Century Century Helicopters Support |
06-24-2014, 05:01 PM | #1 (permalink) |
my predator is back together
but waiting for a carb and spark plug.....i will be asking a ton of questions again......so hope your all ready....LOL so thanks to century and forum members for some parts....thanks to all im still having a fuel problem, and im getting a new spark plug to.....so ill be back with tons of ???? cant afford a crash this time. |
06-24-2014, 08:37 PM | #2 (permalink) |
Looking good cruzroy. If you need any help you will find a lot more Century guys here then on RR.
Phil |
06-25-2014, 08:07 PM | #3 (permalink) |
WELL OK NOW............................help
well ok just got my wt 643 in, and rebuild kit for old carb, and brand new spark plugs
so this 643 has no choke???.......how do i start this thing.... what is the gap for a plug..... hanson 231 motor, what are needle setting for wt 643 and what color locktite on carb screws ok thats it for now....then i will need throttle curves pitch curves.......sorry but starting fresh thanks for all the help |
06-26-2014, 11:30 AM | #4 (permalink) |
What air cleaner are you using. The stock Zenoah air cleaner has a choke lever on it that closes ff the throat of the crab for priming/choking. If you do not have a stock air cleaner you can choke by placing a finger over the throat or wrapping something around the air cleaner intake area to prevent air from entering.
I found a plug gap of 0.024 worked well on my Predator with the G231. The crab settings were L: 1 1/16 and the H: 1 1/8. Doing a full pitch climb for about 3 seconds and listen for distress bogging, if so open the top needle a bit and try again. If it ius OK. Then hover and listen to the motor, if it burbles, then you can turn in the L needle a hair and hover again. What you are looking for is a good transition to full throttle. with a slight burble occasionally in the hover. As for locktite on carb screws. I have never used them. As the motor runs at a temp that will soften any standard locktite, I could never see a use for it in this location.
Phil Last edited by MotorRotor; 06-27-2014 at 01:39 PM.. |
06-29-2014, 08:35 AM | #5 (permalink) | ||
another watch and help video....
still having an issue with the fuel bulb wont pump after the bird warms or is just over heating........im just getting frustrated, i have lawn equipment and i can tune those....why is this a pain, or is there something else wrong....so another vid if your all bored, and want to watch a noob at it again century predator after crash (14 min 33 sec) |
