Old 09-19-2007, 11:29 PM   #1 (permalink)
Default .010 gap too small?
Stratus os-spec,
Just installed on my second stratus, before flight I mesaured .025 now after break in and 4 flights, im measuring a reduced .010 at home, is this too small?
Jamie
nguyen23464 is offline        Reply With Quote Quick reply to this message
Old 09-20-2007, 07:34 AM   #2 (permalink)
It is normal for the gap to lessen after running the motor. You should be fine at .010.
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 09-20-2007, 09:05 AM   #3 (permalink)
thanks david, I feel a little bit better about it now. Is it possible that the frame might flex onto point of contact and cause a lockout at this measurement?
Old 09-20-2007, 09:50 AM   #4 (permalink)
With a helicopter anything is possible.Since the clutch driver and fan hub are turning at the same rpm. A touch between them should not be enough to lock out PCM. Now if the dampeners are bad, there is banging happening between two surfaces. That is different.
David
Old 09-20-2007, 10:18 AM   #5 (permalink)
im thinking about ordering YS adapter plate 126-33 and raise the gap up a bit. But that would really bring it up to .015, almost not worth placing the order. Its either that or I have to reduce that engine shim, and I really dont feel like dial indicating that fan again.
Even though, I think your right on that gap size, I figure it probly got reduced during the first flight to .010, and I got maby about 3 more flights in after that without issue. But who knows maby the wrong move at the right time will be the one.
I think im gonna take your suggestion david, and just fly it the way it is at .010.
thanks david,
Jamie
Old 09-20-2007, 11:21 PM   #6 (permalink)
Got it squared away. K&S brass shims did the trick underneath the a supports. .016 shim brought it up to a gap of .026.
Jamie
Old 09-21-2007, 08:15 AM   #7 (permalink)
That will work. Now you will be replacing the dampeners in the fan hub. The more gap the quicker they wear out.
Like I said, .010 is fine, mine is only .015 and has given no problems.
David
Jamie
