Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 10-14-2010, 12:46 AM   #1 (permalink)
Default Tight tail gear
Outrage has announced 90N in China on Sept., we are all welcome this new designed heli. However, it does make us disappointed due to tight tail gear, seem it is due to the tolarence of plastic gear. Let find the attached video. The tail is so tight that we are afraid problem would be happened during in air
Last edited by DominicD; 10-14-2010 at 07:32 AM.. Reason: Please do not link zip files.
rscrc is offline        Reply With Quote Quick reply to this message
Old 10-14-2010, 07:33 AM   #2 (permalink)
The Capi
If you could please just youtube the vid it would make it safer for us to watch.
Old 10-14-2010, 01:54 PM   #3 (permalink)
Just remove the shim from tail shaft. It is on the flat side of the bevel gear "B"
I've made the same mistake...
T-Rex700N, Vibe 90SG, Velocity90 FBL, Avant Aurora, Srimok90, T-Rex600ESP, T-Rex450SE V2
randyandy is offline        Reply With Quote Quick reply to this message
Old 10-15-2010, 03:20 AM   #4 (permalink)
I removed the shim in mine, but then had a bit of play on the tail shaft. Can someone confirm whether this shim must be used or not?
knysna4 is offline        Reply With Quote Quick reply to this message
Old 10-15-2010, 07:23 AM   #5 (permalink)
YES, the shim should be used, if not the tail output shaft will allow the gear to pull away from the drive gear and you could get a slight pulsing from the mesh moving in and out. Our gears were a bit chunky and noisy and after a couple of flights they bed in nice and have been fine.
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote Quick reply to this message
Old 10-15-2010, 08:05 AM   #6 (permalink)
Hm, looks like that there are many tolerances on that bevel gears...
I have to use a lot of force to turn the bevel gear if i put the shim in.
Old 10-15-2010, 12:47 PM   #7 (permalink)
Okay, correct me if I am wrong, but i just built two 90's and there were no shim on the tail shaft. i also jsut checked the manual and there were no shims. Am I missing something here?
Tone
Team Outrage
YS Engines
Team Switchglo
Team Lynx
tS8103 is offline        Reply With Quote Quick reply to this message
Old 10-15-2010, 03:23 PM   #8 (permalink)
Tone,
Both of Steven's prototype machines had the shim, also the complete output shaft spare with the bevel gear installed had the shims, basically just get the tolerance so there in no play between the gears if it is too tight remove the shim, if the shim is removed you need to verify it doesn't introduce excessive amounts of play, I have a bunch of various size shims I've acquired over the years for different applications mostly for 3mm shafts but same principal, simply add or remove until you get the desired tolerance, on my 2 Vel 90's they were spot on with the shim installed, the gears were a bit snug and Steven had them bed in after one hard 3D flight
Clyde Fox
Port Charlotte, FL.
Old 10-15-2010, 03:52 PM   #9 (permalink)
There is no shim in the tailcase, mine was really tight had to mess about a bit with it, but after first flight feels fine willl keep an eye on it for a few flights,
Del
Beam e4
Outrage Velocity MAGIC
Outrage 90 beast x
deldeb is offline        Reply With Quote Quick reply to this message
