Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 03-26-2015, 02:39 PM   #21 (permalink)
Originally Posted by Baggley View Post
did you set your servos at 90 deg. first?
Yes I did. As I said in my first post, I followed finless's vids.
Alf
strtbobber is offline        Reply With Quote Quick reply to this message
Old 03-26-2015, 02:44 PM   #22 (permalink)
I pm'd you
Blade SR, Blade 450 3D converted to FBL Hightec servos 440 motor Thunder Power CF Blades,Trex 450 Pro DFC Hightec servos, Blade 180 QX, Proto x Nano, DX6i, Walkera V120s v2 Phoenix 5 Sim
Baggley is offline        Reply With Quote Quick reply to this message
Old 03-26-2015, 03:50 PM   #23 (permalink)
Default Success.....sort of.
Finally had a successful hover with "enough" positive pitch. There is still a lot more negative, but at least I have zero pitch at mid stick.
It's real snappy and instant response in the negative, but when I pin the throttle, the positive is not nearly as responsive.
So, now what can I do to get more "authority" or throw on the positive side?
Alf
Old 03-26-2015, 03:58 PM   #24 (permalink)
What are your throttle/pitch settings?
And your swash mix settings?
Blade: Nano QX, SR, 230s, 400 3D
Walkera: V120D02s
Align: 450L Dominator, 450 Pro DFC,
500 Pro DFC
nighttrain06 is offline        Reply With Quote Quick reply to this message
Old 03-26-2015, 04:11 PM   #25 (permalink)
Thrt curve: norm 0,47,70,80,100
stunt 100,88.5,75,88.5,100
hold 0
pitch curve: norm 42,47,52,75,100
stunt 0,25,50,75,100
hold 0,25,50,75,100
swash mix: aileron +60
elevator +60
pitch -35
Alf
Old 03-26-2015, 04:24 PM   #26 (permalink)
hold 0
hold 0,25,50,75,100
elevator +60
pitch -35
I don't remember what my pitch throttle is on mine, I'd try first dropping your pitch down say 36/45/55//75/100
That's really something you have to fiddle with to what's comfortable for you, Throttle I'd try something along the same lines.
You can try bumping the pitch down a little more on the swash mix maybe go to say-40 see what that does first....but either way try one or the other first, then adjust from there.. Be careful though and don't make drastic adjustments....this is tedious but important to do...
Walkera: V120D02s
500 Pro DFC
Old 03-26-2015, 04:30 PM   #27 (permalink)
Thank you for all the help!! I think I'll leave it for today and tackle it again tomorrow.
Alf
Old 03-26-2015, 04:31 PM   #28 (permalink)
I set all of mine as per the sr bible
Old 03-26-2015, 04:33 PM   #29 (permalink)
I think that's where I got my settings from. How do you like it like that? Not sure what kind of flying you do.
Alf
Old 03-26-2015, 04:34 PM   #30 (permalink)
No I have the 2 SR's he just got this one. Yes strbobber, unplug the motor, and I forgot about the lining the blades up....yeah you can hold it by the tail
Let it hang straight down, blades both evenly forward you'll see when you move stick to middle position. You'll see them uneven adjust the links up or down evenly, check and adjust up or down whichever is needed.
Also check settings on throttle pitch, this will cause it to not lift good also.
Yah, sorry I saw that after I posted the reply.
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 03-26-2015, 04:41 PM   #31 (permalink)
I did change my throttle on stunt 100% flat. I fly 8s, small cercurls.no 3d, I do find it jumpy, I like my 450 3d much better, more stable.
Old 03-26-2015, 04:42 PM   #32 (permalink)
Alf
Old 03-26-2015, 04:45 PM   #33 (permalink)
I pretty much have mine somewhere around what's in SR bible, but have fiddled a bit with em, the way mine come up is nice and smooth, as well as landings....I think that a different pitch setting in your swash mix is where you'll get more hot rod type movement out of it...
Walkera: V120D02s
500 Pro DFC
Old 03-27-2015, 11:16 AM   #34 (permalink)
strbobber here is what settings I have on my SR:
Throttle: 0/42/55/75/100
Pitch: 36/46/55/74/100
Stunt: 0/25/50/75/100
Throttle in stunt bout same as yours
My swash mix is
Aile:+60
Elev:+60
Pitch:-36
Those can be different from heli to heli, but try
What I have set up first, and go from there.
Mine comes up really nice and easy, and in idol1
Is nice and powerful.
Walkera: V120D02s
500 Pro DFC
Old 03-29-2015, 05:20 PM   #35 (permalink)
On the SR the pitch is controlled by the trailing edge of the blades which means when you raise the throttle the swash moves down. So when the swash moves down it gives more positive pitch. This also means that at mid stick if the swash is closer to the bottom of the shaft you will have more negative pitch than positive pitch. If you lower the swash while at mid stick, as the OP did, you will end up with even more negative pitch. On the SR low stick the swash should be at the top of the shaft, mid stick swash should be centered and high stick swash should be at the bottom of the shaft. If not, adjust accordingly so you have even positive and negative pitch. At mid stick you want the swash as close to center as possible.
kla912000 is offline        Reply With Quote Quick reply to this message
