Old 02-08-2015, 10:36 PM   #41 (permalink)
Wow, they were on sale for $1 each!
I ordered a bunch in yellow and red! Shouldn't ever need a tail fin again for this heli!
SAB Goblin 600, Logo 480Xxtreme, Gaui X3, Compass 6HVU, Atom 500
Jmann841 is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 04:55 AM   #42 (permalink)
Default Elevator servo for 480
@ KX: MKS elevator servo does not have the servo arm centered within the 480 frame if you install it to the frame as is. You will need to use shims, I used 3 x 1.2mm carbon shims I made myself to "move" the servo more into the frame so that the servo arm aligns with the swashplate elevator ball link.
It was a very obvious misalignment that perhaps the Savox mini servos do not have, but with the MKS, if you install it as the manual suggests it will be 4mm off the center axis of the frame.
Spiros
2 x 7HV Ultimate (MKS HBL980/950, HJ120+, Scorpion 4035 1.32mm YY rewound, Pyro 700-52 1.28mm YY rewound), 1 x 7HV full kit for spares, 1 x Logo xxtreme 480 YGE90LV all with BD3SX
sk8n is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 05:01 AM   #43 (permalink)
The Airetic
Thanks, Spiros. Good lookin' out.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 05:49 AM   #44 (permalink)
Unfortunately the Savox servos have the exact same problem. There are no standoffs for the elevator servo... It's just part of the design. The vbar will compensate for the geometry issue.
Steve_JR is offline        Reply With Quote Quick reply to this message
Old 02-09-2015, 06:31 AM   #45 (permalink)
Default MKS and JR elevator servos misalignment
All though flybarless unit may compensate, I see this as a major head geometry pitfall that is best to be addressed during build up, as the elevator link rod from servo arm to swashplate elevator link ball is far from being vertical and parallel to the main shaft.
Honestly, I was very surprised for Mikado not being able to catch this in the manual and provide the correct servo carbon plate to bring the servo spline to the center of the heli axis of symmetry, especially when they sell the MKS servos as part of the combo.
Carbon shim plate coming with the MKS tail servo would do, but you would need 3 of them and it would be quite expensive to order them through MKS.
Old 02-09-2015, 02:09 PM   #46 (permalink)
It's frustrating and annoying when u see it on the heli... However I'm convinced it doesn't make any practical difference in the air.
Old 02-22-2015, 06:59 AM   #47 (permalink)
The Airetic
Well, I am nearly done with the 480. trying to get the wiring all buttoned up.
I had a quick question though. Is anyone running Rail 80.6 tail blades with the stock Edge mains? They seem like they will fit. I intend to run fairly low headspeeds and think this may be good on the tail.
Old 02-22-2015, 08:06 AM   #48 (permalink)
I had some on mine until a crash took them out. I was very happy with them.
Lynx Team Test Pilot
Heli's :, Gaui X3, Logo 480,
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 08:09 AM   #49 (permalink)
The Airetic
Perfect! Thanks!
Old 02-22-2015, 09:51 AM   #50 (permalink)
That's what I am running and they hold very well at low hs.
logo 600sx, 480, vcontrol ..mcpsbl
Dsss is offline        Reply With Quote Quick reply to this message
Old 02-22-2015, 11:06 AM   #51 (permalink)
They should work great, however, even the stock edge 72's are excellent at low HS.
The Tail on the 480 is outstanding, it's the best of all my machines. Even at 2100 or so RPM i can do tail down funnels and never loose the tail with the stock 72's.
Old 02-22-2015, 11:11 AM   #52 (permalink)
The Airetic
My kit came with Fun Key 76mm tail blades. I might use them for the maiden and test spool ups, but I would like to use the Rails most of the time. I had them laying around, might as well use them.
Old 02-22-2015, 11:25 AM   #53 (permalink)
Very nice! The rails will do well
Old 03-11-2015, 11:58 AM   #54 (permalink)
The Airetic
It's ALIVE!!!
Finally finished putting this thing together and got in a test hover in the back yard. Seems pretty solid so far. No major surprises on the maiden pack. Hopefully I will get a chance to really fly it tomorrow.
Old 03-11-2015, 12:07 PM   #55 (permalink)
You going to love it
waheed1998 is offline        Reply With Quote Quick reply to this message
Old 03-11-2015, 05:42 PM   #56 (permalink)
Looking good KX!
What is the AUW for that skinny beauty?
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is online now        Reply With Quote Quick reply to this message
Old 03-13-2015, 08:45 PM   #57 (permalink)
The Airetic
Thanks man! I got 6 flights on it yesterday! This heli is a great flier. I was flying in 15mph wind and it was right at home. It does get pushed around some because it is light, but it was still very enjoyable. It was really too windy to do a very good job at tuning. I will have to wait for a calmer day for that.
I can forsee the possibility that this logo 480 could become my favorite heli. After I get it dialed in a bit. That said, I am having some canopy fit issues. Once I get that sorted, and I will because it is minor, I'm probably going to be flying it a lot!
I don't know exactly what it weighs. My little scale only goes up to 2kg. Maybe I can weigh the heli and battery separately. I'll let you know. I think it's a little over 2kg.
I also flew my warp today! I'm glad I ended up not selling it. I did just put an ikon in it this morning though. The warp is a damn fine heli.
Old 03-14-2015, 06:45 AM   #58 (permalink)
Hey Rob!
Nice to know you're enjoying your 480
So it seems that to have a nice wind-resistance on windier days, it would need heavier packs?
Maybe that's why smackier pilots stick a 4000 in it.
And yeah, the Warp is a keeper, haven't seen a better 360 heli yet. Changed both belts on mine this week, after two crashes and a few mishaps, and almost 3000 flights. It's a heli that has that kind of smoothness to go along with a mikado, oxy, all smooth machines.
happy flying
T500 AP
Old 03-14-2015, 07:14 AM   #59 (permalink)
My canopy was tricky at first, I found that hanging the front of the heli over an edge while installing the canopy realy helped. That way you can flip the canopy from nose down verticle to horizontal as it fits over the body. Most people get a stress crack somewhere in the middle as you have to bend it out to get it on, just beef up that spot from the inside with a layer or two or epoxy and fabric and that probelm goes away.
MS60 is offline        Reply With Quote Quick reply to this message
Old 03-14-2015, 07:35 AM   #60 (permalink)
Very nice KX! I had some issues with the canopy at first but found you how to align the bottom first then bring the top side on. Make sure the underside lines up with the skids properly then fold it back to the top and it should go on nice and smooth. Took me a few tries to figure it out but now it goes on easy
