X5 Discussion and support of the Gaui X5 |
08-08-2014, 10:17 PM | #1 (permalink) |
Hints on changing the front drive gear bearing?
So I'm hunting down a vibration on the X5 and I decide to inspect the front drive gear for the first time in a while. The ball bearings drop all over the floor as soon as I pull the shaft!
So I need to change the front drive gear bearing ( the bearing for the gear which is driven by the autorotation gear and has an umbrella gear on its top ) Anyway to do this without pulling off a side?
Gaui X5 FBL w BeastX! yesssssss! "The Big T" TRex600N OS 50 +Flybar! Synergy N5 O.S.55 Spartan Vortex |
08-08-2014, 11:08 PM | #2 (permalink) |
Just take a small Phillips take the screw out of the gear , then use a small flat head and pry it up gently it is a tight spot to work in , did that the other day
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2 TARANIS X9D + ,ez-uhf jr mod GauiX5 Gauix3 |
08-08-2014, 11:12 PM | #3 (permalink) |
so if it was unclear. I need to change the BEARING that the shaft for that umbrella gear goes through. The umbrella gear is fine.
08-09-2014, 02:19 AM | #4 (permalink) |
Lol maybe if read the post proper ,just take the main gear out and elevator servo arm
08-09-2014, 03:36 AM | #5 (permalink) |
You need to pull the plate out and heat the plate to get the new bearing in. I took out both plates and did mainshaft bearings at the same time. It's the worst job to do on the X5 IMHO.
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional |
08-09-2014, 06:54 AM | #6 (permalink) |
what is the gaui part number for the bearing you are trying to change.
everyone seems to be confused about what you are talking about and so am i.. i can think of 2 bearings that you could be talking about. or better yet post a pic of what your talking about.
----------------------------------------------------------------- Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more. |
08-09-2014, 10:42 AM | #7 (permalink) |
Its the bearing for the spur gear. The spur gear being the one that the front umbrella gear also mounts two.
The bearing is number 208760 and goes in the bottom plate in that raised spot for the bearing.
08-09-2014, 05:31 PM | #8 (permalink) |
I know what bearing you mean.
You have to do it correctly as if it doesn't seat perfectly your TT mesh will be way off and you'll eat TT gears.
08-09-2014, 11:48 PM | #9 (permalink) |
Well, not the shortcut I was looking for but after talking to newbheliusr at the field today there is not going to be much of a shortcut to this...
