Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 10-25-2013, 05:09 PM   #21 (permalink)
"Forget the heli" because he is trying to make a good point that has to do with tolerance stacking. Don't get me wrong, I'm a huge compass fan, but it should be on Compass to be making sure that all the booms and belts are the same length and the correct length, not an individual who fly's a compass heli. FWIW I have had this issue with all of my booms. With both 17t and 19t tail pulley. The 19t obviously being worse.
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 10-25-2013, 06:11 PM   #22 (permalink)
For those of you that are unsure ,as soon as you take the 17 tooth out you will see right away that the 19 will not fit .Its just a simple case of taking a file or dremel and take an 1/8 off the boom and the slots .I do have the old boom and the new boom and there the same size
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 10-26-2013, 05:49 AM   #23 (permalink)
+1
Modding the boom to fit is simple, assuming someone has tools to do it, but should not be necessary.
Compass should update the boom/slot dimensions to fit out of the box.
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 10-28-2013, 10:49 AM   #24 (permalink)
CHC Benefactor
Originally Posted by Bob O View Post
Maybe you can purchase a bunch of tail boom and tail belts, measure them all, and see if you can find some inconsistencies.
I would speculate that if I were to buy a bunch of booms and belts that they would likely all be pulled from the same portion of the same batch.
If production variances were actually happening it would be far easier for ProStar or Compass to check random samples of current stock. It could be that all previous runs have been depleted and they could not readily investigate but they have a far larger sample size at their disposal.
However, ProStar is unaware that any variances might exist, hence have no reason to check. "Clairvoyance" is, of course, not a reasonable expectation for either a manufacturer or distributor.
Hawk404 is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 02:16 PM   #25 (permalink)
I can 100% confirm that there either ARE variances or that Compass has changed the part without notifying anyone. I have just replaced me boom (had a small dent) with a new boom purchased from heli direct within the last week. Both booms are the newer thicker booms. I just took one off the heli and one out of the package after reading this thread, so i was a little curious. The new boom is 3.5mm shorter than the other and allows much easier installation and correct tension, using the 19t pulley, without any modification. I personally am glad to see that it is shorter because it is much easier to work with. I am attaching pictures of the 2 booms (old on top new on bottom)
ID:	477320   Click image for larger version
ID:	477321   Click image for larger version
Protos Max 700 Vbar, Synergy E7se Vbar, Rush 750 Vbar, Gaui X5 Vbar, Gaui X4II Vbar, Protos 500 Vbar, Compass Warp 360 Vbar, Gaui X3 Robird
Controlled by: Jeti DS-16
Clay333 is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 07:07 PM   #26 (permalink)
If this is indeed on purpose, thank you compass!
Sent from my SCH-I535 using Tapatalk
Old 01-07-2014, 08:48 PM   #27 (permalink)
I put the 19T and did not have to modify the boom.
The heli had some tail wag during some high speed manouvers. Now it does not.
AlvaSpeed is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 07:16 PM   #28 (permalink)
Quick question... Do you still use the limited tail throws on the 19t? I just bought this warp used and it had the 19t already installed. I have a kinda nasty tail kick after the heli loads up. Like the gov is to aggressive. I should switch off the gov to properly tune the tail. Can I use a YEP esc card to change gov gains? Or which yge esc cards? thanks
TEAM IKON
TEAM KDE DIRECT
HeliDoc25 is offline        Reply With Quote Quick reply to this message
