Old 01-07-2014, 05:15 AM   #21 (permalink)
I was really looking forward to a Mini Silverline with DMSS satellite support but right now, I'd be happy with a place to order a 480 XXtreme.
Superstition Hobbies/Mikado VTeam!!
BigIreland is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 05:35 AM   #22 (permalink)
A Mikado 450 running 360blades and 6s
Sent from my Galaxy far far away....
Align 700DFC, Logo 600SX,Goblin 500,Trex 500DFC, Gaui X3 Flying MODE1 with Spektrum DX7S, VBAR,FUBAR,SK540
andione1983 is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 07:21 AM   #23 (permalink)
Originally Posted by helinutz View Post
+1 on the iPad app
Looking forward to seeing the plastic frames for the 700
Upgraded / better mounting options for the 700 and 800 canopies.
720 blades
Price drops across the range
+1 on all the above...
We don't stop playing because we grow old; We grow old because we stop playing!
LOGO700(2) - LOGO690SX - 700XXTREME - GOBLIN380 KSE - VBARCTRL
galensk is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 09:10 AM   #24 (permalink)
Plastic frame 700, or smaller sized and lighter carbon/alu
iOS software a must
Vbar 6.0 with improvements for speed flying (clic an option like small heli?), sub trim for rudder, that the soft knows A and B tail stop gain as right and left depending on the previous setup steps, same as it knows piro compensation on it's own. A crazy thought? Telemetry out from the FBL unit would be a first and some parameters would be very useful in realtime.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 09:12 AM   #25 (permalink)
Originally Posted by Jockpants View Post
Not so sure about an internal WiFi tranceiver in a fbl unit. Both standard WiFi and current RC Transmitters operate at 2.4 GHz. With a transmitting device hoping channels to find an access point so close to the receivers on the model...
EDIT:
Strike that, Bluetooth operates at the same frequency iirc so prolly not that big a deal in reality.
It's. Not an issue at all. The 2.4Ghz band has many "channels". It's why thousands of guys can fly at IRCHA at the same time.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 09:17 AM   #26 (permalink)
Logo parts
adamo is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 09:35 AM   #27 (permalink)
You don't want multiple 2.4GHz signals originating from the same point source since interference could result.
This is one reason that the BT module for the Kosmik is both very low signal strength and able to be easily dissabled. I only kept my module connected to configure my Kosmik and then I removed it. When Skookum releases their BT module it will also be a removable item that will not be connected typically.
I prefer a USB port or a small plugin field monitor for making FBL changes.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 10:38 AM   #28 (permalink)
It's really really not an issue. Another example is telemetry.
RF rejection has come a long ways.
Anyway if you're worried the wifi can have a switch so it's only enabled when you use it on the ground. "Problem" solved.
Old 01-07-2014, 10:51 AM   #29 (permalink)
My thought is that it is best handled by an external module that you can leave on or remove if you like. That way you don't increase the price of the standard controller and let those that want to pay for this feature pay for it separately. They would also be more likely to get return on their investment faster if this feature could be added on to existing controllers vs. a much slower adoption if it required replacing your controller.
Mark
Old 01-07-2014, 12:17 PM   #30 (permalink)
better capacitors in the Vbar, that is friendly with the Spektrum users
Team SAB, Team Pulse and Sponsored by Rotorquest.
DAhmad is offline        Reply With Quote Quick reply to this message
Old 01-07-2014, 08:59 PM   #31 (permalink)
Not to beat this to death, but it's dirt cheap. And these days there is way more competition in the FBL space. The designer gets to pick the features to try and differentiate themselves. I think integrating the $1 wireless IC into the unit is a way to do that. And I predict we will see that soon with other vendors anyway. The old antiquated idea of selling a $130 custom programmer just isn't attractive when we all have smart phones these days. Requiring the user to buy bluetooth modules for every heli is a PITA. Sure you can just buy one and plug it in to each heli as you fly it. But having a full level of integration would be a very attractive feature to a user trying to decide between 2 good systems.
+1. It's not so much a cap issue as it is a crappy undersized LDO driving the 3.3V bus which supplies both the sats and uP for vBar. If you use high current servos with spek sats, I strongly suggest you use an external power bus with vBar as it's very easy to disturb the 3.3V bus and get brown outs.
But I sure wish Spektrum would get with the times and release an RX with a serial bus output. I'd rather buy a full RX that properly switches receivers and handles dropped frames. Plus then we get native support for telemetry.
Old 01-08-2014, 12:38 AM   #32 (permalink)
Default Re: What would you like to see from mikado in 2014?
I am using a Bluetooth transceiver on my mini vbar connected permanently allowing to test how the governor works or allowing to change parameters in no time and have never had any interference issue with the dsmx satellites.
Enviado desde mi Galaxy Nexus usando Tapatalk 2
Soxos Strike 7.1
Minicopter Diabolo 700 UL and 550
Mikado Logo 600SX
Gaui X3
Arag_ is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 02:21 AM   #33 (permalink)
Inflight tuning would be a welcome feature on the Vbar. As in; assigning a parameter (such as tail gain) to a slider or dial channel output on your Tx, then use it to adjust that assigned parameter.
The Spartan Vortex has this 'Remote control' feature as its called and it is very effective. You could argue the optimisers do it for you but it would be nice for the user to define what parameters they want rather than the optimiser.
JR Forza 450 | Align Trex 550 V1 | Henseleit TDF | Henseleit TDSF
Varelco is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 03:00 AM   #34 (permalink)
Hi,
a Apple App would be state of the art.
And Kontronik shows that it is possible.
regards
Stefan
sme_d is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 07:50 AM   #35 (permalink)
I'd love to see something like this, especially for style, since it is such a nebulous setting.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 01-10-2014, 08:30 AM   #36 (permalink)
Bavarion Demon has same in flight tuning option, makes tuning in pretty quick.
Just work your way through the parameters you want to change and you'll dialed in in a few flights.
Still prefer my V-Bar BT with my net/notebook though.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 01:27 AM   #37 (permalink)
1. Auto recovery/rescue mode -- I won't buy another FBL unit without this
2. Bluetooth built into the next VBAR hardware
3. No more lite and pro software -- full features out of the box (annual paid upgrades are OK)
4. Fixed compatibility for MKS servos (I'm stuck at 5.25 because 5.34 doesn't work)
dswitkin is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 01:30 AM   #38 (permalink)
US dealer/dealers ....
Dennis Everett is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 11:30 AM   #39 (permalink)
Whats the problem because most MKS servos seem to work fine?
GAUI X5 with Eznov Neuron and T10J
DannyvG is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 11:54 AM   #40 (permalink)
Default What would you like to see from mikado in 2014?
+1, after that, maybe a Logo 550 or 600 xxtreme
DiceK is offline        Reply With Quote Quick reply to this message
