Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > JS TZ-V2 Frenzy
JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion
Old 12-22-2011, 02:56 AM   #1 (permalink)
Default HEEEELP!! frenzy 50e headspeed
Hi, I just ordered a frenzy 50 e with scorpion 630kv 12s motor. How the heck am I gonna set up the headspeed???? On a calculator it says 3000 rpm, the heli would self destruct? How are you guys doing your setup?
Assuming:
40C battery
10 teeth pinion.
90 % efficiency
Result for calculation:
Estimated lowest voltage during flight: 41,40
Lowest RPM (due to voltage and efficiency) : 2630
(calculated for 100% throttle curve)
Hover RPM at beginning of flight: 3327
Hover RPM at middle of flight: 3064
Hover RPM at end of flight: 2957
Thanks,
Jerry
emberjelly is offline        Reply With Quote Quick reply to this message
Old 12-22-2011, 04:05 AM   #2 (permalink)
I used an RJX 93 tooth main gear on mine to get better ratio. Running on 8s by 2 4s 5000mah a 880kv motor with a head speed of 2200. You have to space out the mixer arms as it will hit the modified main gear at the extreme throws. also need the pinion as it helicut gears. Very happy with this. Can post photo if you like.
cheif is offline        Reply With Quote Quick reply to this message
Old 02-03-2012, 10:00 PM   #3 (permalink)
If you haven't purchased batteries you can look at dropping the cell count. I run my 6hv on 10s and it is great. Are you going to run a governer? You may need to play with the pinion tooth count too. The pinion is the easiest way to manipulate the headspeed.
Logo 500 mini vbar
yowser is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 12:35 AM   #4 (permalink)
I eventually just went with an ultra low KV 700 size motor. a scorpion 4045 HKIII 330 It was mega expensive, but it should give plenty of power.
Cheers,
Jerry
Old 02-21-2012, 07:42 PM   #5 (permalink)
Hi my setup is stuck main gear and pinion. Motor scorpion 4025 890kv ESC CC 75amp batt 5000mah 8s 40c. In normal mode 2000 rpm. In --IDL 1/ 2100. ---IDL 2/ 2200. running a high governor. Gain set at 40. Throttle curve 42.7% 46.9% 50.5%. I am getting about 8-10 mins flight time not too much 3D. LOVE MY FRENZY {:-) Here is my video hope it help.
Frenzy Built HD.mp4 (19 min 42 sec)
blackbeard is offline        Reply With Quote Quick reply to this message
Old 02-23-2012, 03:42 AM   #6 (permalink)
HI,
Looks cool, just note you are trading off some performance and straining your ESC at that low %. 80% is the recommended minimum.
I will post a vid of mine. But my dog is sick at the moment and I can't go to the field
Old 02-23-2012, 02:12 PM   #7 (permalink)
Yes you are right. But i am not a hard 3Der. Ok up my setting abit up to 88.9% max.
Old 02-25-2012, 03:37 PM   #8 (permalink)
Cool. How did it go with the higher hs?
Old 02-27-2012, 08:31 PM   #9 (permalink)
It do not go well 2 much hs blue the tail hub apart. Got it down without crashing it. Keeping the hs below 23. Hope your frend feeling better.
Old 02-28-2012, 10:53 PM   #10 (permalink)
woah that sucks man, sorry. nice job landing it though.
