Old 01-20-2013, 04:14 PM   #81 (permalink)
Best 45 bucks I ever spent... Completely gone now, in a video mrmel said to turn it off after a couple of flights, is that still the case?
Man I can't wait to get my other 2 packs... Only 2 flights just isn't enough
michael88997 is offline        Reply With Quote Quick reply to this message
Old 01-20-2013, 05:21 PM   #82 (permalink)
yes turn them off. once it flys good. you'll want to re optimize if you change the agility.
Greg
MSH USA Heli Flight Team
Mikado V Team
Lynx
el guapo is offline        Reply With Quote Quick reply to this message
Old 01-20-2013, 05:57 PM   #83 (permalink)
Ok so does that sensor you linked earlier work good with the vbar?
Old 01-20-2013, 07:52 PM   #84 (permalink)
it is the only one that works with a castle ESC. and yes it works with VBAR. mini vabr will require an adapter cable.
with a mini vbar you will need to make a patch cable to power the HW RPM sensor. the sensor port on the min doesn't have 5V on the power pin for the sensor. strange but true. witt the fullsize vbar, you plug the sensor into the VBAR and then solder two wires to the motor leads and you are ready to go. MR mell has videos.
Greg
Mikado V Team
Lynx
Old 01-20-2013, 09:03 PM   #85 (permalink)
so i checked the log and i have alot of antenna switched messages... what does that mean? im using 2 sat rx one on each side of the heli
Old 01-20-2013, 09:08 PM   #86 (permalink)
Default It's official!!!!
Use some shoo goo to secure the sat wires in their plugs and the plugs into the vbar unit.
maarset is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:42 PM   #87 (permalink)
you guys are single arent you?
mikado logo 500se edge mains,micro beastx, ds 610s and bls251 natch
Outrage v50 n2 ys56, bx7200 beastx, spektrum servos all around
align 450 dfc bx7200 beastx
blade nano - stock 'cept for tail boom
ed211 is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 05:01 PM   #88 (permalink)
I have a girlfriend, but she knows the helis are here to stay
Old 01-25-2013, 06:47 PM   #89 (permalink)
So question on the sensor, can I hook signal up to rx a, and have power in rx b? I have my bec on rx c
Old 01-25-2013, 09:08 PM   #90 (permalink)
I went with what this guy did.
http://www.66pacific.com/vbar_governor.aspx
With a BEC and mini vbar you will have to use a Y connector so the BEC and one of the servos shares the same port.
Old 01-25-2013, 09:18 PM   #91 (permalink)
ok so i got the sensor all hooked up... its weird the sensor is backwards from all the other plugs...
a couple of questions, i have soft start in my cc program but it seems to start pretty hard... i noticed the governor act never came on.. i did see current and requested moving...
how do yall start up the heli to not get huge amp spikes, is it best to put it into TH and move the stick above half so the gov is enabled and does ramp limit?
oh and i found out why i was getting soo many rx errors on that log, i have it set to 11ms instead of 22ms
Old 01-26-2013, 01:24 AM   #92 (permalink)
I use the vbar softstart. And the castle soft start
I dont use the castle bailout. I only us the vbar bail out. Then end points are just 100 by 100.
Greg
Mikado V Team
Lynx
Old 01-26-2013, 08:26 AM   #93 (permalink)
So you have castle set at soft startup? Mines at medium now... And you don't have a curve to startup but just at 100 flat? What about the light in the program.. I just want to make sure it's working before I go fly
Old 01-26-2013, 09:26 AM   #94 (permalink)
ok so i got the gov light to come on this morning... i ran it without blades and it was showing my requested as 447 and current 1800... is that normal for without blades?
my only confusion on it is im running the mikado scorpion 4025 1100 hkIII and readyheli says its 8 pole but the normal 4025-1100 is 10 pole
Old 01-26-2013, 10:49 AM   #95 (permalink)
They are different motors. So put 4 in pole count in tab 2 gov settings.
Did you do gear ratio correct in tab 2 gov?
Did you watch MeMel gov videos?
Old 01-26-2013, 11:11 AM   #96 (permalink)
Yes I did, I put in 9.5625 because I'm using a 16t pinion
Old 01-26-2013, 01:10 PM   #97 (permalink)
the number you need to enter for "sensor configuration" is half the pole count. everybody gets that one wrong the first time.
the pole count is the number of magnets.
Greg
Mikado V Team
Lynx
Old 01-26-2013, 01:13 PM   #98 (permalink)
I did put 4 in and according to readyheli the pole count is 8.... Any other reason they would be different?
Old 01-26-2013, 01:28 PM   #99 (permalink)
don't request 447rpm. try 2300rpm.
Vbar has a minimum throttle parameter. its what it goes to if the gov sensor fails. you don't want the motor to turn off. but for what ever reason, its not accessible from the software in electric mode.. anyway. i access that thru my potable control panel. its a mess. but the pay off is totally worth it. i think the default is 70%.
so don't request 447rpm. try 2300rpm. 447 is bellow the min, especially with out blades.
Greg
Mikado V Team
Lynx
Old 01-26-2013, 01:35 PM   #100 (permalink)
Well I had max Headspeed set to 2300, I had my normal throttle curve set to 0 at low then 60% flat line, when I brought the stick up to Max in normal mode it is 60% and the program is showing requested that low, the actual seems right but idk why the program is showing requested only in the 400's... How long does the soft start take to disengage?
