Go Back   HeliFreak > R/C Helicopter Support > 100 Class Electric Helicopters
100 Class Electric Helicopters 100 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-01-2014, 09:05 PM   #1 (permalink)
Default Out of box performance?
So what's this thing like out of the box? What mods are important right away? I feel like I see a lot of reliability issues, if you don't crash the thing, is it ok?
Bendero is offline        Reply With Quote Quick reply to this message
Old 03-01-2014, 09:27 PM   #2 (permalink)
Mine has been great..My only issues have come from pilot error crashes..My MCPX-BL takes a beating much better but the 150 flies sooo much better...It flies "bigger " and crashes "bigger"...
700 class nitro,2X 600class electric,2X 450class,250 class,130 class,a few mcpx class().Dx-7.All helis fbl...If I had a dollar for every dollar I've spent on heli's ...I would break even.
.Who is John Galt?
755 robert is offline        Reply With Quote Quick reply to this message
Old 03-01-2014, 10:17 PM   #3 (permalink)
I assume your asking about the T-Rex 150 DFC?
Out of the box, the plastic swash is RUBBISH even on the new batch, change the swash to a metal swash, apply the servo saver mod and I highly recommend replacing the stock gyro foam with something better.
I pre-ordered from the first batch on HeliDirect, however I got lucky they didn't get enough stock as the first batch had crappy brittle plastic. After Align has changed out almost all if not all the plastic and did a few changes here and there I feel this is great flying machine with just the two first mods mentioned in my second paragraph.
At first I was thinking this thing is fragile after reading all the posts and having issues with mine at first (I purchased the metal swash but wanted to see how long the stock plastic one would last ... 3 flights ... really just 3 flights!) but now that I've had a couple of crashes since my mods, I am starting to feel this is more durable than I was thinking ... however I fly over grass and haven't had a crash into anything really hard yet.
Tail holds well!!! Took me a few times to get everything setup and tweaked well and I was about to sell it after my 6th flight as I swore off motored tails ... yet after finally setting up the pots to my fly style and playing with gain a lot on my TX, this tail holds really well for what I can throw at it.
So if you're on the fence about purchasing it ... DO IT, I mean it's only a little more then the mCPX BL, however flies better and the parts are cheaper (I think? Not sure, but I read they were)
Chopper Crew: T-Rex 250 DFC, T-Rex 550e DFC, Goblin Black Thunder 700 T-Line
Multi Chop Crew: US75 Whoop, Martian II 250, Scratch V-Tail 355
Planks: Too Dayam Many
QueadlunnRau is offline        Reply With Quote Quick reply to this message
Old 03-01-2014, 10:45 PM   #4 (permalink)
DPW
Talking Schrödinger's Cat
Align test fly these and the 150 right out of the box is a blast to fly.
but
After a few weeks of non crash flying:
Crash resistance and improved flight.
Metal Swash $12
Stronger Frame $12
Stronger Main Shaft $6.99
Stronger feathering Shaft $4.99
3M Gyro Mounting Pad (3pcs/bag) $1.03
Now
I left out the servo gear strip issue. That can be address buy R&R servo gears or R&R servo's or Modify the servo horns.
What I am hoping for is Align or a 3rd party vendor to come out with metal gear or ceramic gear or Align black torque tube drive gear type of Servo's.
Align450L / 470/150 DFC/Blade stuff
DJI/AR Drone
DPW is offline        Reply With Quote Quick reply to this message
Old 03-02-2014, 07:25 AM   #5 (permalink)
Lol, yes, trex 150 was what I was getting at.. I have an mcpx v2... Had great luck with it. Time for an upgrade, and I'm on the fence between mcpx bl and trex 150. Really, the only time I'm crashing the mcpx v2 is when the tail blows out, but even that I'm learning to compensate for. I like the idea of the trex 150, but really don't want to have to a pile of expensive upgrades, or bench time repairing it. Everything you guys are talking about is ok. Is there a newest version I need to look for? How do you know it's the newest version?
Old 03-02-2014, 08:28 AM   #6 (permalink)
DPW
Exclamation V2 is all you can buy now
There is no official V1 V2 or part number change. All the V1 or first batch are gone. The Align 150 was sold out for a few weeks so original stock was eliminated.
Align in those weeks changed the material from ABS to PA66 (Nylon) which fixed all issues. There was also some assembly issues on first batch V1.
I was first batch and it cost me
Metal Swashplate w/ Free Frame H15H008XX $21.99
Metal Tail Motor Mount - H15T003XX $11.99
to upgrade my 150 way way above whats called V2 kit.
So
If you can even buy a first batch V1 which I doubt you can. Then its a simple $33.98 upgrade to bring your 150 way way beyond the V2 kit.
How to tell first batch V1 from V2:
Align printed the letter A on frame swash and T motor mount.
DJI/AR Drone
Old 03-02-2014, 09:55 AM   #7 (permalink)
The performance booster frame that comes free with the metal swash... Is it the same as the 'a' frame?
Old 03-02-2014, 12:57 PM   #8 (permalink)
DPW
No
All frames with an A printed on them are PA66 (Nylon)
But
Performance Booster (reinforced frame) is improved and is a better frame than a V2 kit or a frame with an A printed on the frame.
The Performance Booster (reinforced frame)
Has an A printed on it
Has larger stiffeners under the MRS
Is thicker under M motor
Has extra stiffeners in the tail area.
Thicker and added stiffeners means less flex better MRS performance improved flight.
Now
I have not seen the PB frame or Mtl swash sold separately. Which is a good thing. The PB frame is free with a Mtl swash buy.
DJI/AR Drone
Old 06-23-2014, 06:39 PM   #9 (permalink)
I have heat a lot about how easy the T150 breaks; but my experience has been just the opposite. In several months of flying I have just replaced the main shaft and feathering shaft, it took about 5 minutes. Just last week I lost control, went to throttle hold and picked up the heli undamaged, then I mowed grass inverted and hit the ground inverted, again, no damage and last, run out of batteries. 3 chrashes and no damage. Heli must be tough to take that abuse.
Aling Trex 450 DFC, Trex 150 Tarot 450 FBL, V120D02S, Super CP, Genius, , Walkera 2801
Waterfly is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 06:41 PM   #10 (permalink)
By the way, I have all recommended parts to improve the heli once it breaks; but it seems the out of the box model works real well.
Old 06-30-2014, 04:30 PM   #11 (permalink)
Kissed the dirt inverted moving forward at good speed on Sunday, no damage. I was flying on grass; but I was expecting at least the feathering shaft to get damage. Amazing little bird.....
Old 07-17-2014, 12:22 PM   #12 (permalink)
Mine flies great out of the box but I had to add foam pad and level the mrs unit
r/c helis lifestyle
HeliSmith is offline        Reply With Quote Quick reply to this message
Old 07-18-2014, 06:18 PM   #13 (permalink)
This 150 has taken lots of abused and still going strong. Hit the dirt twice today, no damage.
The other thing is that after flying at the speed of the 150 , flying my other helis is like cruising. Flying the 150 is like driving a Porshe. It keep you on your toes.
