Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 10-10-2012, 09:09 AM   #1 (permalink)
Default Post your GAUI NX4 Setups
Since this Forum has been slow lately, I decided to post my setup while we are killing time waiting for the release. Please post your setups also!
4x Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
1x MKS DS8910A+ tail servo
O.S. 37
Hatori SAB-6RS-3D Tuned Muffler
Align RPM Sensor
PushGlo igniter
MSH Brain
Mavrikk Header Tank
2x Thunder Power 1900mAh 2-Cell/2S 7.4V G6 Pro Lite RX Lipo TP1900 ( not pictured )
2 x GAUI NX4 kits on pre-order - one for backup
Can't wait for November!
-GN
Citizen 106
Protos MAX V2 | Forza 700 | Goblin 570/500/380 | Gaui NX4 Nitro and Gasser | T-REX 600E PRO DFC | T-REX 550E V2 | Dominator 450L | Blade 130/180 x/cfx | JR XG14/XG11MV | Icon
GasNerd is offline        Reply With Quote Quick reply to this message
Old 10-10-2012, 08:06 PM   #2 (permalink)
Nice! Hey, I bought the same tail servo, but that is not an HV servo. You can't feed it straight 2S lipo voltage... I'm going with a LiFe 1400 unregulated pack with a step down for the tail.
My setup:
OS 37 / Hatori pipe
DS510 x 4 (cyclic and throttle)
MKS 8910A+ with step down to be safe on the tail
Full size silver vbar with 5.3 Pro
SwitchGlo pro
Align 500 Orange skids
Align 500 boom supports
Edge 425s and 72mm tails
QuickUK header tank
Align RPM sensor
Align starter
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 10-10-2012, 08:44 PM   #3 (permalink)
@caralmar
Ah yeah good point. I forgot about that.
I did order a Western Robotics Titan regulator for the tail ( should be here this week ) - hopefully that will work on the tail.
http://www.western-robotics.com/titan_STDR_hp.html
I got the Yellow Align starter that you suggested to me in another post that I also forgot to mention.
BTW: Is this the correct governor sensor ? Align Governor Sensor HE50H22
Citizen 106
Old 10-11-2012, 08:54 AM   #4 (permalink)
OS 37 / Hatori pipe
DS9660A+ x 4 (cyclic and throttle)
MKS 8910A+ on the tail
Brain
SwitchGlo pro
Stock Gaui Blades
Kbdd tails
Spektrum or Align backplate sensor
Quick UK Header tank
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote Quick reply to this message
Old 10-11-2012, 08:57 AM   #5 (permalink)
Originally Posted by Gawl View Post
OS 37 / Hatori pipe
Brain
SwitchGlo pro
Stock Gaui Blades
Kbdd tails
Gawl, what do you plan on using to power the electronics? Also, I think JC said that the motor is too small for a backplate sensor, so that's why I got the Align sensor with the magnets for the bell.
AMA #934662
Old 10-11-2012, 09:04 AM   #6 (permalink)
I think your right, I believe he will be at the Abilene event next weekend and I plan to ask him there. If not, I'll run the align sensor with magnets.
As for powering it all, will be off 2s unregulated life. I was going to do a step down for the tail but 6.6 should be fine.
Team Synergy
VP Racing Fuels
Team Scorpion
Old 10-11-2012, 09:09 AM   #7 (permalink)
Yeah, I just sent MKS an email asking them about this. I think 6.6 should be fine as well, but never hurts to get confirmation, especially on such a pricey mini servo. Are you going to get the kit with blades or just the barebones one? I'm thinking of just getting the barebones one and stick my Edge blades on there... I didn't much like the stock Gaui blades for my X5 when I had it.
AMA #934662
Old 10-11-2012, 09:36 AM   #8 (permalink)
I liked the Gaui blades for the x5 so going with kit and blades. I'll grab some edges at some point since I like to always keep a spare set of mains on hand for each heli. I'm positive that the 6.6 should be fine, hell I'm running my align throttle servo that's only rated for 6v on my N5c off 2s lipo at 7.4v. However that servo isn't under the load that a tail or cyclic servo is.
