Like Tree4Likes
  • 1 Post By Raz0rSh4rp
  • 1 Post By jiminator
  • 1 Post By Eury
  • 1 Post By rcyoda
Old 04-07-2013, 03:38 PM   #1 (permalink)
Default OS 105 Mounting Exhaust
Ok everyone, I really am hoping someone can help with this. I have installed an OS 105 in my 700 and am installing the pipe right now. The pip that I am installing is the OS 105 power boost. The thing that I am running into is installing the exhaust that bolt the pipe to the engine. Is the engine suppose to be threaded in the block? If so are you suppose to run the bolts through the pipe side or on the engine side? It feels like I'm going to strip the bolt holes in the engine. Any help or advice would be appreciated.
Trex_700N is offline        Reply With Quote Quick reply to this message
Old 04-07-2013, 05:48 PM   #2 (permalink)
The bolts go through the pipe and thread into the engine on the 1.05.
dchekas is offline        Reply With Quote Quick reply to this message
Old 10-23-2018, 07:34 AM   #3 (permalink)
So it is supposed to use short bolts? (as you cannot use long ones because they will not bend around the pipe body )
rcyoda is offline        Reply With Quote Quick reply to this message
Old 10-23-2018, 04:09 PM   #4 (permalink)
Drill the threads out of your crankcase and use the bolts from the .91. Otherwise you will break the crankcase in a crash.
Eury likes this.
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 10-23-2018, 07:41 PM   #5 (permalink)
As others have said, the bolts go through the pipe and thread into the 1.05 case. This is backwards to most other OS engines.
ID:	759081   Click image for larger version
ID:	759082   Click image for larger version
"Well, nothing bad can happen now."
wjvail is offline        Reply With Quote Quick reply to this message
Old 10-23-2018, 10:10 PM   #6 (permalink)
Thanks guys. I fixed it with short bolts, as on first two photos. I would rather prefer not to drill-out the threads.
Old 10-24-2018, 05:06 AM   #7 (permalink)
This is the voice of experience. You may not want to go this way, but when you crash and have to replace a crankcase, you'll regret not doing it.
Eury is offline        Reply With Quote Quick reply to this message
Old 10-24-2018, 11:03 AM   #8 (permalink)
I've ripped a crankcase apart on an OS .55. It has bolts that go thru the engine and thread into the pipe. Pretty bad crash though I could see with a more minor crash this could be an issue with the 1.05, just have to crash on the non-pipe side
Eury likes this.
jiminator is offline        Reply With Quote Quick reply to this message
Old 10-25-2018, 04:09 AM   #9 (permalink)
So with long bolts through, secured with nuts, it is more likely that the bolts will break?
Old 10-25-2018, 08:04 AM   #10 (permalink)
In my experience in a crash that hits that side, the pipe will bend and the crankcase will break if you have it threaded into the case. With bolts only the pipe bends.
Raz0rSh4rp likes this.
Old 10-25-2018, 09:18 AM   #11 (permalink)
Not only are you likely to crack the pipe mounting face, it is even more likely that a hard crash on the pipe side will actually pull the threads out of the crank case and you wont be able to get a good seal or even mount a pipe at all.
Old 10-27-2018, 04:12 AM   #12 (permalink)
I finally drilled-out the threads. Thanks for your advises guys.
Old 10-29-2018, 11:14 AM   #13 (permalink)
No prob, long live your 1.05
