Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba 14MZ - 12Z
Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum
Old 01-25-2008, 12:57 AM   #21 (permalink)
Originally Posted by DavidH View Post
The software you need for the 12FG to use the 2.4 ghz module and receiver is version 1.3
It is the software update at the bottom of the list for the 12FG in the link posted above. Version 1.2 is not going to work with the 2.4 ghz module.
Troc,
Do you have a 14MZ or 12FG. You mention both radios in one post. The software version for the 14MZ is
1.20 1.38 or 1.21 1.38 Either version will work the 2.4ghz module and receiver for the 14MZ
For the 12FG you need software version 1.3
Look in the information screen in the menu and it tells what version the software is that is loaded in the tranny.
The modules are region coded also. So you need a module that matches the region code on your transmitter. Being in france, your not go all the frequencies in the 2.4 ghz that the rest of the world has. Or some of them will only be used at 10mw output while the rest will be at 100 mw output. There is an instruction manual in the update that you can read that will explain this. It is a Word formatted document.
David
hi David, I have a T14 with normal modul. And as I have a friend who has the biggest RC shop in France, I also have the 12FG with TM14 modul for trial. Both radio are region coded for France (Europe) So what I have done is just update my T14 to the editor 1.2.0 and plug-in the TM14 of the 12FG. But I can't activate the TM14. When the "mismatched frequency..." message appears, I pushed YES. But when I gp in to the frequency setting windows it said something like unable to change the frequency because of mismathced
troc is offline        Reply With Quote Quick reply to this message
Old 01-25-2008, 05:43 AM   #22 (permalink)
Team Taco Member
troc
Just to clarify.
You have a 12FG with a TM14 Module
You also have a 14MZ with a 35 or 40Mhz FM module
The 14MZ is at Ver 1.20/1.38 but when you plug the TM14 from the 12FG you say that there is a "Mismatched frequency band" message when you first turn on (below)
You select yes and then enter the Frequency screen. Here there should be another message reporting "Mismatched frequency band" with a Yes button below?? Is this button displayed? (below)
Mark
Morley F1 60 Max (OS 61LX-H), Hirobo SDX (OS 55HZ-H, GY701), Trex 450SE + some planks
MarkD is offline        Reply With Quote Quick reply to this message
Old 01-25-2008, 09:15 AM   #23 (permalink)
Default How to change the region code on Futaba 14MZ for 2.4G
Originally Posted by flycop2000 View Post
There's posts on Runryder where members from the U.K. have bought US modules and then changed the region code on their Tx. They have reported that they work O.K.
Hi, Flycop 2000,
I'm interested in reading this posts but am unable to locate.
It would be appreciated if you could put the link for this?
Team Japan
Team Japan is offline        Reply With Quote Quick reply to this message
Old 01-25-2008, 10:22 AM   #24 (permalink)
Here is one.
http://www.runryder.com/helicopter/t397358p1/
David
DavidH is offline        Reply With Quote Quick reply to this message
Old 01-25-2008, 05:40 PM   #25 (permalink)
Originally Posted by MarkD View Post
troc
Just to clarify.
The YES button is not there. And I found another problem: when I plug back my 41MHz Modul in with the updated Editor (1.2.0) and Encoder, the transmiter is hang out, unable to go further than the screen that demand the confirmation to transmit (the second window when TX is turned on). When I switched back to 1.1.0 editor with 1.37 encoder it works like before. Strange think happened.
Old 01-25-2008, 06:54 PM   #26 (permalink)
Hi David,
Thank you very much for your prompt response.
It is very useful as I have been struggling how to use TM-14 sold in U.S.A. outside U.S.
Will digest this post carefully.
Thanks, Team Japan
Old 01-29-2008, 06:15 AM   #27 (permalink)
Hi David,
Thank you for advising the link for changing the area code of 14MZ.
Aread code on 14MZ was sucessufully changed. Thanks again.
Now, a friend of mine who has 12Z would like to change the area code.