Team Synergy
VP Racing Fuels
Team Scorpion
Old 10-11-2012, 11:41 AM   #9 (permalink)
I just got off the phone with a nice guy from MKS support. He does not like the use of the unregulated pack to the MKS servo. He says that the servo is rated for up to 6v. The LiFe pack, when fully charged, will be 7+ volts. So, he says to use a regulator and step down the voltage to the servo somewhere between 5.5 and 6 volts. Also, strongly recommended the use of a linear regulator, and not a switching one, and reminded me to set the 760 pulse width on the flybarless controller before plugging in the servo.
I will heed all the warnings!
AMA #934662
Old 10-11-2012, 11:44 AM   #10 (permalink)
I thought life fully charged was only 6.6 volts? Hmm in that case might need to look into a regulator.
Team Synergy
VP Racing Fuels
Team Scorpion
Old 10-11-2012, 12:01 PM   #11 (permalink)
It's over 7 volts when fully charged, but for a very brief time...It quickly drops to 6.6v and stays there for the majority of capacity.
The Futaba CGY750 displays incoming voltage and I've never seen it over 6.6v on my LiFe packs..even with a freshly charged pack.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote Quick reply to this message
Old 10-11-2012, 01:47 PM   #12 (permalink)
I've been hunting around for something "simple" and lightweight to put in between the battery and the vbar so that everything runs at 6V, regardless of the pack voltage. I think I may have found something.... what do you think?
http://www3.towerhobbies.com/cgi-bin...3&I=LXVDB0&P=K
AMA #934662
Old 10-11-2012, 06:49 PM   #13 (permalink)
OS37
Hatori Pipe
3 x Align 515M
2 x Align 525M
Align 2n1 Reg with Push Glow
V-Bar 5.3 Pro Blue Line Full Size
Futaba 6203SB Receiver
KDBB 72mm Tails Neon Orange
Rotor Tech FBL Blades 430 i think
Receiver pack Thunder Power 1900mAh 2-Cell/2S 7.4V G6 Pro Lite RX Lipo
Gaui NX4 FBL (SK-540)
Gaui X4 II FBL (Gaui Mini V 5.3 Pro)
TT X50 N FBL (GT5)
T-Rex 700N FBL OS GT15 HZ (SK-540)
ranma103 is offline        Reply With Quote Quick reply to this message
Old 10-12-2012, 08:31 PM   #14 (permalink)
No one has any thoughts on this regulator??? Itching to buy it, but I'm hoping someone here knows something about it!
AMA #934662
Old 10-18-2012, 07:44 AM   #15 (permalink)
Purchased servos yesterday and Brain last week. Only need a pushglow, life pack and a regulator and I'm set. Quick question on servos, I purchased a set of mks' for the cyclic and tail, but for my throttle servo I have an Align 520 sitting around not being used. Would that be ok to run for a throttle servo?
Team Synergy
VP Racing Fuels
Team Scorpion
Old 10-18-2012, 11:48 AM   #16 (permalink)
DS520 Should be great on Throttle.
JC Zankl
Heli-Professional/YS Engines/Futaba USA/1st Blades/Scorpion Power Systems/Bavarian Demon/Xpert Servos/AeroPanda/ThunderPower RC
jczankl is offline        Reply With Quote Quick reply to this message
Old 10-19-2012, 07:39 AM   #17 (permalink)
Awesome, thanks for the info JC, one less servo to buy!
Team Synergy
VP Racing Fuels
Team Scorpion
Old 10-19-2012, 07:58 AM   #18 (permalink)
Got mine ordered today
I've been flying nitro since nitro was cool and something really excites me about a mini nitro....
Anyway the setup will be - -
OS37 - Sent to Magnum for their centerglide, ported by me
Revolution muffler (hey it was cheap and came with the motor)
DS515 for cyclic/throttle
BLS257 for tail
SK540 (figured I'd give it a try since it's the only one I haven't tried yet)
Probably a life pack
Stuff
eric cartman is offline        Reply With Quote Quick reply to this message
Old 10-20-2012, 05:17 PM   #19 (permalink)
Default What size root tail blades for NX4
What size root tail blades for NX4?
What size ball for the ball links?
mc0464 is offline        Reply With Quote Quick reply to this message
Old 10-20-2012, 05:24 PM   #20 (permalink)
Default MC
Are you going to be at the ROTO event next weekend?
Standard balls same as X5 and tail blade root is same as hurricane 425, Trex500
JC Zankl
