Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters
Walkera Helicopters Walkera Helicopter Support
Old 10-29-2010, 10:13 AM   #1 (permalink)
Default How do you secure your main gear retaining pin?
The one that keeps the main shaft attached to the main gear? On a 4g6 or 4g3. I know about the paper pin mod, styrene, aluminum pins, etc. this is with the factory pin.
It's a bit loose now since I took it out to replace the main shaft and put it back in.
Could bend it a bit, rather not. Could put a drop of silicone on or a drop of elmer's glue, something that can be peeled off but would retain it?
Or maybe use a bit of solid copper wire and just bend it around instead of the steel pin?
ncostes is offline        Reply With Quote Quick reply to this message
Old 10-29-2010, 11:18 AM   #2 (permalink)
I use a "nano drop" of CA... I use a pin to swipe the thinist, slightest amout of CA on the pin before I insert it... it is just enough that holds it quite firmly in place, yet I can break the seal and remove it if needed. the other trick is to apply a thin coat of CA on the pin and let it dry. This will increase the diameter of the pin making for a tight fit. you could do the same with clear laquer or nail polish.
Steve Joblin is offline        Reply With Quote Quick reply to this message
Old 10-29-2010, 11:33 AM   #3 (permalink)
Good tips. I considered a drop of CA but I have yet to master the "nano-drop" usually it ends up being a deluge.
The 2nd technique might be more appropriate for me, thanks.
Edit: I've been thinking of trying the paper pin mod, but 185 GSM paper converts to a bunch of different weights in LB, depending on the type of stock, so I gave up I supposed I can just buy some 72LB (one of the conversions I found) paper and try it, worst that can happen is I have to glue more sheets together.
Old 11-01-2010, 03:33 PM   #4 (permalink)
Use a drop of blue loctite, let it set up overnight once its in. Easy to punch out the next time, but stays put.
Schluter Champion, Kavan Allouette, TRex550E-FB, HC500SE, CloneT450pro-4bladed, Blade 400, WK 4F200, Xaircraft X650, and a CB180D, usually in a tree.
60something is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 03:42 PM   #5 (permalink)
But the main gear is plastic, I thought blue would degrade plastic, no?
Old 11-01-2010, 09:42 PM   #6 (permalink)
It's not locking up against the plastic, it's locking up against the metal main shaft.
To avoid all this you could use 1mm styrene rod, you cut the tip on an angle insert and cut to length. This helps with crashes as well. (doesn't strip main gear)
Some people have a problem for every solution...
john aeras is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 09:53 PM   #7 (permalink)
Ah I see, loctite the pin only, but some will get on the gear when you slide it in, I guess it doesn't matter.
The wait overnight part is the only downside
I read about the styrene pin mode but apparently that doesn't last very long. The paper pin mod seems to be the favorite, I haven't had a chance to buy some heavy paper to try it though but I will. I've used some solid copper wire before - it was flexible enough to bend back around like a clip.
Thanks to all for the info.
Old 11-01-2010, 10:03 PM   #8 (permalink)
I've been flying Walkera's, of various types, for the better part of two years now and I've never used anything to secure the pins. I just push them in there and away I go. Have not had a pin fly out yet.
johnsma22 is offline        Reply With Quote Quick reply to this message
Old 11-01-2010, 10:18 PM   #9 (permalink)
I use the styrene, it lasts until you crash and hit the rotor blades.
Old 11-02-2010, 10:24 AM   #10 (permalink)
where do you get 1mm sytrene rod from?
Old 11-02-2010, 04:44 PM   #11 (permalink)
From my LHS (actually 3 of them carry it!)
Old 11-02-2010, 08:53 PM   #12 (permalink)
I'll have to look... actually, I'll have to look for a LHS... we don't have many near where I am at.
Old 11-02-2010, 09:07 PM   #13 (permalink)
In that case... here it is online:
http://www.elmcityhobbies.com/shop/i...roducts_id=342
Old 11-03-2010, 09:17 AM   #14 (permalink)
Cool! Thanks! I googled, but couldn't find it.
