450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
08-07-2016, 07:31 PM | #21 (permalink) | |
Good for you bro. How is your 450l treating you. Which fbl unit and batteries did you got? Yes my heli got stuck in customs for a while thats why set it up late but anyways ...worth the wait . |
08-07-2016, 07:33 PM | #22 (permalink) | |
08-07-2016, 08:01 PM | #23 (permalink) |
Found the problem of power failure! Bad solder point at motor bullet connector
Update guys:
I could not believe my eyes. Was just checking the esc and motor again and found this!!! Motor came presoldered from the box. I guess align has to be more carefull in their soldering job Re attahed the wire by hand and then connected the battery.. Motor started emmiting beeps like normal mode . So will do proper soldering today and see how she goes... Thanks for the support Helifreakers! It seems oliver 1071 was right |
08-07-2016, 08:09 PM | #24 (permalink) | |
I spent this morning with a new 1/10 25.5 F1 motor that I found to have cold solder joints on the sensor connector. I kept on replacing the sensor cable and it was still intermittent. My 450 is fantastic. I flew 6 packs through it today. It is the biggest heli I have ever flown. I use 3GX 5.0 and the same battery you have. I actually wanted 3GX because it is on my TREX 250 and I know how to program it by memory. |
08-07-2016, 08:18 PM | #25 (permalink) | |
Awesome glad you found it. I was so bumbed when it happened with mine. It was like my 2nd or 3rd flight on a brand new heli. Nothing sucks more than crashing a brand new heli and it's not even your fault.
__________ Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071 |
08-08-2016, 01:06 AM | #26 (permalink) | |
glad to know abt ur 450l report. the power is good. its good if you are happy with 3gx because most people i know change it the first thing when they get a heli deal with 3gx. i got continuous wag problem with 3gx because my 550 was not perfectly balanced. when i used a v-bar clone, heli flew liek a dream, tail rock solid ever since. also with 450l gpro i seem to have a slight wag problem when in hover, other its just fine. may be it still needs the perfect gain adjustment.. will tweak with it more.... |
08-08-2016, 01:07 AM | #27 (permalink) | |
my esc died on my 550 , and another time swash link just popped out from 550 |
