Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
11-06-2010, 06:43 AM | #321 (permalink) |
I just took my 3G apart yesterday to do the mod. It is a V2 labeled unit and it did not have the pins epoxied. I also took care of the pins while I was at it. Hopefully I will get a chance to fly it maybe Tuesday due to work.
11-06-2010, 04:54 PM | #322 (permalink) | |
Ben Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251 DX8, RF6 |
11-06-2010, 04:58 PM | #323 (permalink) |
I used the ultra black myself and I am extremely pleased. I might have used more than recommended, but not enough to make a mess or touch the board. Definetely cut off the tabs if you ask me.
Blade 350QX - BNF with GPS for $399 tons of fun. T-rex 700E V-BAR V2-B Tail, DFC Head system, Outrage 9188 tail, 610's, Quantum 4530-500, slant gear. Scorpion Commander V 130A with SBEC, Running V-Bar gov - the best governor combo ever. Maiden Flight: 6/5/2010 - Still on stock frame & blades as of Dec 2013. |
11-06-2010, 05:23 PM | #324 (permalink) |
Thanks, will use that then
11-07-2010, 09:07 PM | #325 (permalink) |
All I can say is freaking WOW. LEON you are the man!!!!
What an awesome mod. I used just regular goop, linked all 3 sensors together (did not load it up, just enough for them to all touch). I also put some on the bottom as well and cut the tabs on the case. I used 2 layers of 3m tape and strapped it down tight and used all the settings that LEON displayed. Words can't describe how much of a difference this is. No bobble, no wag. Just 100% locked in feeling. Sorry no vid, just went out and tore up 3 tanks before it got dark. Thanks Leon!
-you can't FIX stupid- AMA# 935732 |
11-07-2010, 09:55 PM | #326 (permalink) |
ok need to do the mod but I see no sticker on my unit so I'm guessing it has no glue on the pins what do I use to glue the pins with?
11-07-2010, 09:59 PM | #327 (permalink) |
I never glued the pins in mine, but from factory I think it is non metallic 5 or 10 minute epoxy would work.
Representing: Team A Main , Mikado V-Team, Team Xpert, Team Synergy, Team KDE, Team Cool Power, Team Hatori, Team Protek, Eco Power Lipos, TruGlow, XFC 2006/7/8/11 |
11-07-2010, 10:00 PM | #328 (permalink) | |
11-07-2010, 10:14 PM | #329 (permalink) |
Leon you are on it thanks should I fly with the settings I use now or should I change the gains right off the bat I do not have the usb unit yet, was unsure if I was going to keep the 3g unit or not, I have been flying with a 520 on the tail and it has been flying very well. Will the mod benefit the cyclic as well as the tail?
11-08-2010, 04:48 AM | #330 (permalink) |
@Leon Luke
...first I have to thank you for the publication of this great mod. My heli now flies like one in my "phoenix" flight simulator But there are still some questions to you. You set the EXP Level Setting for Nick and Roll to 0 - are there any settings for EXP you have programmed into your transmitter instead? What are the correct settings on the 3G control unit for aileron and elevator that fit to your recommendations? Thanks Arndt111 |
11-08-2010, 09:46 AM | #331 (permalink) | |
In normal mode 100DR 30EXP In Idle up mode 100DR 20EXP Please see the settings for ail and elv on first post of thread.
11-08-2010, 10:51 AM | #332 (permalink) |
...thank you for the info about the EXP settings
But for my other question I think, you missed my point - I meant - what are your settings at these two controllers of the 3G control unit. Thanks Arndt111
T-REX 550E 3G V2.1 * Creata 400 + FlyCamOne eco * Dragonfly 4 WK-2801 Pro Ultramat 18 |
11-08-2010, 11:41 AM | #333 (permalink) |
@Leon Luke
Everything is fine. First i had not seen the information about nick and roll gain. Thanks for the support Arndt111
11-08-2010, 04:11 PM | #334 (permalink) | |
11-08-2010, 04:27 PM | #335 (permalink) |
I tried to keep the gains on the control box at 12 o clock, I seem to recall that with the software selected to large heli, I monitored the gain output, in the 3g display setting to be around 72-74% before I changed anything in the software. I normally adjust the pots to have identical gain on aileron and elevator like 72% and then leave it alone. Then make any adjustments in the software.
11-08-2010, 08:00 PM | #336 (permalink) |
Hey leon,have you changed anything from your settings posted in the photos?? especially for 700n?? Thanks
11-08-2010, 11:16 PM | #337 (permalink) |
The 700 and 600 have exactly the same program and I have not changed anything as I like them the way they are, I suppose I could try to increase the gains.
11-09-2010, 10:21 PM | #338 (permalink) |
should i open up a new v2.1 unit?
Thanks for everyone who has provided a wealth of info in this thread. I just got a new 3G system, stamped 2.1v. how can i find out, without opening the sensor unit, that if Align has modified the unit or not? do you guys think i should go ahead and try opening it...or leave it alone...any advise would be appriciated. thanks in advance.
if wife ever saw my credit card bill....... |
11-09-2010, 10:54 PM | #339 (permalink) | |
11-09-2010, 10:54 PM | #340 (permalink) |
Don't be afraid to open the case to have a look, it's very easy to do, just take out the 4 screws & hinge the top open using the little warranty sticker as the hinge, that way if it's already modded you won't void the warranty by breaking the sticker
Trex 500 ESP 3G - DS510M - Jive 80+HV - BLS251 - I2 + KDE + Edge Trex 250 - GY520 - s9257 - ds410M - Medusa 5V/2A BEC - Scorpion 3900/15T 4G6 - HP08s - XP-07A MIA 4#3B - HP06s - XP-07A |
