Old 05-29-2009, 02:53 AM   #21 (permalink)
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 08:12 AM   #22 (permalink)
I prefer large and high quality video! If you're on dialup then you shouldn't be downloading such files anyway.
jared_of_atlanta is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 10:42 AM   #23 (permalink)
+1 Larger and higher quality, great job!
ducati996 is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 12:47 PM   #24 (permalink)
John thanks a lot for the manual !!!!!
gelatmi1 is online now        Reply With Quote Quick reply to this message
Old 05-29-2009, 07:56 PM   #25 (permalink)
yes HQ and large +1
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 09:52 PM   #26 (permalink)
I am speechless to the packing and machine work. Definitely HQ. I don't want to miss anything.
- Mike -
MINI TITAN - DX7, AR6100, GY401 w/3400G, TP 2100
TREX 500 -
DX7, AR7000, JR 3650Z's, GY401 w/9254
cmb2003svt is offline        Reply With Quote Quick reply to this message
Old 05-29-2009, 10:06 PM   #27 (permalink)
Cant wait! Ordered mine with the cyber flybarless head. =) Can't believe my peeps in the motherland can make a heli this awesome!
[Trex 250] [Trex 450 Pro VBar] [Blade mcpX2]
[Kasama Srimok 90 Nitro VBar]
MB-PC is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 01:24 PM   #28 (permalink)
very nice videos
I'm just wondering if there will be any issues with mounting the carb when the fan is mounted first? It looks as it will be very close to the fan while mounting it?
Looking forward to the rest of your build
Team visa.....
Bjorn is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 01:38 PM   #29 (permalink)
Team Taco VP
Hahahahahahahah...... The free range rodent was funny!
Bob
Old 05-30-2009, 01:50 PM   #30 (permalink)
Team Taco VP
John, I wouldnt worry about runout on the fan but more of the starter shaft and pinion. To me when you are rotating the fan it looks like the top of the starter shaft has quite a bit of runout? Maybe it's just the video?
Bob
Old 05-30-2009, 02:12 PM   #31 (permalink)
Yeah, the free range rodent made me almost spit out my tea! As soon as I saw that, I thought of Capi (HFG) and my puter almost got sprayed! That was priceless!
Rick.
Rick.
Heli Pilot, Engineer & Mechanic for Team Dirka Dirka!
MavriC is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 02:26 PM   #32 (permalink)
Nice build John. Keep the HQ videos coming.
Old 05-30-2009, 02:39 PM   #33 (permalink)
Default HURRY BUILD & TEST FLIGHT
Maybe GrandRc will get more in by then......!!!!!!!!!
Thanks for the great videos John.
jimheliboy is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 07:27 PM   #34 (permalink)
Originally Posted by Bjorn View Post
very nice videos
I wondered this too but I'm pleased to say I could fit the carb (on the Aligh 91P) without stripping it all down !
Bob
Might have been parallax distortion Bob as I had a quick check and it seems OK I'm not gonna worry about the fan for now but if/when I have toi strip it down in future I'll try dialling it in properly.
Only problems so far are the pinion very tight fit in the clutch bell and worried me a lot I was cross-threading it as it wouldn't screw down freely - using the starter shaft as a former helps.
Also there was a packing error in my kit with two canopy standoffs being mistakenly included in pack 5-2 on page 11 - lucky I had some QuickUK T700 canopy mounts which were just the right size (with an M3 0.75mm washer) to make up the 22mm required. Kasama is aware of this and rectifying it as we speak !
John
Old 05-30-2009, 07:34 PM   #35 (permalink)
Bob
Norah's been a great building companion over the last 2 years but I have to say that this is likely to be her last build video series as she has to undergo surgery next week and I don't think her prognosis good
John
Old 05-30-2009, 07:51 PM   #36 (permalink)
Hi this is a great heli, but itīs been delay for 2 years if not more......
I am wondering if Kasama are gonna realese a 50 size Srimok....???
Great job whit the vidieo
Salvatrucho
Salvatrucho is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 10:02 PM   #37 (permalink)
John,
For the pinion being tight...
Next time you have it apart, take a look at the "crest" of the threads on the pinion. If the major Dia. is a bit large, you can simply file down the O.D. a little bit. Carefully mind you, but you can. Threads run on a Pitch Diameter, and that is what is important. Unless you have a Go-NoGo Gage for the internal thread, you cannot measure this. But for the external thread, simply measure the O.D. of it. But rule of thumb, external threads should be machined approx. .002" under nominal. They are measured then using Thread Pin Gages "Over Wire Method" and Micrometers. Remember, it's the Pitch Diameter that is important here. Not so much the O.D.
If the "root" of the internal thread is a bit large per say (from a big tool nose radius) then the "crest" of the external will interfere. So a simple filing might help you out there.
Which brings me to my next point...
Threads run or ride on the Pitch Diameter. So if the shaft has a run-out, the ONLY way to fix this is to "bend" the shaft. I'm sure the shaft was machined and ground between center's, so the run-out should be next to none.
Hope this helps!
Rick.
Rick.
Old 05-31-2009, 01:03 AM   #38 (permalink)
Well if it is truly here last build then the Kasama looks like a helluva build to go out on. Hope it isn't the last one though and things go well with the surgery.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote Quick reply to this message
Old 05-31-2009, 05:11 AM   #39 (permalink)
Got two more vids today but not sure if they'll be available for upload
Got to go to UK for a week for my mum's 80th birthday and had to leave these blind uploading - Cute FTP not the world's most reliable - Anyway don't try and download them before 1200 UTC (that's 0700 East Coast) earliest as they're slow to upload !
If they don't work 'fraid you're gonna have to wait till I get back
John
Old 05-31-2009, 11:41 AM   #40 (permalink)
Both of the videos worked! Thanks!
