Airplane Related R/C Airplanes Discussion |
04-08-2009, 04:28 PM | #1 (permalink) |
Look what I did!
I had an old Razor V2 heli motor from a Hornet 2, I have a swept forward design for a combat (4' wing) and a souped up .15 OS FP now getting updated with a bearing .15 and a whiffle bat for a fuse. Anyway I was going thru my junk and found the motor and 10amp CC esc, had a prop hub and pulled this outa my imagination! Its based on the other one except smaller and sleeker! I clocked the motor on a 3s/ 3x3 cam prop at 32,000 rpm!
6100e,2 x gws 6g servos,Razor V2 heil motor, CC 10amp, TP20c 910ma 3s = 200.09g / 7.08oz
How much past 200 mph do I need to go you ask? Last edited by TomRex; 04-10-2009 at 11:20 AM.. |
04-10-2009, 03:51 PM | #2 (permalink) |
Have you flown it yet? If so, what kind of speeds is it capable of?
Looks sweet, lets see some footage of it in action |
04-10-2009, 04:32 PM | #3 (permalink) |
man that thing has got to sound pissed off at full throttle.
04-11-2009, 12:35 PM | #4 (permalink) |
Its almost ready for the maiden, added another 4g to it with the extra work, also smoothed some medium CA down the belly and around the nose area.
How much past 200 mph do I need to go you ask? |
04-11-2009, 05:59 PM | #5 (permalink) |
Thats a nice looking wing! Lol can't believe I missed the link.
Trex 600N OS55HZ-R Funtech Pipe Edge Blades Edge Tails Edge Paddles BLS 451 cyclics BLS 251 tail Gy701 gyrogov JR DS9411 Throttle Spectrum AR8000 Arizona Fromeco Switchglow Pro FlightPower EonX Lite 2500 Trex 450,Thanks Marv! |
04-12-2009, 06:07 PM | #6 (permalink) |
05-02-2009, 08:31 AM | #7 (permalink) |
Latest update! Razor V2 heli motor and a Graupner 4x3 cam prop on TP 910ma 3s @32000 rpm, 8oz and is totally radical, no stall, floats and hauls butt, agile as a bat!
PS: the wind got #1 on a launch, oops!
05-13-2009, 06:36 PM | #8 (permalink) |
Decided to keep my 1107! Building another one with 42" wing, 1107,spin44 and turns a 6x4e @ 22800rpm static on 4s
a homade carbon glass motor crutch
06-05-2009, 03:56 PM | #9 (permalink) |
A better update, hope the pics take!
A carbon motor crutch, the fuse and the plane! I put a Scorpion V2 60 amp/Neu11072Y and a Neutronics 40c 2600 4s along with an APC 6x4 e prop, tached it at 37600 rpm, this thing is totally radical ! Ballistic straight up! 21in long and 42in span, fully symmetrical modified R140 foil @ 327sq in/ 1.25lb loaded A pair of old HS56's and a 6100e Rx, TX is a DX6i, 6/10/09 added rudder, no real difference 6/14/09 Tested out the Neutronics 40c 2600 4s and shazam! It was what was needed to go full bore, use only 1.4 amps and come down lukewarm! Unbelevable power delivery and peformance.
How much past 200 mph do I need to go you ask? Last edited by TomRex; 06-15-2009 at 02:16 PM.. Reason: rudder |
07-01-2009, 04:25 PM | #10 (permalink) |
08-17-2009, 03:25 PM | #11 (permalink) |
Latest update, I put a Neu 1110 1.5y and a Scorpion 90 esc. (1000 watts) This thing is stupid sick now. The 1107 and the 1110 share the same can and Kv but the 1110 is stuffed full top to bottom full of windings, the 60 esc wasn't enough.
Hope to get some video sometime!
09-29-2009, 08:30 PM | #12 (permalink) |
Another update is a Neu 1112-2D, got 1250 watts and 110 amps static 10 sec run. Cranks around 160-170 mph now. Same esc and batt.
10-01-2009, 02:22 AM | #14 (permalink) |
I bet you just got done watching Mel Gibson in one of the road warrior series!
How much past 200 mph do I need to go you ask? Last edited by TomRex; 10-01-2009 at 07:05 PM.. Reason: check em out guys! |
10-01-2009, 07:05 PM | #15 (permalink) |
Well I was showing off for the camera and got a little low! I still think if I was on mowed grass it would have skipped off but, it looks like the tork on the wing tip ripped the wing from the fuse saddle.
Sorry for the bad vids, my bud had never used a digital camera for a movie cam. http://www.youtube.com/watch?v=yHpS3tfbM_Q http://www.youtube.com/watch?v=_C3na7u9GqQ
11-12-2009, 10:20 AM | #16 (permalink) |
Removed the covering from fuse, CA'd the thing back together, couldn't find Ora-Cover so Monocoat went on, colors aren't perfect but its back and a 5.5x4 (6x4 cut down) got it going even faster now!
In the process of redesigning the fuse and using a SD6060 modified for the next SFD! 2" longer wing with 7sq in less and a rounded type fuse
How much past 200 mph do I need to go you ask? Last edited by TomRex; 11-13-2009 at 04:24 PM.. |
12-28-2009, 04:53 PM | #17 (permalink) |
Been off track, got myself a different project needed finishing! Phase 3 Squall,hand launches well and floats like a dream to land, no bad habits
Uses an ARC 28-47-1, Het 70mm fan, 85amp esc and of course Neu 2600 40c 4s's. Cranks about a buck thirty and the vectored thrust works! How bout a 180 at speed! I finished the foamy with polycrylic and glass, Rustolium neon and poly clear.
12-29-2009, 02:08 PM | #19 (permalink) |
I was just thinking of picking one up. On sale right now at Hobby People for $20 off.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
12-29-2009, 08:19 PM | #20 (permalink) |
The squall is a blast just stock out of the box.. just wish i had a bit more umph to hover.
Comparf Eurosport 1/7 F-14D Rave 450, scorpion -10, DS285MG, 3500G, Spartan, 4s 2200 outrage, 6100e, 350mm radix lookin for another Vibe 50 |
