Old 06-11-2015, 07:41 PM   #1 (permalink)
Default kosmik program question
Hi. Just bought a new kosmik cool 160. Trying to figure out what i need to get to program it, to update its firmware(not sure if i need to or not).which program disk or should i buy the pc progunit? Or can i update with disk? Which will enable the current limiting feature? Ect, ect.. thank you......
helifreak member since 2003
south of boston
iheliflyer is offline        Reply With Quote Quick reply to this message
Old 06-11-2015, 09:27 PM   #2 (permalink)
Smile
You will need to purchase the Prog Unit to make changes.
Prog Disc is no longer available.
Trex family.....100, 450L, 550E 3GX. Goblin 770.Goblin 700 speed machine. Goblin 380.
JR X9503.
PHANTMXR6 is offline        Reply With Quote Quick reply to this message
Old 06-11-2015, 10:03 PM   #3 (permalink)
Default progunit
Thanks.. 75$.. should be free when someone pays 689-910$ for a esc.
south of boston
Old 06-11-2015, 10:15 PM   #4 (permalink)
Welcome to Kontronik's business model....
VControl
Old hand at Planks
Peter
Old 06-12-2015, 05:14 PM   #5 (permalink)
Default programing
Drove up to helidirect today and bought the progunit..So are there any updates i need to do?
south of boston
Old 06-12-2015, 07:30 PM   #6 (permalink)
if you are on version 4.5 i woudl suggest updating to 4.5.1 to make sure you dont have any issues with the sd card not saving logs
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 03:15 PM   #7 (permalink)
Default kosmik
Ok. I will check. Thanks...just got it mounted..use a bic pen body for the stands and fuel tubbing to fill the center of pen body .soldered these angled copper termimal lugs i got at homedepot for the motor wires.
ID:	590839   Click image for larger version
ID:	590840   Click image for larger version
ID:	590842   Click image for larger version
south of boston
Old 06-13-2015, 06:53 PM   #8 (permalink)
Smile
You'll be happy with that motor too.
I have one in my 770 off a Kosmik 200.
Heaps of grunt
JR X9503.
Old 06-13-2015, 07:09 PM   #9 (permalink)
Default programing
So what do i set the current limit to?
south of boston
Old 06-13-2015, 08:29 PM   #10 (permalink)
you mean capacity limit? if you are running 5000mah packs you set it to 4.0 ah which is 4000mah which is 80% of the packs capacity used.
Richard Zappe
Old 06-13-2015, 08:58 PM   #11 (permalink)
What section did you get these in? Do you still have the package they came in?
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 06-13-2015, 09:08 PM   #12 (permalink)
Default terminal lugs
In electrical.....1.87$ for one pack that has 2 qty. I removed the set screw, found 2 bolts that barely threaded into the 2 side holes to keep the solder in .
ID:	590896   Click image for larger version
ID:	590897   Click image for larger version
ID:	590898   Click image for larger version
ID:	590899   Click image for larger version
south of boston
Old 06-13-2015, 09:14 PM   #13 (permalink)
Default programing
Yes. Capacity limit. Thanks.. so if 4200mah then set to 3.3-3.4?
south of boston
Old 06-13-2015, 09:57 PM   #14 (permalink)
yup i would go with 3.3 as it would always take a short time to get back and land.
Richard Zappe
Old 06-14-2015, 09:40 AM   #15 (permalink)
Default programing
Do i want governor or govenor store when im in mode 4?and set under voltage behavior to on?
south of boston
Old 06-14-2015, 11:20 AM   #16 (permalink)
no under voltage behavior makes under voltage a hard cutoff per the description in the manual.
you can run either it is up to you. if you are running a lot of batteries of different ages i would run store and use your weakest to do your first spool up. otherwise you can use it to not have to wait for the governor to kick in before taking off in normal flight.
Richard Zappe
Old 06-14-2015, 05:49 PM   #17 (permalink)
Default programing
So yes on the under v. B. And i only have one set of lipos so then just gov.
south of boston
Old 06-14-2015, 09:15 PM   #18 (permalink)
No you do not want to check under voltage behavior.
Richard Zappe
Old 06-14-2015, 09:19 PM   #19 (permalink)
Default programing
Ok. Thank you. I will uncheck it.
south of boston
Old 06-28-2015, 09:56 AM   #20 (permalink)
Default bog
Hi.. so i have 5 flights on the mostro with the kool 160. Seems awesome but every flight about halfway thru i get one bog on a hard move which can be heard and makes the tail kick. Why?
south of boston
