Old 05-01-2010, 03:05 PM   #61 (permalink)
More bad news concerning the 4035, the shaft is to short to be supported by the lower bearing mount.
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 05-01-2010, 03:26 PM   #62 (permalink)
Couldnt you install without the lower bearing block and run it that way?
Jeff
helis101 is offline        Reply With Quote Quick reply to this message
Old 05-01-2010, 03:34 PM   #63 (permalink)
sure...not sure if that would pose any problems with gear shredding due to flex but you could do it.
Old 05-01-2010, 04:50 PM   #64 (permalink)
started a thread about the 4035 vs 700M...
https://www.helifreak.com/showthread...10#post2024510
Old 05-01-2010, 05:23 PM   #65 (permalink)
KDE has a longer shaft for the 4035.
http://www.kdedirect.com/PartsandAccessories.html
Just another crappy day in Paradise.... Aloha!
CNCjunkie is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 10:12 AM   #66 (permalink)
Originally Posted by 1nv3rt3d View Post
I was planing on just cutting out the edges (Between white lines) and using longer threads and two large washer's for each side.. If this does not work then I may just use the factory motor until I can get a friend at a machine shop to get spec's and press me some perfect hole's set just for the 4035 Scorpion motor. Seems extreme but...
Here are maybe one of the first solutions.....
http://www.flying-hobby.com/shop/ind...oducts_id=5888
Speedy1661 is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 11:29 AM   #67 (permalink)
Holly Crap man why wasn't this posted earlier before I put a few scratch's on my motor trying to pull the shaft...Thanks man done order one of these.
1NV3RT3D YOUTUBE HelloHeli
1nv3rt3d is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 11:35 AM   #68 (permalink)
Just checked the tracking from Heliproz, the kit will be here Wednesday at 2:00..I cant wait!!! I will be posting so many photos haha.
Old 05-02-2010, 12:36 PM   #69 (permalink)
I found this serial connector while surfing.
http://www.helikraft.com/Batteries+a...-PreOrder.html
Edvard showed one in his build but had no reference as to its availability.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 01:05 PM   #70 (permalink)
http://www.helikraft.com/Batteries+and+chargers/ALIGN+RC/HEP00001-P/T+Type+joiner+(HEP00001-P)-PreOrder.html
It looked like the price was crossed out, and a higher one next to it, but it's 18.51, not 10.51. Almost had to raise the
Trex 450XL
Trex 450 Sport, S9257, Micoheli tail pitch lever bellcrank, KBDD 61 mm tail blades
opie1knobe is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 01:56 PM   #71 (permalink)
The $18.51 is crossed out and the new price posted is $14.44. Still not bad. I just ordered a serial deans cable and it was $11.99. This one is certainly more compact.
Old 05-02-2010, 02:07 PM   #72 (permalink)
Uhhhhhhhhhhh, that's what I said
Trex 450XL
Old 05-02-2010, 04:26 PM   #73 (permalink)
Sorry I must have misunderstood your post.
Old 05-02-2010, 04:35 PM   #74 (permalink)
Could somebody measure the inside diameter of the battery slot? would love to know the size of space, and battery options? Thanks
Yardape is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 05:00 PM   #75 (permalink)
https://www.helifreak.com/showpost.p...4&postcount=21
Old 05-02-2010, 06:06 PM   #76 (permalink)
Thank you
Old 05-02-2010, 11:01 PM   #77 (permalink)
The plug is on the way to shops:
http://www.align.com.tw/shop/product...oducts_id=3279
And also Align has mentioned a new line of 700e capable ESC to be available in next two weeks. They sure work fast!
steph280 is offline        Reply With Quote Quick reply to this message
Old 05-05-2010, 10:41 AM   #78 (permalink)
Hey guy's, Finally! It came in yesterday evening and I freaked out. It's just an amazing looking machine. For the most part the build is easy, but IMO the manual lay-out is $hit.
On the 3rd or 4th page when building the frame, it get's tricky..no big deal but my Trex 500 manual was easier to read and tell which part goes where. Anyways, I ran into a few problem's that slowed me down, like the rudder servo wire got in the way and wouldn't let the Futaba bls251 slide through so I had to cut and file the frame back but it looks neat and fits well now.
As for the elevator box that located by the main shaft bearing's..omg god, Align wtf? I had to cut on my new HV servo's to get it to clear the mount right and set correctly...
Also, I have never built the TT model and to me...the way you have to Glue the grommet's and the bearing's on the tt shaft, haha that's dumb but it worked out and the tail seems really strong and smooth.
I have taken so far over 50 photo's of the build as it goes but nothing really detailed and special, so maybe these photos will help people out in some way. The photos are uploading and will be posted soon.
Old 05-05-2010, 12:40 PM   #79 (permalink)
Old 05-05-2010, 12:43 PM   #80 (permalink)
