Old 04-23-2008, 01:31 PM   #1 (permalink)
Thumbs up New power supply for my Hyperion Duo
Guys, check what UPS man drop at my door today.
New power supply for my charging station Hyperion EOS0610i Duo. Massive amount of output power, from 3V to 15.5V variable or fixed 13.8V via switch at the bottom of the unit, at 40A.
The unit is the BK Precision 1692, got it at: http://www.byramlabs.com/product_inf...oducts_id/7471 at a very good price $263, comparing to other suppliers. The only thing was that it took about 6 days to get it because they do not stock the item and it comes from BK Precision.
You can also find it at: http://www.testequipmentdepot.com/bk...plies/1692.htm but for $309 with free shipping.
If you want to charge two packs as one with the Duo you need something like that, because the duo needs max 360W output and this power supply provides 450+Watts.
Check it out.
Name:	LiPo Charging Station 001.jpg
ID:	46097   Click image for larger version
Name:	LiPo Charging Station 002.jpg
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote Quick reply to this message
Old 04-23-2008, 07:02 PM   #2 (permalink)
Nice unit but expensive. For example some alternatives all under $110 include:
540W 11-18V 30A
500W 13.8V 36A
350W 24V 14.5A
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 04-25-2008, 06:09 PM   #3 (permalink)
540W 11-18V 30A
500W 13.8V 36A
350W 24V 14.5A
I know but, none of the above Power Supplies look as good as this one, right?
Looks and size do matter....
Panos.
Team GrandRC
Old 04-25-2008, 06:26 PM   #4 (permalink)
Quite right, enjoy
Kenneth
Old 04-30-2008, 04:57 PM   #5 (permalink)
Sorry to say, but your power supply is a big overkill...!! Even with a 13,5V / 20A power supply, you can easily charge 2 6S LiPo's in series.
From your pictures, it seems like you power only have connectors for one charger. With the specifications of your power supply, you could handle two Hyperion Duo's, each charging two 6S LiPo's. But you don't have the connectors for that.
But I do agree in one fact - your power supply looks great....
Sveberg is offline        Reply With Quote Quick reply to this message
Old 04-30-2008, 06:49 PM   #6 (permalink)
Originally Posted by Sveberg View Post
... Even with a 13,5V / 20A power supply, you can easily charge 2 6S LiPo's in series.
Do you know that from your own experience ? Of course it depends on what capacity 6S lipos and whether you want to charge at or above 1C. For example, charging two 6s 5000 mAh lipos at 1C will draw approximately 280W from the power supply. At 13V that would be 21A. Since these estimates allow for only 80% efficiency in the charger and the power supply might tolerate a small overload, then you probably could get away with a 13.5/20A unit but you would be running it at its limit and it would potentially have a shortened life under those conditions. Of course if you want to charge at 2C you are completely out of luck with that power supply.
It never hurts to have headroom in your power supply and connecting more than one charger is simple enough even with a single set of banana sockets. And besides, that's a damn fine looking PS
Kenneth
Old 05-07-2008, 09:13 AM   #7 (permalink)
[quote=Sveberg;655535]Sorry to say, but your power supply is a big overkill...!! Even with a 13,5V / 20A power supply, you can easily charge 2 6S LiPo's in series.
Sveberg,
Don't forget that the Hyperion Duo is a "Duo" that means two chargers in one.....
So I do have two chargers connected to one output...
But don't you worry, I will find a way to connect my TP 610 C , at the same time with the Hyperion Duo, because like you said it is an overkill and it can handle it with no problem.
