Belt CP E-Sky Belt CP
Old 01-24-2009, 08:48 AM   #21 (permalink)
Jonny, it's totally rebuilt.
I did some test hovers in the garage last night. New servos are awesome. Just going to wait for a decent day outside to go out and fly.
"It was a controlled descent!"
T-Rex 600 GF, 600XL, Stock ESC, 11t, Align DS610's, s9251,GY601 gyro, AR6200, ZIPPY 6s1P FOREVER!
testpilot58d is offline        Reply With Quote Quick reply to this message
Old 01-24-2009, 09:16 AM   #22 (permalink)
Good to hear it's back up in the air again. She is a beautiful machine
Hope to hear a pogress report on it's first outdoor flight after the recovery
-Jonny
Spektrum DX7, Align Trex 250se, Align Trex 500cf, Align Trex 600n LE
Jonnyheli is offline        Reply With Quote Quick reply to this message
Old 01-24-2009, 12:45 PM   #23 (permalink)
hi jonny your parcel is ready to post monday
3 stock servos
1 stock gyro
1 telebee head lock gyro
2 flybar paddles carbon
1 1800 mar bat
1 stock tx transmitter
1 stock receiver
and your welcome to them ps thanks for trying to get me sorted but no joy
milo6 is offline        Reply With Quote Quick reply to this message
Old 01-24-2009, 01:25 PM   #24 (permalink)
Milo, where in the UK are you? Perhaps one of us is close enought o meet up and help out with the heli?
Jonny, if you don't need the rx/tx that milo is offering I could really do with them to get my belt up and running and then sold
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV
And a P51D plank......SSssssshhhhhhh!
BMFA & RCHA Member
[B][COLOR="Blue"]
psilo is offline        Reply With Quote Quick reply to this message
Old 01-24-2009, 02:06 PM   #25 (permalink)
3 stock servos
1 stock gyro
1 1800 mar bat
1 stock receiver
Holy crap! (Soz for swearing) That is a lot of stuff. Thanks soo much dude! Like Gerd said, where in the UK are you. There are a lot of us here from the UK, im sure someone lives quite close to you.
Gerd, of course you can have the TX/RX. You have helped me out loads (Giving me a batt and letting me borrow a gyro etc) To save Milo time and money. When I recieve the package, I will send you the TX and RX It's the least I can do.
Thanks again Milo. This will be very helpful to me and I should easily be able to get the old Belt cp up and running with all that stuff. I already have a stock TX and Rx that I will be selling with the belt cp. So giving it to Gerd will be of better use.
-Jonny
Old 01-24-2009, 02:30 PM   #26 (permalink)
hi im on the east coast mablethorpe nr skegness i think im going to sell up fedup pd of misrable headhurts no just joking spent to much money to give up im going to by a new motor /esc/receivers and hope that will sort it out can u guys recomend a good motor iv been looking at the scorpion 1s can u point me in the right direction please thanks
Old 01-24-2009, 02:36 PM   #27 (permalink)
Thought you were actually going give up then. Glad you are going to keep trying
Scorpion 45A commander V2 ESC.
Scorpion - 8 (I maybe 6)
AR6100 or AR6100e. (The AR6200 takes up to my voltage in my opinion. And they are DSM2 which means they have a very far signal, well with small heli's you don't go very far anway so why use one. Fair enough if it came with one though) The AR6100 is DSM which is a parkflyer. Cheaper, less power thursty and just right for 450 size helicopter.
Hope this helps.
-Jonny
Old 01-24-2009, 02:55 PM   #28 (permalink)
+1 but think the -6 would be overkill!!
Milo, I am about 50 or so miles from you down in Ely, Cambs. If you want to come down one weekend or evening I will gladly go over the heli with you and test with my known parts to find what is faulty before you go replacing everything. I even have a spare 45A scorpion 6s ESC that has not been used that I could sell you should you need/want it. PM me if you fancy coming down and sorting it and I will give you my contact details.
BMFA & RCHA Member
[B][COLOR="Blue"]
Old 01-24-2009, 05:04 PM   #29 (permalink)
Actually the AR6100s are also DSM2. The only Spektrum receiver I've seen that's still compatible with DSM1 (as used on the DX6) is the AR6000.
