Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > mQX
mQX Blade mQX Quad Helicopters Information and Help
Old 12-15-2012, 10:20 AM   #21 (permalink)
Originally Posted by setishock View Post
Just a suggestion flyin mike. Roll up some thin double sticky carpet tape and put it under the bottom of the cam in the back. Replace the cable strap. It's not going to take much to make a wedge.
That's a good idea, thanks!
flyin~mike is offline        Reply With Quote Quick reply to this message
Old 12-19-2012, 09:30 AM   #22 (permalink)
I'm hoping to get a 808 #16 for Christmas This is exactly the info I needed for camera mounting. Thanks!
maoromir is offline        Reply With Quote Quick reply to this message
Old 12-22-2012, 09:03 PM   #23 (permalink)
Just got my mQX yesterday. In the past, I've always used velcro to mount keychain cameras. So I did the same with the mQX.
The camera is an 808 #11 Key Ring Spy Camera 720p HD (http://www.chucklohr.com/808/C11/).
The camera plus the velcro weighs 17.3g (0.61oz). The mQX has no problem lifting and maneuvering with it.
No part of the heli shows in the videos I've taken with this mount. It also seems to be relatively vibration free.
Here are some pics of the setup followed by a 10 second video clip.
To see my mQX with camera, landed on water: https://ibm.biz/BdxyVJ
Blade 450X, Witespy Quad, Gaui X3, Gaui X5, Goblin 570, Goblin Black Thunder
lmcwilli is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 04:25 PM   #24 (permalink)
Wouldn't taking the camera out of the shell and perm mounting it under remove a lot of the extra weight the camera case comes with?
I have mine on order and that's my plan.
ScreamingSkulls is offline        Reply With Quote Quick reply to this message
Old 01-09-2013, 09:24 AM   #25 (permalink)
I'm a little late to the party - I just got my mQX a few days ago. I also purchased an 808 #16 a couple of weeks ago. Yesterday, I ordered the MIA TUFF LG Camera Mount Kit. I watched several MIA videos on YouTube and it looks like a good solution versus me trying to design something from scratch. l'll definitely report back once I receive it and get it mounted and working.
DX6i ♦ Blade CX2 ♦ Blade CX3 MD 520N (x2) ♦ Blade mCX2 (x2) ♦Blade Tandem Rescue ♦ Blade mQX
SJMarty is offline        Reply With Quote Quick reply to this message
Old 01-10-2013, 06:41 AM   #26 (permalink)
Though the mQX can easily lift my keychain cam in its case---since I use a lightweight mounting method, it's true that removing the case would eliminate a significant amount of additional weight.
Leaving the case on works for me because I only occasionally use the mQX with a cam attached (and want to be able to use the cam intact elsewhere). The rest of the time, I don't want the mQX burdened---by either cam or mount---when I'm just flyin' to be flyin'
Though I'm really into keeping the weight down when adding mQX attachments (see pontoons https://www.helifreak.com/showpost.p...&postcount=250), perhaps the additional mass of the case adds stability to the mQX (just a random thought).
Old 02-10-2013, 09:26 PM   #27 (permalink)
Originally Posted by lmcwilli View Post
... velcro to mount keychain cameras
Here are couple of additional photos.
Old 02-11-2013, 07:23 AM   #28 (permalink)
I wanted to add my comments to this thread since I've also purchased the 808 keychain camera.
I mounted mine on top of the stock canopy. I used the doublesided velcro that ships with the E-Flite batteries. I also put a rubber band around the whole canopy/camera combination so it wouldn't shake.
The biggest problem I've had is with the camera. Obviously, for $6.50 shipped one has to temper your expectations. You get what you pay for. The problem I've had is that sometimes shuts itself off while recording.
But my mQX has had NO problem lifting the camera and I have had no stability problems at all. I'm using the standard radio with the tame settings. It's been breezy at my house since the camera showed up but I've managed to get video a few hundred feet up in the air that gives me a nice bird's eye view.
PSU1995 is offline        Reply With Quote Quick reply to this message
Old 02-22-2013, 08:36 PM   #29 (permalink)
I have found that a camera on the bottom make the mQX really unstable. But on top you see the propellers, especially with the wide angle lens. I really want a bottom mounted camera, angled down at the ground. My latest effort involves new canopies made by heat forming plastic rectangles for the top and bottom. The battery is moved to the top to raise the center of gravity. The camera is mounted to the bottom on a balsa wedge.
bdmsb is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 12:52 AM   #30 (permalink)
Good idea, relocating the battery on top.
Do you fly with black props on the front?
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 02-23-2013, 10:13 AM   #31 (permalink)
No, the black props are on the back.
Old 02-23-2013, 01:05 PM   #32 (permalink)
Ah! So the camera points to the back?
Old 02-23-2013, 02:59 PM   #33 (permalink)
Yeah, I don't care where I'm going, I like to see me behind the copter looking up at it. Maybe I'm vain. But it shows the scale of altitude well.
Old 02-25-2013, 11:10 AM   #34 (permalink)
Default How do you mount you 808 keyfob cam ?
I had the MIA camera flight kit and the pieces to attach to frame were very fragile. It lasted a good week then a crash sent it flying off...it didn't help with the jello in the camera either so I dumped it. Too much added weight. Can't do loops or rolls either...unless you like Mother Earth that much.
Quadman X is offline        Reply With Quote Quick reply to this message
Old 02-25-2013, 11:14 AM   #35 (permalink)
This is what I use today...
Went caseless and put a bit of Velcro behind the camera to get a good angle and remove a lil jello
Old 02-25-2013, 11:24 AM   #36 (permalink)
Why did you re-route the motor wires outside the booms?
Old 03-05-2013, 07:54 PM   #37 (permalink)
This is my set up.
Align PU Gel under the camera to eliminate Jello.
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 08:11 PM   #38 (permalink)
I guess you mean polyurethane? I bought some sorbothane for that purpose, but the stuff is so dense and heavy I decided not to use it. Is that what you're using?
Old 03-05-2013, 08:16 PM   #39 (permalink)
K10457A Align PU Adhesive GelI. It is some strange stuff, but it sure eats up vibrations.
Old 03-05-2013, 08:39 PM   #40 (permalink)
Okay, thanks. I just ordered some.
