Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 05-12-2012, 09:57 PM   #781 (permalink)
Originally Posted by Califlyer818 View Post
Here is the video of the 808 key chain camera as promised enjoy!
looks like the dirt was too close a few times.
easier to deal with the cam mounted that way?
Scammer is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 08:48 PM   #782 (permalink)
Originally Posted by Skidpad View Post
Please tell us more - is the vibration constant at all RPM? The main gear and one-way bearing (OWB) relationship requires a little fiddling as it is easy to get the bearing crooked and cause the gear to wobble real bad, too.
Tell us a little more and we can help.
It is shaking the most just after i crack the throttle. Once it gets going a little. It will actually shake the whole heli violently for a second until more throttle is applied. After reading some, i have found that you should recess the main gear holes, and not over tighten the shaft bolt, etc. Seems to help but the shake at the beginning of spool up is still there.
Fast-Pitch is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 10:11 PM   #783 (permalink)
Mine has some too. If I spool in Normal it isn't bad, but if I spool in IU, it actually hops once. Crazy. I believe the hop has more to do with the way the ESC feeds power when spooling in IU than vibration caused by main gear wobble. Perhaps I should try another ESC....
Nevertheless, there is indeed some transient vibration present in these helis that seems be acceptable long-term...provided you've accomplished the recommended steps to reduce it.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 05-13-2012, 10:56 PM   #784 (permalink)
Yes it sure was, the cam is easier to access. Tape comes right down the middle of the cam which separates both the keys and where the micro sd inserts in such a way that I can have easy access to both.
Califlyer818 is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 10:59 PM   #785 (permalink)
Well said screw it, ditched the training gear and decided lets go foward flight. Been using the mcpx extensivly, and its paid off!! Flew two awesome packs through the heli, had mostly just did tail in hoving now im flying around doin circuts Ect....having fun... What a blast!!
Pheonix Sim, Blade MSRX, MCPX, 450 3D with DX6i
Jem450R is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 11:31 PM   #786 (permalink)
Went through 8 packs back to back today for a total of about 45 minutes flight time.
Was doing some FFF, circuts, stall turns, piros, two loops and attempted some figure 8s... I have trouble keeping my forward momentum through the turns, I need to work on that.
Oddly enough I find forward flight to be much easier than hovering... I'm always a bit unstable when coming into a hover but I'm very smooth at circuts.
Inrover is offline        Reply With Quote Quick reply to this message
Old 05-15-2012, 11:43 PM   #787 (permalink)
Default reprogrammed my FBL Beastx ar7200bx and wow!!
WOw what a difference now iam a nooob so this is new territory for me.lol
but it flips alot quicker and easier .. i love it.. guess iam getting better.. thats a good thing.. now i will crash harder....) better not.. .. ok it happens actually the reprogram was caused by a crash so worked out better sorta..lol
posting vid from my pro 450 not the sporty
Always thanks for the help much appreciated makes the hobby alot easier and enjoyablesince i began flying in dec.2011
Last edited by Indydrt; 05-16-2012 at 09:47 AM.. Reason: woops wrong thread...nevermind:)
Indydrt is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 12:02 AM   #788 (permalink)
I did the maiden flight of my B450 45 minutes ago. I had enough after 2 minutes and landed. I then flew a second battery and had enough at 4 minutes and landed. Two successful flights and two successful landings. I now have a grand total of 6 minutes and 5 seconds of experience in this class of helicopter including two flights totaling 5 seconds and two less than successful landings in the B400.
This was my first CP experience beyond the mCPx. I felt like everything happened in slow motion and the closest thing I can think of to the B450 experience is driving my (former) 1996 Ford Taurus or my parent's 1970 Ford Ranch Wagon after the 100,000 mile point when everything underneath was good and loose and you could move the controls a lot before much happened.
I thank the person on helifreak that sold me his used B450 in December 2011. It took me this long to maiden it. I am smiling from ear to ear and celebrated with a cold beer. My two batteries are already charged for tomorrow.
I did not change a thing from downloaded DX8 settings or with the helicopter. I checked for damage, security of the bolts, checked for correct direction, checked for no binding, checked all servo throws, and checked for a level swash and went flying. I just eye balled everything. I've watched many setup videos.
I want to get a bunch more successful flights and landings without damage and then work on improving the setup of the helicopter.
megawhacker is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 06:16 PM   #789 (permalink)
Went through 12 packs, awesome day for flying. Sunny skies, 70 degrees , 3mph winds
All went well and came back in one piece.