However I am unable to find the link where contains following programs;
1) T12ZSETRX.ini
Execute T12Z Setting Rx Program
2) T12ZTESTLIGHT.ini
Execute T12Z Reduced Test
3) T12ZTEST.ini
Execute T12Z Test Program
It would be great if you could advise the place to down load above.
Best regards, Team Japan
Old 01-29-2008, 09:47 AM   #28 (permalink)
That is the commands you need. Those are the programs you posted. You have to put the one you want to use on the CF card. Needs to be the only command on the card.
David
Old 01-29-2008, 06:16 PM   #29 (permalink)
Hi,
I just received my TM-14 module and successfully plugged in in my 14MZ. I cheched the frequencies with a scanner and I can confirm that when positionned to "France" the module transmits only between 2400 and 2450 MHz, so Futaba did a bandwith limitation, not a power limitation (there's no output at all between 2450 and 2483 MHz).
BTW I had to change my radio to Europe version (module is europe one, bought in France). One important thing I noticed is when reverting to encoder 1.1 - 1.31 to use the calibration utility for the 14MZ, when I set the region to Europe, at reboot I loose all text in the display !! (bug seems to appear only when the radio is set to Europe, I tried America and it works well). But no panic, I just had to uprgade again to 1.21 - 1.38 and display gets back as normal for Europe zone.
A+
Sam
sambogosse is offline        Reply With Quote Quick reply to this message
Old 01-30-2008, 08:13 AM   #30 (permalink)
David
Hi David,
I'm little bit confused. I was not able to find the v1.31 for 12Z.
Are you suggesting for me to use v1.31 of 14MZ of following program (which included in utility soft includes T14mzUtility calibration utility for the FX40 )to apply 12Z by installing each program for different CF card to change the region code?
1) T14ZSETRX.ini
Execute T14Z Setting Rx Program
2) T14ZTESTLIGHT.ini
Execute T14Z Reduced Test
3) T14ZTEST.ini
Execute T14Z Test Program
Appreciate your help.
Old 01-30-2008, 09:16 AM   #31 (permalink)
This thread explains it.
https://www.helifreak.com/showthread.php?t=20745
You can not load 14MZ updates into the 12Z.
The latest update for the 12Z is for the 2.4ghz module.
It is V1.2.0 /1.38
Just curious if your in Japan. 2.4 ghz is not legal for aircraft there yet from what I understand. Suppose to be legal around June/July is what I was told.
David
David
Old 01-31-2008, 05:51 AM   #32 (permalink)
It is V1.2.0 /1.38
David
Hi David,
Thank you very much for your very useful information. I believe I can understand how to activate calibration soft for 12Z which is already installed in 12Z.
I do not know when 2.4G is legalized in Japan but our team is very much interested in this new way to avoid interference. So I asked your help.
Thanks again and best regards, Team Japan
Old 03-29-2008, 10:03 PM   #33 (permalink)
Hi, Team Japan and David.
I have same problem with Team Japan.
I'm looking for the software for 12Z but I can't find out from rcfan.
I'm really happy if you send me a software by PM or e-mail.
Thanks, Sukjoon Kim
sukjoon324 is offline        Reply With Quote Quick reply to this message
Old 04-09-2008, 12:31 AM   #34 (permalink)
Default Futaba FASST receivers
Hi there
I want to buy Futaba FASST receivers from the US.
Does anyone know if the receivers are region coded?
Will they work with a European TM 14 module?
Thank fpr your help
Roland
magic is offline        Reply With Quote Quick reply to this message
Old 04-10-2008, 02:37 AM   #35 (permalink)
Hi
The receivers are not region coded.
You can take the receiver from the US.
mfg Chris
fritzchris is offline        Reply With Quote Quick reply to this message
Old 05-16-2009, 12:49 PM   #36 (permalink)
Default Hi
Hello DavidH,
Sorry just enquiring, Does it mean that the US region versions have more transmit power or are able to use more hopping channels, then the France and Asian regions versions? Thanks!
David
kaka is offline        Reply With Quote Quick reply to this message
