Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Ufly
Ufly Walkera Ufly Helicopter Support
Old 03-30-2011, 07:45 AM   #1 (permalink)
Default Faulty uFlyS
I just received my uflys today and am having some problems..
When I move the AILE (left right on right stick for mode 2) to the left it does nothing but when I move it right it works.. I even took the connector off the servo so it was just the bare gear and only one direction works (trim doesn't help either)..
Also with the rudder moving it to the left and it moves the rudder but letting go of the stick and it doesn't reset back to the middle (the servo that is not the stick on the transmitter) over to the right and let go and it pops back to the middle fine..
Have I got two faulty servos (the third one seems to work fine)..
Apart from that the blades were way too loose and one paddle was flat and the other was set up on an angle (45d)..
joele is offline        Reply With Quote Quick reply to this message
Old 03-30-2011, 01:21 PM   #2 (permalink)
there is nothing wrong with the rudder servo it does that because of the HH gyro...if you switch the rx from WK to ADJ the rudder servo will center when you release the rudder stick...however as far as the aileron servo you might have problem with that one for sure...try plugging in a different servo to the aileron channel to figure out for sure if it is the servo that is bad or something else...you might need to send it back for a replacement depending on where you got it from..
magicmarty is offline        Reply With Quote Quick reply to this message
Old 03-31-2011, 02:02 AM   #3 (permalink)
OK false alarm, once I unplugged everything and replugged it all back in, it started working..
