Old 08-26-2014, 07:19 AM   #421 (permalink)
clueless people talking smack about helis they have no clue about. 700 exxxtreme is a bad ass pitch pumping cyclic power horse like no other with the queit smoothness mikado is known for and as for the 690sx its every bit a 700 as any orther heli on the market. appearance, power, agility and blueprint in the sky is equal or better than most other 700 size heli on the markets. i love people who talk smack about helis theyve never owned it keeps me entertained.
dbirds2 is offline        Reply With Quote Quick reply to this message
Old 08-31-2014, 07:48 AM   #422 (permalink)
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 11-30-2014, 06:34 AM   #423 (permalink)
just in reply to a few things i read about gear train strength a page back ..a few years ago i brought the first run of scorp 4525-520kv le motors (ultimate) along with a newly released logo 600se..
and i can say from experience that it ate the main gear no problems! ...i started of with 12s and 693mm edge blades two flights two main gears destroyed ..put the old style motor shaft support on to try help with no luck tried fine tuning how i was meshing the gears adjusting them tighter or looser ..no deal! almost a main gear by the end of every hard flight and it was only beginner sport 3d the motor was just too much for the old 600se,
so eventually i went to 623mm edge and a 10s setup and had no further dramas.. amazed to see that years after i was probably one of the first to tinker with a motor that size on that gear train that mikado eventually thought of it themselves and released a solution ...seriously looking at buying this heli as ive been regreting the day i sold it ..and to have it in 690 ..drooling! love it! go mikado! ...now has anyone tried 710's on these ???
also if the new 380kv motors are less powerfull then the 4525-520 le then thats fine by me i was actually considering selling it back in the day top put a smaller motor in i think the 4525-380 would be bang on perfect for the 690's it will not seem to be lacking in power to me in the slightest
logo
kangaroo801 is offline        Reply With Quote Quick reply to this message
Old 12-01-2014, 04:10 PM   #424 (permalink)
It's almost painful to answer but here I go.
Logo 600SE chews gears with 4525: Of course. I don't know where you got the info that you could use that motor on that heli.
Logo 690SX has the same drive train as 600SE: of course not.
690SX has:
- Bigger (taller) main gear
- Counter bearing support
- Double one way bearing
- Bigger pinion requirement (15t) and that's why a 380Kv is required
So an old 600SE of course can't withstand a 4525LE, a 690SX can take it all day long as long as it's 380Kv and you use 15t pinion.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 12-01-2014, 08:45 PM   #425 (permalink)
Correct Marcos. You are safe with the 15t and we have been using the 14t quite a bit with the Pyro, but 15t is preferred if you have the correct Kv rated motor.
Ryan
Mikado USA, Kontronik, Opti-Power, MKS Servos, VTX
RyanW is offline        Reply With Quote Quick reply to this message
Old 12-01-2014, 09:13 PM   #426 (permalink)
quick Q for those that have built this, I started the build and the manual says to set the motor pinion before putting the frames together and refers to page 9, where it shows using all 6 of the shims between the pinion and motor counter bearing, but states to make sure to use only one shim? What is correct
janol is offline        Reply With Quote Quick reply to this message
Old 12-01-2014, 10:45 PM   #427 (permalink)
Use all six shims. The note about using one shim appears to be left-over from another manual (e.g. 550sx) where it is one tall shim instead of stacked skinny shims.
Team MikadoUSA
hemp is offline        Reply With Quote Quick reply to this message
Old 12-01-2014, 10:56 PM   #428 (permalink)
thanks for the quick reply, build continues
Old 12-02-2014, 06:49 AM   #429 (permalink)
As a matter of fact i am using 4530 on my logo 690 winded to 390 KV and 15 T pinion, have over 20 flights so far without a problem.
_____________
abanihani is offline        Reply With Quote Quick reply to this message
Old 12-02-2014, 09:23 AM   #430 (permalink)
Are you babying it or are you smacking it hard?
maarset is offline        Reply With Quote Quick reply to this message
Old 12-02-2014, 10:52 AM   #431 (permalink)
Hard baby
_____________
Old 12-02-2014, 11:11 AM   #432 (permalink)
LIKE!
I wonder if someone is going to try a KDE700XF-395 ?
OK I'll stop
Peace
Old 12-02-2014, 08:05 PM   #433 (permalink)
i am using 4530 ... without a problem
Except for weight, I'd guess? The 4530 LE is 60 grams heavier than the 4525 Ultimate. My 690sx is already nose heavy without putting a heavier-than-stock motor in it. Not that it can't be compensated for, just something to note.
Team MikadoUSA
Old 12-05-2014, 10:29 AM   #434 (permalink)
anybody actually weight the stock motor? I working with a friend to come up with a new motor for this heli, something wound to around 365-380 with a concentric bearing at the back of the motor
Old 12-06-2014, 11:09 PM   #435 (permalink)
LIKE!
OK I'll stop
Peace
Hmmm, that's a great idea mike. Kde motors have been great to me.
Just one more honey... I don't have one like this.
Kilo23 is offline        Reply With Quote Quick reply to this message
Old 12-06-2014, 11:20 PM   #436 (permalink)
Just looked at specs, 1.5 hp to every pound sounds fun.
Old 12-10-2014, 09:36 PM   #437 (permalink)
quick question for those that have the 690sx and use a separate rx pack.
where and how are you securing the pack?
Old 12-10-2014, 09:48 PM   #438 (permalink)
A small 2S Lipo tucks away nicely inside the compartment created by the chassis box. Also happens to be a good spot for an external BEC if you go that route.
Team MikadoUSA
Old 12-10-2014, 09:52 PM   #439 (permalink)
yes, but how to secure it from sliding around, velcro, but it is a pain to get it in and out
Old 12-10-2014, 10:00 PM   #440 (permalink)
OK, another question, I went to tighten the main blades on the heli and the nylock nut in the grip did not hold in their pocket, they started to slip way be for the grips were tight
