Gryphon Electronics Gryphon Electronics Factory Support Forum |
04-01-2014, 07:34 PM | #1 (permalink) |
right or wrong way the wire 7075 bec?
i posted this pic of my esc placement and wiring. i was told that i have my bec wired on the wrong side of the esc. please see pic.
thanks for looking |
04-01-2014, 11:03 PM | #2 (permalink) |
Hi.
I also use my gryphon' soldered direct into plugs on esc. |
04-03-2014, 07:17 PM | #3 (permalink) | |
You always wire low negative which means the negative wire from the BEC connects to the negative wire of the ESC, and the positive BEC lead connects to the positive jumper lead on that same battery plug. You can have serious issues wired high negative as you have in your photo, and its possible to melt things down. This is a Castle ESC diagram, but it shows exactly how it should be wired for 6 cells only
Tony Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do |
