Old 11-26-2015, 11:35 PM   #1 (permalink)
Default 690sx - Adding weights for proper CG.
Hi Guys,
With my setup, stock motor, Edge 160 esc and 2x6s 5000mAh packs the 690sx is nose heavy.
I pushed the packs all the way back and the nose drops fast.
Where i have to put the weights, on the tail fin?
Cheers!
|Michalis|
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 11-27-2015, 06:57 AM   #2 (permalink)
Ok, i got some lead weights and added 58g on the tail fin, now it balances fine.
|Michalis|
Old 11-27-2015, 08:40 AM   #3 (permalink)
With the light weight of the 690, it was recommended by Ron at Mikado to drop down to a 120a ESC and 4500mah packs.
I looked at the logs on my 160 and the most amps I have pulled is 127, so a 120 with the lighter weight ought to do the trick. I haven't had a chance to test fly the 120 yet, but will do so when the weather clears.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 01:02 PM   #4 (permalink)
After the CG issue i thought exactly the same combo of esc and packs as you mentioned it
On a side note; with an Edge 120A and 5000mAh packs it will balance ok.
|Michalis|
Old 11-27-2015, 02:51 PM   #5 (permalink)
A metal tail box e.g Lynx or Hawk helps a little bit
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 03:13 PM   #6 (permalink)
Lynx got metal tail box? I only knew about the Hawk one.
Cheers
|Michalis|
Old 11-27-2015, 04:41 PM   #7 (permalink)
Yeah, you overbuilt that one with the 160, just too much esc and batteries.
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 05:10 PM   #8 (permalink)
Cheers
http://www.world-of-heli.de/en/lynx/...-logo-600.html
Old 11-27-2015, 05:45 PM   #9 (permalink)
This is going to be my setup, so good to know that it will be fine, i have 5000mah packs which im using with my other heli, the the 60c eco power i am alittle worried about the weight of the 2 pack, the pulse is just 45c so its fine, but maybe in the future i will get some 4500 or 4400... Im just looking for a longer flight time....thanks
doubletap is offline        Reply With Quote Quick reply to this message
Old 11-28-2015, 02:49 AM   #10 (permalink)
I can't wait to maiden this heli!
I am curious to see my amp draws from the Vbc logs.
|Michalis|
Old 11-29-2015, 09:51 AM   #11 (permalink)
No need to add useless weight. Check out my thread in the other forum regarding cutting out the rear bulkhead from the battery compartment.
I'm flying with 5000mah packs, use a YGE160 w/heat sink, and have perfect balance with no extra weights on the tail.
I've had two crashes so far since removing the bulkhead and my frames are still fine. That was the one worry I had about removing that material....whether it would weaken the frames back there. Apparently not.
KevinB
KevinB is offline        Reply With Quote Quick reply to this message
Old 11-29-2015, 10:41 AM   #12 (permalink)
Hey Kevin,
Will check it out. Cheers!
|Michalis|