And the AR6100 has been tested out to 1.7 miles, which is hardly in the parkflyer category
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote Quick reply to this message
Old 01-24-2009, 07:09 PM   #30 (permalink)
Mika,
Yeah, that 6100 I'm sending Chad...I've had it WAY out there on the 600 (and that's even with a suspect antennae wire that I soldered back onto the main board.
The range on those little things is incredible.
Old 01-24-2009, 07:14 PM   #31 (permalink)
Oops ment the AR6000.
But the AR6100s are still better for small heli's. The AR6200 is too much. And if having brown outs or whatever they are called then an AR6100 wouldn't help the matter.
-Jonny
Old 01-24-2009, 11:23 PM   #32 (permalink)
Milo6
What your are describing sounds to me like you need to bind the rx to the receiver.
Have you bound it?
I just recently got a new rx and when I first pluggid it in it did exactly as yours does.
It flashed a few times then the light went out because it couldnt find the tx it was bound to.
Get your bind plug and plug it in where the battery slot is.
Then get you rx battery(if you have one) OR your esc and plug it into the throttle then plug your flight battery into the esc.
Now your rx should flash, turn on your TX whilst holding the the bind button on the back.
Once your light on the rx is solid you can turn it all off and disconnect your bind plug.
Power it all back up and it should work fine.
Hope this helps.
Darin
Nitro, I don't need no stinking Nitro!
Logo 500 Vbar
Trex 450 Pro Mini Vbar
mCPX
Real_Sparky is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 07:22 AM   #33 (permalink)
Originally Posted by Real_Sparky View Post
Milo6
Have you bound it?
Hope this helps.
Darin
I think he has tried re-binding a few times. But he could well be doing something wrong. Gerd lives quite near so if they could meet up Gerd would help Milo.
-Jonny
Old 01-25-2009, 12:01 PM   #34 (permalink)
I just thought of something! I just got one of those $15 AVCS gyros(like Gerd lent you Jonny) in the mail yesterday, as I was looking through the instructions, I remember it saying you must initialize with the gyro in AVCS mode(HH mode) My point being my heli won't initialize if the gyro wont if you are running an AVCS/HH gyro check this and then try to rebind. Just a thought.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious!
Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range!
Heli Yea! is offline        Reply With Quote Quick reply to this message
Old 01-25-2009, 12:28 PM   #35 (permalink)
hi guys tried all of the above it seems to have lost where is wase bound because on my tx screen it ses bound so dont no lost the plot whith this heli but to happen on my copterx as well same thing but both receiverse came of my old cp could have got the little front receivers mix up they was in my tool box could have got mix/mach modle mixed up but tryed all afternoon al i got was a headache
Old 01-25-2009, 01:38 PM   #36 (permalink)
Originally Posted by helihathnofury View Post
Jonny, I'd get yourself a Scorpion, or you could have my old stock Esky one. It just sits in a box in the shed. I have a few other stock bits too.....
Mike
Milo, did you send me a stock motor aswell as everything else? If not, Mike I would really appreciate if you could send me yours. That's if you really don't need it and don't mind giving it away or selling it for cheap? Sorry if I am being rude
-Jonny
Old 01-25-2009, 02:07 PM   #37 (permalink)
hi jonny yes therse a stock motor in the parcel ill post tomorow
Old 01-25-2009, 02:44 PM   #38 (permalink)
Ok, thaks a bunch!
-Jonny
Old 01-27-2009, 10:37 AM   #39 (permalink)
Hi Milo. I recieved all the stuff you sent to me in the post today. There was a lot of helpful stuff I needed in there and you have saved me a lot of money.
I have one question/favour. Your motor has big bullet connectors. Could you give me website that sells the other connctors that solder onto the ESc (Female connectors?)
Cheers.
Gerd, if you could PM me your address I will send you the TX and RX. Milo, Gerd needs the TX and RX more than me which is why I am sending them to him.
-Jonny
Old 01-31-2009, 04:23 AM   #40 (permalink)
hi guys back at work now heli still no go but got brock into last week large 60 inch tele computer/laptop stereo lether sofa watch gold chains they killed my german shepard and got in but they never took my helis just sorted out with police and insurance so im a bit p###st of so couldent go down and sort heli out sorry
