Old 04-17-2009, 02:08 PM   #41 (permalink)
Originally Posted by vicrc View Post
Actually the Evolites have a strange configuration the cells are fat. However I really like them more than my EVO's, they seem to last longer. Its a shame I killed my two 6s3000 Outrage on my Trex 500, they fit nice and balance well on my Protos.
I hope these G3 will stand up to abuse... and when they say 4x life... do they mean 10 cycles or 50 cycles??
Have you used your 6S Evolites on your Protos? Anything bad about that "odd" shape? Might be a pain to get the rubber bands hooked up, since the pack protrudes over the batt tray of the Protos/Rex.
Tail boom is offline        Reply With Quote Quick reply to this message
Old 04-17-2009, 02:12 PM   #42 (permalink)
I will take some pics of all the packs I have and post when I get back home.
Mini Protos BeastX
Trex 450 Pro BeastX
Protos 500... needs a Brain
n00b3D
vicrc is offline        Reply With Quote Quick reply to this message
Old 04-17-2009, 02:18 PM   #43 (permalink)
Thanks a lot!
Old 04-17-2009, 03:02 PM   #44 (permalink)
hello,
i would try the hyperion 6S 4000 mah. the protos has less weight then trex 500 and i thougt, i could fill the rest of gramms with capacity. im flying no 3D. does it work then? and does the battery fit under the canopy? (598g, 140 x 42 x 55.5 mm)
oxylos is offline        Reply With Quote Quick reply to this message
Old 04-17-2009, 11:45 PM   #45 (permalink)
I test flew my new HypeG3 35C 6s2600 (413grams) taking the Protos to another level of beast! . My first flight was only for testing purposes and getting it tach'd in the air. The G3 pack is almost identical in size as the Evolites, interesting its heavier than the EVO 25C but its physically smaller. No problem fitting 3000 packs, I don't know about the 4000 for CG though. The Outrage 3000 25C was about max weight to get CG perfectly and I am using a 9254 tail servo.
HypeG3=413g
Evolite=385g
EVO=400g
On my Protos
With the Z20-850kv, 17T
idle1 80% 2750
idle2 90% 3150
My older packs I fly them at idle2 which feels like 2600-2700
I charged up again (within 20min at 10amp setting) and had a friend try it on his Trex500 (Z20-1700kv 12T) and he is a better flyer than I am and that is the graph below. We tach'd the beginning of his flight at 2950 rpm and 2750 at end.
I don't think it holds voltage as well as the Outrage pack but its very close and power seems pretty good throughout the flight? I cant compare it as my Outrages are dead.
ID:	92349   Click image for larger version
ID:	92350   Click image for larger version
ID:	92351   Click image for larger version
Mini Protos BeastX
Trex 450 Pro BeastX
n00b3D
Old 04-17-2009, 11:58 PM   #46 (permalink)
This is phenomenal! Look at how level and high the voltage curve is! An average of above the nominal voltage is just fantastic!
I put my 6S 2500 25C on my friend's Protos tonight (did not have a chance to fly though), and the pack fits well under the canopy (mounted like you did).
Picking up my Protos Carbon from the post office tomorrow. Cannot wait to slice the air with her ...
Best and thanks,
Frank
Old 04-18-2009, 12:26 AM   #47 (permalink)
Frank you will have a blast with the Protos, its kick arse heli!
Also if you load it up with larger packs it will feel smoother and you get longer flight time.
The biggest pack I would use is a 6s 3000ma 475 grams max, any more than that it will be nose heavy.
Mini Protos BeastX
Trex 450 Pro BeastX
n00b3D
Old 04-19-2009, 07:49 AM   #48 (permalink)
Here it is.
6pack and 3pack placement. They fit, no probs.
and this is what will happen if you insist on using 16T with Gen3 packs
Wesp
ID:	92589   Click image for larger version
ID:	92590   Click image for larger version
ID:	92591   Click image for larger version
wespen is offline        Reply With Quote Quick reply to this message
Old 04-19-2009, 08:53 AM   #49 (permalink)
Ouch!
Thanks for sharing. I will start building today
Old 04-19-2009, 09:38 AM   #50 (permalink)
Originally Posted by wespen View Post
Here it is.
