Old 08-25-2014, 12:28 PM   #21 (permalink)
Originally Posted by Badhelipilot View Post
What calculation did you enter for your gear ratio?
I'm not familiar with that motors pole count or the pinion your running to calculate it myself to reference it to you to see if it's what you've entered.
Main gear: 106T
Pinion gear: 12T
Magnet poles: 10
(106/12)x(10/2)=44.16
This is the calculation I did.
LOGO 600 SX [ Pyro 700-52M | Scorp. Commander V 130A OPTO | VBar Neo | BLS255HV & BLS256HV ]
LOGO 600 SX
[ HKII-4225-500KV | Scorp. Commander V 130A OPTO | VBar Neo | BLS255HV & BLS256HV ]
bavci_0655 is offline        Reply With Quote Quick reply to this message
Old 08-25-2014, 12:37 PM   #22 (permalink)
Originally Posted by sctholson View Post
Okay, so you have two problems remaining, 1 is that the rpms vary and that it turns left.
Okay, so by rpms vary do you mean that while the governor is on and your flying around the governor isn't holding a steady rpm? what is your gov gain setting and what is your overdrive set to?
On the still turns to the left, did you redo the esc min and max throttle. I did have this problem in several helicopters and it always seems to resolve by redoing the esc min max, skookum min max and possibly changing timing and pwm settings in the esc for the motor. Do you know what the timing and pwm as set at?
Yes, governor is on and it doesn't have a steady rpm even in hover.
I did esc throttle calibrating before this update. I will try that after re-setup from the begining.
Esc is a Scorpion Commander VI 130A OPTO. Timing is 5 degrees as Kontronik recommends. PWM setting can't be adjusted on this esc.
LOGO 600 SX
Old 08-25-2014, 12:39 PM   #23 (permalink)
Originally Posted by georgi UK View Post
=] please start with a fresh SK profile & Tx model.....
I will try this and post the results as soon as possible.
LOGO 600 SX
Old 08-25-2014, 12:52 PM   #24 (permalink)
=] I think it's your only way out, sorry to see the hassle but this could be quicker..
Old 08-28-2014, 10:35 AM   #25 (permalink)
I did a complete setup and did a test hover. I think it need some small adjustments. And I have to do a real flight test to prove that it is working. I can't wait to fly it.
LOGO 600 SX
Old 08-28-2014, 10:57 AM   #26 (permalink)
=] looks like you have cracked it!
Old 08-28-2014, 11:58 AM   #27 (permalink)
Sometimes nothing like a fresh setup to make everything right again.
YS Powered Rave ENV Stretch Protos 500, Stretch Mini Protos, 180 Trio
gitbse is offline        Reply With Quote Quick reply to this message
Old 09-01-2014, 12:07 PM   #28 (permalink)
Hi,
Yesterday I did 12 flights with succesful results on governor. But when I give throttle at start up, heli turns about 20 degrees on the ground. BTW, throttle starts when collective stick is more than ~%10 percent. Also after throttle hold, start up is too aggresive (more than before). Heli turned almost 360 degrees on the ground. This start up is really ignoring. I will try NHENRY's suggestion about using Hobbywing rpm sensor.
Thank you everyone for your kind help.
Burak
LOGO 600 SX
Old 09-01-2014, 01:06 PM   #29 (permalink)
All of my logs would look like that with the high amplitude spike just as throttle hold was disengaged, when i used my Jeti Mezon RPM ESC with built in RPM sensor, but now it is perfect using the external Hobbywing sensor. ! I look forward to your results with your scorpion ESC
It is worth mentioning, that for me, it was not just a problem with Skookum firmware 4, I had the same issue with the last 2 firmware editions, but not in anyway blaming the Skookum unit as i do not fully understand the the problem here, i just know a workaround for now!
I think a preset fix for one ESC can fix it for one and can break it for another, so maybe in the future we could have user adjustable variables within the software for bailout!
I seems that certain Esc's with the built in RPM sensor are doing something different, compared with other standalone sensors like the hobbywing. Having a standalone phase sensor connected from the motor to the skookum unit is simple and avoids any complications of an inbuilt ESC RPM sensor being controlled by many variables within the ESC which then conflicts and becomes incompatible with the skookum FBL unit. Just thinking out loud!
Maybe someone else could provide further solid knowledge here!
Gaui X7 | Gaui X3 3s (TT version) | Gaui X3 3s (Belt version) | Nano CPX..........JETI DS-16 Tx
NHENRY is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 06:11 AM   #30 (permalink)
A log for omerco
LOGO 600 SX
Old 09-06-2014, 12:37 PM   #31 (permalink)
Yes i see the second problematic spool here as well. Opto cable,right?
Is this the one you PM'd me - without blades? very low throttle percent.
80 low Ramp 100 high ramp are my numbers on all my ESCs they work well with all (scopr 160HV, CC120HV, YEP120HV, K-force 40A)
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks
omerco is offline        Reply With Quote Quick reply to this message
Old 09-06-2014, 02:53 PM   #32 (permalink)
Rpm readings are coming from opto cable. This is the log that you see. I tried with your suggestions (80 low ramp, 100 high ramp). Your numbers give better spool up.
LOGO 600 SX
Old 09-06-2014, 02:55 PM   #33 (permalink)
Well, I can say after re setting both my problematic Skooks yesterday. I did get my slow spool and great gov engagement back. I am using the HW sensors on both. In my case both helis hard starts were software glitch related. Cleaning out the Skooks and doing a manual ground up value input, plus re calibrating my esc's did the trick. Thanks for the advice here from the experts!
Old 09-06-2014, 10:30 PM   #34 (permalink)
Hmmm...ok thanks. Could try the HW sensor.
Time to add SOLVED to thread title?
Old 09-07-2014, 12:12 AM   #35 (permalink)
I will but I can't see the edit button on first post.
LOGO 600 SX
Old 09-07-2014, 04:22 AM   #36 (permalink)
=] say how you want it to read, will do it for you.....
Old 09-07-2014, 08:16 AM   #37 (permalink)
Hit the Go Advanced icon after going into the edit function to gain access to the thread title.
EDIT: NM, I see you don't have access to the edit function anymore. The edit ability times out after a certain number of days, so Georgi can fix it up for you
Tony
Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do
Xrayted is offline        Reply With Quote Quick reply to this message
