Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 03-05-2013, 08:59 AM   #21 (permalink)
Another thing I've found online but not sure of the accuracy of the method !
[ame]http://www.youtube.com/watch?v=7xae7ggtH0M[/ame]
Flydynamics is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 04:12 PM   #22 (permalink)
This shims look good:
XRAY Washer 7x10x0.5mm (10)
http://www.amainhobbies.com/product_...r-7x10x05mm-10
you can do fine adjustments.
stiganas is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 06:00 PM   #23 (permalink)
The heli is pretty dialed in now. Very happy with the performance so far. It has a very positive feel and responds well to the fast cyclic rates I like. The main reason I was interested in the model was the saddle pack arrangement, and I 'm happy to report elevator performance is top notch as a result (saddle pack has less pendulum effect). It has a very good piro steering feel, and is happy with a very aggressive setup.
The low disk loading is awesome. My flight times seem a bit better than my other 600 class models and the machine moves around quite easily. I really noticed the light loading in maneuvers like piro tic tocs where they are very effortless with this machine.
It's a keeper.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 06:02 PM   #24 (permalink)
What ball spacing did you user on your servo horns? Do you remember your cyclic % number on the servo trim screen? Just wondering.
WessCo is offline        Reply With Quote Quick reply to this message
Old 03-05-2013, 07:14 PM   #25 (permalink)
I'm using the Align plastic servo wheels. Good for reducing damage in crashes. Using the inner hole on these. I think my cyclic was around 28% for 10.5 degrees.
Old 03-05-2013, 07:18 PM   #26 (permalink)
Meant collective, but I can see it'll probably be low. I'm using about 9mm ball spacing.
Old 03-05-2013, 09:40 PM   #27 (permalink)
OntheSnap thx for your background, will you have, by any chance, something to weight your machine ?
I'm interested in this machine for the lay-out of the battery and the intelligent idea to have the ESC ventilated by the relative wind ..... and not hiden under the canopy without any air entry !...
Thx again Snap, difficult to find accurate feedbacks on this model.
Old 03-05-2013, 10:09 PM   #28 (permalink)
I have a really crappy scale that I only use for relative comparison.
Old 03-05-2013, 10:15 PM   #29 (permalink)
OK well ... I'm not looking for any super precise weight to the gram but just a relative idea of the weight, I'm not a fan of the heavy 600 like we can now see at almost the weight of a 700 !
I think a light set up with battery should be around 4000g (8.82Lbs).
Again ... Thanks for reporting your flight impressions ... really helpful ...
Looking for a machine reliable, well thought, light ... obviously the X50E is spot on ?!...
Old 03-06-2013, 05:30 AM   #30 (permalink)
I measured 8 lbs. 8 oz. I have a 3s 2200mah lipo running the Castle Pro BEC, so there could be a little weight lost there.
My setup is:
MSH Brain
Quantam 4125-560
Castle Creations Ice2 80HV
Align DS610's on cyclic
Savox 1290mg for tail
6s 3000mah 40C Sky Lipo x 2
Castle Creations Pro BEC
3s 220mah 40C Sky Lipo
Stock main blades and tail blades
Old 03-06-2013, 07:38 AM   #31 (permalink)
Default Good News
It's a keeper.
Happy that you seem to like it.
Drummer
aerosmith is offline        Reply With Quote Quick reply to this message
Old 03-06-2013, 08:01 AM   #32 (permalink)
It's a good half pound lighter than my Fusion50. 3/4 lb lighter than my E5 stretch. 1.5lb lighter than my old Goblin 630. About 1/4 lb lighter than my old logo 600.
Packs are easy to swap out. Best in class.
On the con side - lets face it, it's pretty damn ugly, parts seem only available at Tower Hobbies in the US, no break away tabs for the canopy, mod .8 main gear with no slant option. I have not heard of any stripping issues though so it's probably a stout gear. Very high profile rotor head, which looks a bit retro.
But overall it seems like the perfect practice platform, like the Fusion50 was, but without the stripping issues and a bit less weight. In my mind it seems like a sleeper hit. The retro design is probably killing its popularity. But probably a revamped canopy design would do wonders for it.
Old 03-06-2013, 09:03 AM   #33 (permalink)
Wessco, Snap,
Thanks for the weights ... I initially was extremely disapointed by the modulus choice but it seems to be very happy with even insane power setting.
1/2 Lbs lighter than a logo wow .. very interesting ... might try the X50E with 14S A123 pack ;-) to get rid of expensive LiPos, spend the money on A123 once then you can fly hundred times with no worry of discharge level ! + A123 don't burn easily !...
Snap I agree with you for the parts availability, Amainhobbies and Towerhobbies got them, infinity hobby has also parts.
For the design I kinda like it, the head being a bit high gives, like you said, a retro style I like, I love the fact that the boom is parallel to the disk not like Logo or other machines having kind of a weird look in the air (my 2 cents) ....
Well guys thax again, you helped me making a decision on this one.
Old 03-06-2013, 09:56 AM   #34 (permalink)
Wessco, Snap,
Amain and Infinity only carry the nitrox50 parts. Lots are probably common but many are not.
One more pro - Saddle packs produce the best piro steering feel and minimum pendulum effect IMO. Helis already have the problem of way more mass on the elevator vs aileron. Making aileron faster than elevator in stopping/starting performance. Saddle packs move more mass to the aileron and minimize length wise mass. This gives it a more symmetric feel and produces a very positive piro steering feel. This is what I loved about the Fusion. Since support for that model seems to be wilting, this is my replacement.
Some of the newer 700's use the same principle. Logo 700, x7, rush 750. The trade off is some added width, but designers using this approach usually like narrow stiff frames, and a narrow canopy cut above the packs. Seems like the best design approach to me.
Old 03-06-2013, 10:18 AM   #35 (permalink)
You're right about Infinity and Amain ..... Heliproz has some parts for the X50E.
I agree with the pendulum effect, if you can center ALL the masses close to the rotor shaft and very close to the disk you'll have a more symetrical feeling ... some different manufacturers tried to achieve this with some or no success ....
I think Thunder Tiger did his homework on the electric side with the ESC located in the relative wind, light but robust machine, no major issue, cool design (I think) ....
Will order mine ;-)
Old 03-07-2013, 02:16 PM   #36 (permalink)
I put the extra shim in mine, but it made everything to tight. Took them out.
Where exactly did you put the shim?
helicopter1 is offline        Reply With Quote Quick reply to this message
Old 03-07-2013, 02:17 PM   #37 (permalink)
Between the cup and dampner.
Old 03-08-2013, 01:43 PM   #38 (permalink)
Thanks. Can we just put one shim instead of 2 if the grips get too tight?
Old 03-08-2013, 01:50 PM   #39 (permalink)
The stock build flies fine for me.
Old 03-08-2013, 02:11 PM   #40 (permalink)
The grips are a little on the loose side for me and need a little stiffening.