Wesp
What happened? Crazy headspeed and the heli won't handle that insane headspeed?
thegamer is offline        Reply With Quote Quick reply to this message
Old 04-19-2009, 09:45 AM   #51 (permalink)
Hey Wespen, thanks for the photos, shame about the crash. What's with the collection of black cables (O-rings?) sitting horizontally around the LG ? And how did the CF frame hold up ?
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote Quick reply to this message
Old 04-19-2009, 11:34 AM   #52 (permalink)
Carbon one with cable (thats still in one piece) is mine.
Cable is USB from V-Bar I didnt want to unplug untill I set it up, so I just wrapped it arround skids
https://www.helifreak.com/showpost.p...&postcount=120
Plastic one was friends bird. He wouldnt listen and left 16T on it.
HS was insane, poor Protos was spinning like 3500 RPM with 100% flat governed.
On second tic-toc Jazz 80 shut it down and he did half-good auto.
Frame snapped near motor mount, but we CA-ed it at field and reinforce it with carbon plate.
So now we swapped out to 15T and lowered the Jazz to get 2800 RPM.
After 5 mins and about 2000mAh consumed motor lost power in tic-toc and it was straight down from 15m.
He tried to recover, but HS droped fast since he was inverted. Didnt look so bad untill we got to it.
Whole servo block shattered and all 3 servos broke off smasing all servo cases.
Tail box shattered and frame broke in 3 pieces including lower bearing part.
I was suprised to see tail pitch leveler in one piece. I broke like 5 of those already
I guess tail box and servo block are weak spots...well and forward frame, near motor
I think he damaged the motor in first run, we could smell the burnt insulation
He pulled like 1600W on that
Wesp
Old 04-19-2009, 12:46 PM   #53 (permalink)
With my setup Z20-850kv 17T
80 % =2650
90 % =3150
100 % = I didn't even want to go there
Mini Protos BeastX
Trex 450 Pro BeastX
n00b3D
Old 04-19-2009, 04:11 PM   #54 (permalink)
Ok, here is my EagleTree.
Squeezing out 2500mAh from 2600mAh pack.
Check the voltage!!!
Till 2300mAh its still 23V, and drops to 21V at 2500mAh.
Buy, buy, buy
Wesp
Name:	hype gen32.jpg
Old 04-19-2009, 04:20 PM   #55 (permalink)
Buy, buy, buy
Wesp
I did, four of 'em
Actually, I got the 25C ones (called CX). The CX stands for capacity optimized (price/value).
The ones you guys have eagletreed are the VX ones (35C). The VX stands for optimzed voltage behavior under load, which your guys' graphs certainly proof.
Would love to see an eagletreed CX pack ...
Best,
Frank
Old 04-19-2009, 04:25 PM   #56 (permalink)
Best,
Frank
Got a few 6S 5000mAh coming in for 12S AP ship.
Will eagletree them too.
Wesp
Old 04-19-2009, 07:20 PM   #57 (permalink)
Rock on
Old 04-19-2009, 10:03 PM   #58 (permalink)
Buy, buy, buy
Wesp
I see you went over 6 minutes, with a peak amp of 1700 watts. Nice!
Are you using the stock SAB blades?
Mini Protos BeastX
Trex 450 Pro BeastX
n00b3D
Old 04-20-2009, 07:38 AM   #59 (permalink)
I am impressed with the packaging. Nice looking product. Very poilished in a decorated box. Battery is a blocky like structure. a little fatter and not as long as my other 6S.
simmer is offline        Reply With Quote Quick reply to this message
Old 04-20-2009, 04:07 PM   #60 (permalink)
The packaging lasted as long as I opened it... , in the recycle bin it goes. I wish they save me some money instead and put them in plastic or brown box, heck a days old newspaper would work.
Here is another logged flight with the RPM sensor installed. I tried the brushless sensor and it didnt work... maybe I plugged it in wrong. Agree Voltage is holding pretty good with these packs but these are the 35C packs and flight was on 80 percent. I did a 10 seconds of 90 percent and its way too much for me.
Mini Protos BeastX
Trex 450 Pro BeastX
n00b3D
