500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
02-19-2008, 04:05 AM | #101 (permalink) | ||
Team Taco CEO
Kevin Don't Taco My Pack, Bro! , Why crash when you can POUND it! |
02-19-2008, 04:09 AM | #102 (permalink) |
As the tail metal gear seems to be a nice upgrade to have, I'll go for it and just sand the tailboom section that goes into the tail metal gear part and that should do the trick ?
Never Underestimate The Power Of Stupid People In Large Groups |
02-19-2008, 04:39 AM | #103 (permalink) |
You will get the same readings from the main blades and paddles.
Anything that moves in the air creates some type of static field. ESD is the problem. |
02-19-2008, 07:03 AM | #104 (permalink) |
Great info. I see on the vid that you have the GF frame. I wonder if its the same result for the CF frame?
I LIVE FOR THIS! |
02-19-2008, 07:15 AM | #105 (permalink) |
Hey Kevin, Great job man......
I ran it over the tail blades yesterday and got a big signal. I was thinking the material caused it, so I stuck a pair of K&B blades on there, a little larger and it increased the intensity. I didn't necessarily think the gears were holding the charge, but possibly the frame is absorbing the charge from the gears. Thanks for all the work you've done on this.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep Donut Connoisseur HELI-FREAK, You couldn't have picked a better place to land ! |
02-19-2008, 08:48 AM | #106 (permalink) |
I saw this lastnight as well. On the stock tail it will read at the tail first, around the spinning grips with no blades attached. Awesome how you hooked to a meter. You should definitely get a reading from the gears and Im interested in how much.
02-19-2008, 08:48 AM | #107 (permalink) |
Sorry I should have been more clear.... We use this material Dupont Nylon with Fiber fill in my line of work all day!!!! LOL
Jerome |
02-19-2008, 09:10 AM | #108 (permalink) |
Kevin, Great Job with the video. With blade and without blades. I don't think its the material of the blades causing the static. I would think it once we put the load on the bearing from attaching the blades causing more friction that is STATIC. Grounding will do the trick. P.S. I had the Metal tail upgrade When I went down this weekend.
02-19-2008, 09:15 AM | #109 (permalink) |
I've just ordered the carbon tail blades, you think they will doe this too to that extend?
I also ordered the metal tail case, so I should be fine with that. Awsome job Kevin, thanks!!!
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-) |
02-19-2008, 09:31 AM | #110 (permalink) |
I think it will have the same affect with Carbon Blades. The stock Nylon blades Has a 5% carbon fill or glass fill in them this is how they get the strength and light weight out of the material.
02-19-2008, 09:42 AM | #111 (permalink) |
Now kev needs to do it with a metal tail case, with sanding some of the coating off of the boom
Representing: AMain Hobbies, XNova Motors |
02-19-2008, 09:48 AM | #112 (permalink) |
Assuming he is using the Greenlee that has the same range (50-1000), why is it activating at 1 volt? I was a bit concerned when my probe was detecting at the main gears, thinking there must be 50 volts there mininum. If it is a minute amount then I dont see a concern at the main gears since as Bob stated it has no place to build.
02-19-2008, 09:51 AM | #113 (permalink) | |
02-19-2008, 09:55 AM | #115 (permalink) |
No I mean 50. This greenlee I have is rated 50 to 1000v AC. One would think the detection range would fall between those 2, otherwise why provide the lower number.
Solution 1: Ground Boom to Tail Case Bearing Solution 2: Get a metal tail case and remove coating and make sure there's continuity between boom and bearing. Kevin so no ground from the boom to the frame? |
02-19-2008, 10:04 AM | #116 (permalink) |
You should probably check your bearings for pitting like Aberdeen says! ;-) Haha. Nice work. Now I don't feel so scared about getting my 500.
02-19-2008, 10:35 AM | #117 (permalink) |
Team Taco CEO
I've also tested my second 500 that was pre-lube with silicon oil and did not pickup anything on the boom. It also has a metal tail case, but I did not check if it's grounded. I think the lube is keeping the boom from holding any charge. I've only tested with GF frame. I'll will also test with CF frame when I have a chance.
You have to remember, the real problem is the buildup of charge over time. If it bleeds off and don't have enough energy to "spark" you will not have a problem. Yes the probe I have is 50-1000V Greenlee. The probe is a "non-contact" sensor so it's just measuring the energy "near" the signal not on it, so the circuit amplify this. On a power cable, you need to be about 1/4 inch from the line for it to trigger. On the heli, you can be as far as 4" away and I will trigger. You can also get it to trigger by just rubbing the tip on you shirt.
02-19-2008, 10:49 AM | #118 (permalink) |
Yes I understand this. In my video I showed detection turning the head by hand alone at low rpm and that grounding eliminated this. The only source I have found remaining is the main gear. I just dont see the use of the rating range if its going to detect less than 50 volts. I would like to see what numbers show up on the main gear, assuming you get anything at all.
02-19-2008, 10:55 AM | #119 (permalink) |
Team Taco VP
This needs to be in the sticky or this post stickied as well..... Ideas?
FYI interesting Kevin.... Have you tried the probe at the other end of the boom with the tail grounded? Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
02-19-2008, 11:03 AM | #120 (permalink) |
Team Taco CEO
It was getting late last night. I need to rebuild by carbon frame also. I was also able to get arcing and see a small spark when the tail was not grounded. I'll have to see if I can video this in the dark. I'll get more data soon.