Team GrandRC
Old 05-08-2008, 12:08 PM   #8 (permalink)
or if your in the uk you can get the same thing from here
http://www.rapidonline.com/Electrica...supplies/65063
which i have and chargeing my 6s 2100 packs at 2amps you can pull 7 amps
or if you need more power there is this one 60amps
http://www.rapidonline.com/Electrica...-control/75295
2 x Blade MCPX,stock & duel Brushless
Trex 250FBL,BeastX,Scorpion,Trex 450,Scorpion,4s,Jazz esc,Trex 500FBL,3GX V3.1,5s,Scorpion
Avant, Kasama head,OS 91 OMI,XeroG Raptor,Total G,Outrage Head
Trex 600 EFL Pro super combo,BeastX
d3sbo is offline        Reply With Quote Quick reply to this message
Old 06-02-2008, 10:02 PM   #9 (permalink)
im runnign a 40amp power supply on my duo and it works great.
justin keaton is offline        Reply With Quote Quick reply to this message
Old 06-04-2008, 09:18 AM   #10 (permalink)
How about this one, it even has bling... I got it seems to be great
http://www.jackedupcustoms.com/
-Ari
aka, Sir-Crah-a-Lot
aballen is offline        Reply With Quote Quick reply to this message
Old 06-04-2008, 10:10 AM   #11 (permalink)
$100 is expensive for a 12V/20A supply but if you like the shiny case and flashy lights then go for it! For reference the Hobby Lobby 13.8V/20A is about $59 and for $99 you can get their 13.8V/40A unit: http://www.hobby-lobby.com/powersupply.htm
Kenneth
Old 06-04-2008, 10:16 AM   #12 (permalink)
I got it a bit cheaper some time ago... one of the "early units" before he had a website... seemed like a good deal at the time.
-Ari
aka, Sir-Crah-a-Lot
Old 06-06-2008, 10:32 AM   #13 (permalink)
i have 13,8v 20A PS , can i charge two 2*3s2200mah at 1C?
sulan is offline        Reply With Quote Quick reply to this message
Old 06-06-2008, 12:35 PM   #14 (permalink)
yes
-Ari
aka, Sir-Crah-a-Lot
Old 06-09-2008, 09:36 PM   #15 (permalink)
Ok.. I hope this is not a stupid question.... Are there any concerns with the amperage, since my breakers in my home are 20 Amp?
If I were to use a a 40 Amp power supply, would that be a problem? Would it trip my breakers if I charge multiple 6s packs at a time?
BRIAN FLORES
HOUSTON, TX
EMAX HAWK 5: Spektrum DSMX ▪ DX18G2 Stealth
TREX 250: Zippy 1000mAh 45C ▪ Spartan DS760 w/290G ▪ HS-65HB ▪ CC25
bflores is offline        Reply With Quote Quick reply to this message
Old 06-09-2008, 10:39 PM   #16 (permalink)
The breakers in your house are 20A at 110V AC = 2200W per circuit. A 40A 13.8V DC power supply should draw no more than about 40 x 13.8 /0.8 = 690W so you could run 3 such supplies driving lots of charges all off one AC circuit without blowing the breakers in your house.
Kenneth
Old 06-25-2008, 11:12 PM   #17 (permalink)
So if I wanted use the Due to its maximum would the 13.8V/40A power supply be over kill? Or would it be just right? Also does one power supply give power to both sides of the Due?
Heli_freak is offline        Reply With Quote Quick reply to this message
Old 06-25-2008, 11:20 PM   #18 (permalink)
Yes, a single power supply runs the DUO, there is only a single input lead.
13.8V/40A = 552W which is plenty for the DUO and IMO is not overkill but it is worth noting that due to current limiting on the input side, you will not get the full 180W/port unless you have at least 15V input. However at 13.8V you will probably get 160W or more which is still enough for most folk.
Kenneth
Old 06-25-2008, 11:31 PM   #19 (permalink)
Can you recommend a power supply that has the 15V/40A for a good price?
Old 06-27-2008, 02:27 PM   #20 (permalink)
I also use the BK Precision 1692. Works PERFECTLY!
TRex 500 CF, AR7000, S9650, S9257 Spartan DS760, all metal part upgrades, TT, Stock ESC/BEC, Hacker A40 10S
Outrage 6S1P 25C 2500mAh and 3300mAh & Zippy 3300mAh
Spektrum DX7
Phoenix Sim on MBP 2.33 GHz Core 2 Duo w/ Parallels & WinXP
Augman37 is offline        Reply With Quote Quick reply to this message
