Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 12-17-2010, 07:11 AM   #41 (permalink)
Originally Posted by g-bru View Post
Maidened the TDR last weekend Vas!
G.
G, sweet as mate Looks quick just cruising. Congrats and enjoy
Vas
P.S now you have to even it up and get some footage with the X5
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote Quick reply to this message
Old 12-17-2010, 07:22 AM   #42 (permalink)
Thanks and will do bud!
However, will not be flying either of them till these below freezing temperatures are over. I don't really want to be another boom backing out victim!
Heres wishing you and the family a very Merry Christmas Doooood!
G.
g-bru is offline        Reply With Quote Quick reply to this message
Old 12-18-2010, 02:41 AM   #43 (permalink)
Originally Posted by -Centurion- View Post
Terrabit,
Thanks for the info and the link...
Of course! Glad to help.
terrabit is offline        Reply With Quote Quick reply to this message
Old 12-18-2010, 03:03 AM   #44 (permalink)
where are you vstabi users mounting your system. I ordered the mini v 5.0 and as with my x5 it's not here yet. Is the best place inbetween the frames, on the bottom plate towards the back? Or maybe, if it's small enough, it can go inbetween the frames on top of the TT plate. Or is that too close o the TT shaft?
kdfi is offline        Reply With Quote Quick reply to this message
Old 12-18-2010, 03:14 AM   #45 (permalink)
I use the standard vbar with seperate sensor only because it gives me more mounting options should I decide to move it to another ship. I believe you would be fine to mount it either on the back of the boom block or inside. It might be more protected inside the frame. Either way it will overhang the sides of the frame. It is juast a bit wider than the frame.
Old 12-18-2010, 03:34 AM   #46 (permalink)
yea, I want to put it in the best possible place for protection.
Old 12-18-2010, 04:55 AM   #47 (permalink)
G.
G, hopefully you get some flying weather soon mate. Merry Christmas to you and yours aswell. If you've been good, Santa may even bring some heli pressies...
Let's hope he hasn't been watching the other 363 days
kdfi, i have my mini-v mounted on the lower tray inside the frames. Is about 1-2 mm wider than the frames themselves. One point to watch for... make sure you can plug the USB cable in when mounted. I offset the mini-v to one side slightly to accomodate and took a little off the side of the usb plug(cable) itself to make it easier. Can also use a straight plug but have to thread through the frames when doing so.Just make sure the mini-v is straight with the frame sides. My understanding is that it doesn't matter if it's not centred.
Vas
GAUI
Old 12-18-2010, 05:28 AM   #48 (permalink)
Hi,
Below is where I mounted my Mini V-Bar...
*Acrobat Voodoo 600 - Microbeast V 3.0.8
*Compass 7HV - Microbeast V 3.0.8
*Gaui X5 FES - Microbeast V 3.0.8
-Centurion- is offline        Reply With Quote Quick reply to this message
Old 12-18-2010, 05:34 AM   #49 (permalink)
Hi all,
Today I maidened my X5 under light snow. Everything was excellent. X5 flew so smooth without an issue and the sound was amazing...Mini V-bar also did well. No problem so far. Thanks to all who helped
Old 12-18-2010, 06:10 AM   #50 (permalink)
Centurion, it gets better with more flying
Welcome to the grin club and enjoy mate
Vas
GAUI
Old 12-18-2010, 11:37 AM   #51 (permalink)
Vas
Thank you Vas. Happy to be a member of grin club
Old 12-18-2010, 11:16 PM   #52 (permalink)
Hi,
Tanks for posting the pic Centurion!
Looks like a good fit! Any probs with accessing the usb port?
VAS,
Do you have the Blue 5.0 vbar? How do you like it?
Old 12-19-2010, 03:00 AM   #53 (permalink)
I use vbar 5.0 in a std black and the bluline units. Functionality is identical. The bluline series is a bit more resistant to vibration but that's about it.
Old 12-19-2010, 03:36 AM   #54 (permalink)
VAS,
Hi Vas,
I have only this one (version 4.0) Actually this is my first und only vbar. That's why I can't say anything on this
Accessing the usb port is not that easy but not too hard either... I just need to bend the cable to access that's all.
Old 12-19-2010, 03:53 AM   #55 (permalink)
mines in virtually the same spot as Centurions. Can access with a bit of fiddling on the cable.
The blue mini-v is my first FBL and for me has been terrific. Simple to set up and flies awesome.
As terrabit said... the v4 ones can be upgraded to v5 and is just the sensors that are different and a bit better in regards to vibration. From what i understand, the software from v4 to v5 has made a more connected feel and seem alot recommend the upgrade.
Either way, they fly awesome and i'm kicking myself for not trying earlier
Vas
GAUI
Old 12-19-2010, 04:05 AM   #56 (permalink)
Vas
I'll think about upgrading it. Thanks Vas...
Old 12-19-2010, 06:32 AM   #57 (permalink)
the " pro " version has even more features. All depends on how much you enjoy fiddling and how many options .
One thing to point out to people....... disable your trims on the TX!!!!!!!! Don't want to be bumping them and making the vbar think different settings.
Vas
GAUI
Old 12-19-2010, 09:13 PM   #58 (permalink)
I've been using vbar since 2006. Back then it was a totally different game. It's much easier to setup now and it actually works better too. I've probably setup a dozen different birds with vbar including the ones that weren't mine.
5.0 pro gives you access to the spectrum analyzer and offer a higher level of programmability.
Old 01-13-2011, 06:13 PM   #59 (permalink)
My BeastX setup on my X5 FES.
Going to consider redirecting the yellow signal wires back through the frame or maybe bind them in the middle a little away from the Beast and have them connected to the frame. Will play aorund a bit.
Overall very pleased with the setup, was almost plug and play, pretty much went from the start of the manual to the back and it was all done
Models:Compass 6HV Synergy E7 Warp 360
Radio: Futaba 8FG
Lojik is offline        Reply With Quote Quick reply to this message
Old 01-16-2011, 05:43 AM   #60 (permalink)
Looking tops Lojik
Anxious to hear your thoughts after the maiden.
All the best with it mate
Vas
GAUI
