Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 08-27-2014, 06:56 PM   #1 (permalink)
Default Problems after Servo Rebuild
I have replaced the sevo gears many times without any problems. But this time have a swash plate levelling problem.
After replacing the gears on all three servos. Tested them with the Turnigy Servo Tester , to make sure they were running smoothly and cycling OK.
Fitted them to the heli and used the Turnegy tester to set the swash arms at mid point and level the swash plate..
In setup 'G' the swash was level and did not require any adjustment.
However when I go back into flight mode, both rear servo arms are up about 10 degrees , tilting the swash plate down at the front. All controls work smoothly and correctly, but with the swash tilted .
The DX8 setting are unchanged with pitch curve 0-100 linear.
Phoenix Sim.,mcpx..blade 130x..blade 450 3d..blade 450X .. Trex 550 E DCF/mini Vbar
ingk is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 07:16 PM   #2 (permalink)
In step G you select a servo by moving the rudder stick and a light will come on. You then move the elevator stick up or down to make that horn as level as you can. Repeat for each servo. Here is the key part...you MUST exit to the next step With one of the servo's selected and its light on. It does not matter which servo is selected. That will ensure your settings are saved.
jhan1 is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 08:04 PM   #3 (permalink)
If you crashed make sure your Elevator control lever did not slip a notch.
Rotarywing is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 11:50 PM   #4 (permalink)
Thanks.. jhan1 .. problem solved. This is not mentioned in the Spectrum handbook.!!
Because the swash was already level when I went into 'G', I missed this important step.
Old 09-07-2014, 09:46 PM   #5 (permalink)
Is this normal that the servos would need to be adjusted independently after replacement?
Just curious as I have 2 rear servos that i'm changing out this week, but I haven't made any adjustments to my AR7200 from factory settings.
In the Hangar: Blade MCPx BL - 130x - 450x v1 - 450x v2
arias51 is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 07:21 AM   #6 (permalink)
ANY mechanical adjustments made to your servos, especially replacements, will require you to go through your AR7200 settings.
450X V2, mCPX V2, 120 SR, DX6i TX, icharger 106b & Junsi P350 Watt DC, Hyperion & Glacier Batt's, EP Buddy Safe 40A ParaBoard, RC Logger Digital Pitch Gauge, Maglev Blade Balancer, Quantum LV Alarm & Voltage Tester, T3chDad RC Flight Log Android App
KySky is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 08:37 AM   #7 (permalink)
OK, this will be my 1st attempt at entering/adjusting the beastx configuration. I watched some of the vids on the menu param 'G' setup. Looks fairly simple.
