450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
02-06-2005, 02:54 PM | #1 (permalink) |
What's your setup on the Trex?
Just wondering who uses what :wink: .
Logo 800/Jeti DS16 |
02-06-2005, 03:27 PM | #2 (permalink) |
Here is my setup
Mega 16/15/4 16 tooth pinion TP 2100 3s1p CC35 3 HS56 MH 120 deg swash MS carbon blades stretch carbon boom 401 gyro with hs 50
Jon Jennings |
02-08-2005, 10:43 PM | #3 (permalink) |
T rex 450 x
bats 3s1p kokam 1500 servo 3 blue bird 371's 1 blue bird 306 bb gyro gy 401 motor chili pepper 3600 kv with 9 tooth blades stock 315mm woodies and i think thats it smoked the chili pepper using hand wound cd motor |
02-09-2005, 07:26 PM | #4 (permalink) |
Trex with stretch boom and Align "Carbon" blades.
AON 3500 11 tooth pinion CC 35 esc TP 3s 2100 GY240 Hitec HS56 X 3 Futaba 3108 on tail Prior to this motor I tried the Align 400s, Chili 3200, and Mega 1615-3. The Mega was close but still got too hot. The AON is only warm after a flight. |
02-10-2005, 07:34 AM | #5 (permalink) |
Align 400L
14 Tooth Align 35 4 HS56 401 3S 2220 Tanic The motor is a POS |
02-11-2005, 04:02 PM | #6 (permalink) |
From reading on RR I guess I'll buy a Lehner 1020/17.
500 watt/ 750 grams.....
02-12-2005, 11:04 PM | #7 (permalink) |
Himax 2815-3000 13 tooth pinion
Phoenix 25 Kokam 2000mah 15C I am very happy with this combo, I ran a Himax 2025-4200 from my Shogun before this motor (weak). Now the climb out is comparable to my sceadu/hyper 50. The Kokam 2000s never get over 94 degrees and the motor runs 120's with a heat sink. My head spead with the 13t pinion is 2500 rpm on the ground in idle 1 and it maintains very well during extended climbouts. I would highly recommend this combo. The motor costs $79 and comes with the the male connectors already soldered on and you also get the female connectors for your speed control. This motor has a 3.17 inch shaft so you can use the 13t pinion that comes with the T-rex kit. :glasses2: I run fixed throttle mode, idle 1 throttle curve 90-80-75-80-90. Idle 2 90-90-90-90-90.
-Brandon Crosier |
02-13-2005, 09:28 AM | #8 (permalink) |
929pilot- do you know the current draw on this setup?
02-13-2005, 11:44 AM | #9 (permalink) |
mudbogger- No, I set my timer for 6 minutes, when it goes off I usually do one or two more things and land. When I charge the pack with my Triton it takes 1300 to 1370 mah. Considering the temps I'm getting this setup will last a long time. If I'm using 1370mah in 6 minutes wouldn't that be like averaging 13.7 amps? According to himax this motor requires a 25 amp controller.
Before I put on the heat sink I was getting 145 degrees with it on I'm getting 124. The battery has never reached 100. I think a large key to the perforance is the battery pack (Kokam 2000-15C). When I tried my old packs (Kokam 1500-6 or 8C) the performance drops off big time and the pack gets hot. When I first used the 2000-15C pack with the 2025-4200 motor it helped alot but when I install the 2815-3000 I new my search was over.
-Brandon Crosier |
02-13-2005, 12:09 PM | #10 (permalink) |
Tower sells this pack with the deans plug on it for $68.99. It flies great but won't fit in the canopy unless you lose the servo frame by going ccpm.
http://www2.towerhobbies.com/cgi-bin...&I=LXHFG2&P=ML
-Brandon Crosier |
