Go Back   HeliFreak > R/C Helicopter Support > Bergen R/C Helicopters
Bergen R/C Helicopters Bergen Intrepid 90 Intrepid Turbine Observer Industrial Twin Observer Turbine Support Forum
Old 02-10-2008, 11:29 PM   #21 (permalink)
Chris,
What will be the AUW with & w/o lipo's ?
Jesse
... good.. bad.. I'm the guy with the gun.
j_kookboy is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 11:38 AM   #22 (permalink)
My Tazer weighs in at 10.5 with the 5350 5s batteries.
The Tazer 800 will be slightly more w/ the long boom/blades and 6s...
Chris D. Bergen
cbergen is offline        Reply With Quote Quick reply to this message
Old 02-11-2008, 05:42 PM   #23 (permalink)
Front transmission and lower mainshaft bearing block installed.
Here's what it's supposed to look like to this point with upper and lower bearing blocks installed and elevator yoke in the middle.
Name:	75install lower mainshaft BB.jpg
ID:	38331   Click image for larger version
Name:	78 all together now.jpg
Chris D. Bergen
Old 02-11-2008, 09:22 PM   #24 (permalink)
The Tail servo is mounted just under the boom, but is still attached to the frames.
The boom clamps actually clamp the boom without requiring the addition of tape or sandpaper for a solid, no slip affair.
Name:	80tail servo mount and boom clamps.jpg
ID:	38356   Click image for larger version
Name:	85install servo mount w bolts.jpg
Chris D. Bergen
Old 02-11-2008, 09:28 PM   #25 (permalink)
A gyro mount is included in the kit, no need to guess where to put your favorite gyro.
This angle mounted plate is also an ideal place to mount the second 2.4 ghz receiver.
Name:	86gyro mount and slope mount.jpg
ID:	38358   Click image for larger version
Name:	89 install plate into frames.jpg
ID:	38360   Click image for larger version
Name:	90install slope plate.jpg
Chris D. Bergen
Old 02-11-2008, 09:44 PM   #26 (permalink)
The Tazer kit comes with the constant driven tail system, the standard main gear (non driven) can be installed as well for those without a need to do aerobatic autorotations....
The crown gear hub utilizes pinch bolts to keep the gear running true to the mainshaft ,another Malorie design.
The Autohub utilizes 2 one way bearings in a substantial aluminum housing. No cracking, no slipping, no locking up, no mods necessary. We do recommend using a light oil for lubrication, NOT grease.
Name:	92 constant driven tail system.jpg
ID:	38364   Click image for larger version
Name:	99install pinch bolts.jpg
ID:	38365   Click image for larger version
Name:	101install auto hub.jpg
Chris D. Bergen
Old 02-11-2008, 09:53 PM   #27 (permalink)
The mainshaft is 10mm, hollow and fully hardened.
It's held in place with the original split collar, oft imitated, but never duplicated!! No need to double them up, these won't crack around the bolt hole.
We do, however, recommend the use of a hardened allen driver, NOT an allen wrench, as you are less likely to strip the head out. No need to overtorque these, and we do NOT recomend loctite on the screw.
Name:	105begin mainshaft install.jpg
ID:	38367   Click image for larger version
Name:	106mainshaft install.jpg
Chris D. Bergen
Old 02-11-2008, 10:08 PM   #28 (permalink)
Installing the main gear is next, lowering the mainshaft through the autohub, locating the setscrew into the divot on the mainshaft, then installing the lower mainshaft collar.
The screw in the lower collar is an sae bolt, 4-40 to be exact, so don't use your metric driver on it.... Use a 3/64" allen wrench. Two options here to set any up and down float of the main gear. You do want "some" float of the main gear and autohub vs it being bound up between the lower collar and the crown gear hub.
If you have excessive up and down float, install the lower collar with the step on the top. If the system binds up, flip the collar over (step down) for clearance.
Name:	107main gear assy.jpg
ID:	38369   Click image for larger version
Name:	108locate divot w setscrew.jpg
ID:	38370   Click image for larger version
Name:	110install lower mainshaft collar.jpg
Chris D. Bergen
Old 02-16-2008, 05:38 PM   #29 (permalink)
With the main gear in place, tighten down the split collars, bottom one first while pushing UP on the main gear, then the upper collar.
Doubling up our Split collars is NOT necessary, we reduce the size of the head of the bolt to leave more meat on the collar so these won't crack....
Now set the mesh of the tail drive pinion/bevel gear by pushing down on the front of the transmission cage (remember the slots..). Due to the pressure of the side frames, this may require some force or a little tap to get the front end down. What you're looking for are the "ears" of the transmision to be at least flush with the mainshaft bearing block.
Now looking up the back end of the heli, ensure that the Delrin coupler is centered in the boom clamps.
Name:	111tighten bottom split collar.jpg
ID:	38812   Click image for larger version
Name:	114tighten gear mesh.jpg
ID:	38813   Click image for larger version
Name:	116 align delrin coupler.jpg
Chris D. Bergen
Old 02-16-2008, 05:44 PM   #30 (permalink)
With the main gear in place, we can now set the pinion to main gear mesh and the belt tension.
Name:	118set  height of pinion.jpg
ID:	38819   Click image for larger version
Name:	119align pinion to main gear and set mesh.jpg
ID:	38820   Click image for larger version
ID:	38821   Click image for larger version
Name:	123belt tension.jpg
Chris D. Bergen
Old 02-16-2008, 05:52 PM   #31 (permalink)
Swashplate and washout unit are next, both are all metal, no plastic except for the
radius link (porkchop).
