SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters |
02-10-2013, 05:46 PM | #1 (permalink) |
What's your Goblin 500 Setup Thread
Since our Goblin 500's will be here this week, and we were broken into our own "SAB Goblin 500" sub-forum...I thought it was only appropriate that we start our own Sticky "What's your Goblin Setup Thread".
I know I started the other wildly popular Goblin 500 - What setup? thread, but that was extremely early on while people were still brainstorming and learning about the options that were out there. Now that we've settled into the options available, and most have actually PURCHASED their setups...here goes nothing. Quote this and fill in all that apply:
-Shane |
02-10-2013, 05:48 PM | #2 (permalink) | |
Here's mine. -Shane |
02-10-2013, 06:20 PM | #3 (permalink) |
Here is my set up.
AMA # 823133 |
02-10-2013, 07:22 PM | #4 (permalink) |
Re: What's your Goblin 500 Setup Thread
Yellow 500
Futaba bls 153 Torq 9188 rudder Jive 100lv mode 4 Scorpion 4020-1350 Thunder.Power 4400 /65c (got 6) Silver line v bar DX 18 EC 5 connectors Setup in works will update v bar and head speeds. New England Heli Crew
SAB USA REP New England Heli Crew |
02-10-2013, 07:33 PM | #5 (permalink) |
Mine
02-10-2013, 09:30 PM | #6 (permalink) |
Here is mine:
02-10-2013, 11:29 PM | #7 (permalink) |
YELLOWand BLACK
CN#139 GOBLIN 500- HeliJive 120, Pyro 600-12, BK Servo GOBLIN BLACK NITRO YS 96 SRX Tareq, Torq, BK |
02-10-2013, 11:42 PM | #8 (permalink) |
My setup
Flight Style: Sport / New 3D FBL System: Skookum 720 Motor: Scorpion, 4020, 1100 Pinion: 18T Target Headspeed(s): 2600 ESC: CC Tylon & 90amp Governor: CC ESC BEC: NONE RX Pack: Futaba, R617FS, 2.4Ghz Cyclic Servos: Align, 510 Tail Servo: Align, 650 Main Blades: SAB Stock Tail Blades: SAB Stock LiPos: Voltz, 35C, 6S, 5100mah Anything Else: |
02-11-2013, 12:08 AM | #9 (permalink) |
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct | |
02-11-2013, 12:09 AM | #10 (permalink) |
Yellow and Black SAB Goblin 500
02-11-2013, 05:56 AM | #11 (permalink) |
-- Outrage Fusion 50 FBL, Outrage 560k motor/CC HV80 ESC, Torq 9180/9188 servos, Skookum 540 -- SAB Goblin 500, Scorpion 4020-1350kv, CC Talon, Skookum 540 Lynx Heli Innovations Team Pilot | Southwest PR RC Crew Last edited by ericcolon; 02-11-2013 at 05:57 AM.. Reason: formatting |
02-11-2013, 07:32 AM | #12 (permalink) |
Flight Style: Sport / Basic 3D
FBL System: HC3SX Motor: Scorpion 4020-1350 KV Pinion: Stock 18T Target Headspeed(s): 2600-2700 ESC: Castle Talon 90 Governor: Built-In ESC BEC: Hercules mini G2 @ 7.3v RX Pack: Futaba R6303SB Cyclic Servos: Graupner HBS660 HV Tail Servo: Futaba BLS256 Main Blades: Stock SAB (500mm) Tail Blades: Stock SAB (80mm) Lipos: Pulse Ultra 6S 4100mAh 45C Anything Else: Scorpion Backup Guard
3 Align 450 Pro's Align 600N DFC, CGY 750, reactor X2 os 55hzr |
02-11-2013, 08:31 AM | #13 (permalink) |
Red & White
Flight Style: Big Sky / Speed FBL System: Mini V-Bar 5.3 Pro w/ DSMX satellites Motor: Kontronik Pyro 600-12 Pinion: 18T Target Headspeed(s): 2300 ESC: Kontronik Jive 100+ LV Governor: ESC BEC: Jive internal BEC RX Pack: none Cyclic Servos: Spektrum H5020G Tail Servo: Futaba BLS251 Main Blades: Edge 523 FBL Tail Blades: Edge 72mm LiPos: Haiyin 4000 6S 40C Anything Else: TM1000 telemetry Last edited by rablett; 02-23-2013 at 12:27 PM.. |
02-11-2013, 09:03 AM | #14 (permalink) |
Yellow & Black
02-11-2013, 12:20 PM | #15 (permalink) |
Here is mine Red-White Goblin500:
Flight Style: Smooth 3D / Smack 3D FBL System: 3GX 3.0 Motor: Scorpion HK3-4020-1350KV Pinion: 17T Target Headspeed(s): 2600/2700/2800 ESC: CC Talon 90 Governor: ESC BEC: Talon 90 Cyclic Servos: DS515M Tail Servo: DS655 Main Blades: Stock Tail Blades: Stock LiPos: Pulse 6s 4500mah 45C Anything Else: Scorpion Backup Guard |
02-11-2013, 03:09 PM | #16 (permalink) |
Red and White:
Flight Style: Sport Flying/Smooth 3D FBL System: Mini Vbar Motor: Quantum 4120-1200 Pinion: 18T Target Headspeed(s): TBD ESC: CC Talon 90 Governor: ESC BEC: ESC Cyclic Servos: Graupner HBS 660 HV Tail Servo: Torq 9188 Main Blades: Stock Tail Blades: Stock LiPos: Pulse 6s 4500mah 45C Anything Else: Scorpion Backup Guard
-------------------------- SAB Goblin 700, Goblin Fireball, OXY 2, OXY 4 |
02-11-2013, 03:27 PM | #17 (permalink) |
Yellow and Black
Flight Style: Sport Flying/Smooth 3D FBL System: BeastX Motor: Scorpion HK4020 - 1100 Pinion: 18T, 20T Target Headspeed(s): 2400rpm, 2800rpm ESC: YGE 120 LV Governor: YGE / Gov. Store BEC: 8V from YGE Cyclic Servos: Graupner HBS 660 HV Tail Servo: Graupner HBS 770 HV Main Blades: Stock SAB Tail Blades: Stock SAB LiPos: Whiteline Exxpert 6s 4500mah 30C Anything Else: Green Caps
Goblin 770, Logo 700 @ VBar Touch |
02-11-2013, 07:37 PM | #18 (permalink) |
Angelo |
02-13-2013, 12:13 AM | #19 (permalink) |
Switched from my original pre-order of Red / White to the Yellow / Black
Logo 550SX, Oxy 3 TE Futaba 14SG |
02-13-2013, 03:21 AM | #20 (permalink) |
Red and White:
Flight Style: 'Barely Can Fly' FBL System: Helicommand HC3-SX Motor: Kontronik Pyro 600-12 Pinion: 18T Target Headspeed(s): ESC: Kontronik Jive 100+ LV Governor: Kontronik Jive BEC: WR Hercules Super Mini BEC G2 Cyclic Servos: Graupner HBS 660 HV Tail Servo: Graupner HBS 770 HV Main Blades: Stock Tail Blades: Stock LiPos: Desire Power 6s 4200mah 45C Anything Else: |