Had to laugh, about 5 packs in a couple of big mean lookin bikers road up behind me and started watching. When i started doing some 3d and inverted hovering, they sounded like a couple little kids. WHAT? how the heck? Did you see that?!?!then started laughing, and "do it again" was pretty fun, and they had a good time watching too, trying to figure out how in the world it could hover upside down. After, sat around and BS'd with them for a while, and showed them how it worked. Was a good time.
Oh and installed my fusuno tail fins
Synergy E7SE / Synergy E5s / Blade 180 CFX
IX12, DX6, Real flight 8, ACCURC
gixster is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 06:49 PM   #790 (permalink)
This morning I had 4 batteries all charged up and ready to go. All is going great until there is 10 seconds left on the timer of the last flight when I am cutting the grass inverted and the grass snatches my heli up.
The damage wasn't too bad. Took out the tail boom, feathering shaft and all three servo gears. The only thing I don't already have are the servo gears but I have decided to upgrade to metal geared servos. Every time the blades touch the ground all three servo gears strip. It is worse for me since I am running FBL.
I have decided to go with the Solar D654 servos from hobbypartz.com. Does anyone have any experience with these?
Also when it crashed the blade had a boom strike. It looks pretty cool!
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote Quick reply to this message
Old 05-16-2012, 11:45 PM   #791 (permalink)
Default Ehhh weird day today.
So went to a new park with my buddy to fly his 7oo and 600 ..how nice ehh,
I get ready to fly the 450 sport with fbl and I forget to ck the gyro switch on my dx8
For some reason,,and the new pitch curve that aim not really used to yet and liftoff was way quick and spinning
Out of control and not time to even think about throttle hold and wam bam .. Second mainsaft this week..,lol. Boom I bent back from saturday crash..then I fly the 450 pro with three close calls. .i said forget today. Just one of those days. ..did somepOne make one of those signs yet that says" a bad day flying is better than being at work". Or something like that ..lol.
Plus the overcast grey day it was and drizzling ..ehh next time
Old 05-17-2012, 04:23 PM   #792 (permalink)
Well I got my B450 put back together after my incident. Other than stripping all my servos I just needed a new tail boom, blades and a feathering shaft. I did a very brief test hover and everything was running smooth and seemed normal.
I ordered three of the Solar D654 servos from hobbypartz so when those get here I will put them in and give them a review.
Here is a picture of the boom strike when it crashed. It's scary how much damage even a 450 can do. Plus I was running fiberglass blades and a relatively low headspeed. I was cutting the grass inverted and it got sucked in.
Old 05-17-2012, 05:57 PM   #793 (permalink)
I bought an Align 500e fuselage. Put most of it together lastnight and did a hovertest... I like it I know it's a "3d" but I really like the scale look. I may have to pick up another 450 3d[IMG][/IMG]
[IMG][/IMG]
Champy is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 07:18 PM   #794 (permalink)
Looks really good!
How does it fly?
Jherison is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 07:44 PM   #795 (permalink)
It is very nice. Not the power horse it was but I like the scale fuselage
I may look into the 440 motor upgrade from E-Flite and some larger mah lipos for a longer run time. Stunt mode really drains the lipos quick... maybe 5mins on a TP 2250 65c. I'll get a video soon... a better one than what I have now
Old 05-17-2012, 08:20 PM   #796 (permalink)
How was it to install? It looks really good.
Trex 600efl Pro with Beastx, Blade 450 3D with ZYX Tarot FBL, Blade 450 3D stock, MCPX v2, Sr120, Spektrum DX8
celltech is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 08:36 PM   #797 (permalink)
I installed a new blaze canopy and black landing gear. I think the red and black color scheme looks nice.
Name:	250 (1024x768).jpg
Walkera v200d03, v120d02s on Devo 8s
Realflight 6.5
HRPuffnstuff is offline        Reply With Quote Quick reply to this message
Old 05-17-2012, 09:03 PM   #798 (permalink)
No pics?!?
I believe that violates forum rules!
Old 05-18-2012, 02:03 PM   #799 (permalink)
That fueslage looks really clean How does it handle inverted?
Old 05-18-2012, 07:12 PM   #800 (permalink)
I ordered an X.
Soundlzrd is offline        Reply With Quote Quick reply to this message