After installing short balls in the outer ring and medium balls in the inner ring, slide it onto the mainshaft, attaching the ball links from the elevator yoke.
ID:	38823   Click image for larger version
Name:	127install swashplate.jpg
Chris D. Bergen
Old 02-16-2008, 06:24 PM   #32 (permalink)
This brings us to the washout unit and washout arms. You will find 2 packages of radius links (Porkchops) in your kit.
I'll show the suggested assy first, then the alternative with the extra links.
The layout of the parts is as shown, the arms are aluminum, the base is aluminum, there are 2 bearings in each arm, note the brass washer between the bearing and the base.
Assemble the first arm with the radius link and crosspin, securing the crosspin with a setscrew.
ID:	38827   Click image for larger version
Chris D. Bergen
Old 02-16-2008, 07:39 PM   #33 (permalink)
The washout arms are installed with a shanked bolt, the brass washer, and a setscrew which is installed from the OPPOSITE side, acting as a jamnnut (screw?).
Tighten the bolt enough to remove slop from the bearings, but not so tight as to make them notchy. Secure by tightening the setscrew against the bolt.
Name:	131install washout arm bolt and ss.jpg
ID:	38848   Click image for larger version
Name:	132tighten ss against bolt.jpg
Chris D. Bergen
Old 02-16-2008, 08:04 PM   #34 (permalink)
The washout unit is hardcoated on the inside, keeps it from wearing out. Slide it onto the mainshaft and snap the radius links onto 2 opposite balls on the inner ring of the swashplate.
Now the explanation of the alternate links.
Line up the balls that you snapped the porkchops onto with the outer balls of the swashplate, preferably the ones to the sides.
Look at the flybar, noting the angle, that it is NOT pointing straight out away from the heli.
This is the "retarded" setting, and in general, gives you a more stable hover and less cyclic action.
Name:	134install washout on mainshaft.jpg
ID:	38850   Click image for larger version
Name:	135line up the swash balls.jpg
ID:	38851   Click image for larger version
Name:	136 note the retarded angle of the flybar.jpg
Chris D. Bergen
Old 02-16-2008, 08:13 PM   #35 (permalink)
If you opt to use the other links, then your assy will look like this. Note the washout arms are flipped over and the bolt is installed in the other hole.
Now if you line up the swashplate balls and look at the flybar, the angle is now "advanced".
This gives a less stable hover, but more cyclic action.
The porkchops are handed, meaning they only snap onto the ball in one direction, seen in the photo.
All of this is also called swashplate timing, and in the higher end radios can be adjusted electronicallyin a specific mode or by mixing in some aileron with elevator, and elevator with aileron.
If you prefer to have your swashplate timing set to 0 and have pure aileron and elevator movement, then use the first, suggested setup and mix it out in your radio.
Name:	137with the other links assembly looks like this.jpg
ID:	38853   Click image for larger version
Name:	138 line up the swash balls.jpg
ID:	38854   Click image for larger version
Name:	139the flybar is now advanced.jpg
ID:	38855   Click image for larger version
Name:	140the links are handed, note the ball socket.jpg
Chris D. Bergen
Old 02-16-2008, 08:17 PM   #36 (permalink)
Assy of the control system is next, and it isn't as complicated as it looks...
All pieces are aluminum, not stamped out, but machined.
Name:	141control system parts.jpg
ID:	38858   Click image for larger version
Name:	143 install balls in collective and elevator arms.jpg
ID:	38859   Click image for larger version
Name:	144install long balls in X arm.jpg
ID:	38860   Click image for larger version
Name:	146aileron bellcranks L and R.jpg
Chris D. Bergen
Old 02-16-2008, 08:22 PM   #37 (permalink)
All bellcranks rotate on bearings, and you can set the tension on them to eliminate any slop in your controls.
The aileron bellcranks are done by tightening the through bolt enough to remove any play, but still allow free spinning, then tightening the jamnut to the popsicle stick.
Name:	148install bearings in arms.jpg
ID:	38862   Click image for larger version
Name:	151set tension on aileron bellcrank.jpg
Chris D. Bergen
Old 02-16-2008, 08:24 PM   #38 (permalink)
The collective bellcranks rotate with the lower collective axle.
Name:	153install trip bellcrank.jpg
ID:	38864   Click image for larger version
Name:	154instsll single bellcrank.jpg
Chris D. Bergen
Old 02-17-2008, 10:29 AM   #39 (permalink)
Collective arms (Popsickle sticks) go on next, these strictly control collective movement, nothing else.
Then the elevator "X" arm is installed at the pivot point for the Popsickle sticks. Again setting the tension on the bearings for slop free, free spinning movement.
Name:	159install right popsicle.jpg
ID:	38915   Click image for larger version
Name:	162install X arm.jpg
ID:	38916   Click image for larger version
Name:	163install X arm.jpg
ID:	38917   Click image for larger version
Name:	164free spinning X arm.jpg
Chris D. Bergen
Old 02-17-2008, 10:36 AM   #40 (permalink)
Aileron servo mounting is next, This sits in between the Popsickle sticks and moves up and down WITH the popsickle sticks, but there is NO aileron INPUT with collective movement.
Instead of loctite, use a drop of CA on the screws securing the mount to the popsickle sticks. The mount is made from G10, which is porous. Loctite requires the ABSENCE of air to cure, so will not setup properly in G10.
Name:	165aileron servo mount.jpg
ID:	38920   Click image for larger version
Name:	170install ail servo assy in popsicle sticks.jpg
ID:	38921   Click image for larger version
Name:	171drop of CA on ail screws.jpg
Chris D. Bergen
