04 PM | #23 (permalink) | |
So I am saying that there is some confusion from Beastx as they are saying that the same servo has 2 different settings |
02-25-2015, 03:12 PM | #24 (permalink) |
agreed conflicting info.... have Savox 257 on cyclics (300/450x @1520 - 200hz) run a 262 on the 300 at 1520 - 200hz and a 264 on 450 1520 - but brought the Hz down to 165 hz as it was getting warm while setting up when set to 200hz.
email I received from Savox USA From: Joel Eaton [mailto:joel@hrpdist.com] Sent: 25 March 2013 13:32 To: Subject: RE: Attn: Tech Department 250 to 300 is the settings used most commonly Thanks, Joel | Customer Service | Technical Service | Warranty Service Racers Edge | Savöx USA if you fit them, set the BX up without connecting first so you don't fry them, start low and increase 1 step at a time, if they start getting warm/hot to touch back off. There has been posts from people who have been unlucky and have this happen to them
sc00bied00 DX8i | Phoenix Sim | Nano CPX | 300X | 450X | Goblin 380 | Soko Heli Tool |
02-27-2015, 02:36 PM | #25 (permalink) |
hello savox users
Hi, does the SH-0257mg servo case need any alteration to fit in the elevator position?.....or does it drop right in? How about for the ailerons? tia
03-03-2015, 04:28 PM | #26 (permalink) |
I found that they fitted ok, may need a little file on the servo's to fit frame or frame filed but not much mod needed, almost straight swap.
