Go Back   HeliFreak > R/C Helicopter Support > Miniature Aircraft Helicopters > MA Gas
MA Gas Miniature Aircraft Gas Helicopter Support Forum
Old 06-07-2013, 07:31 PM   #21 (permalink)
Ok I put the washers on top and now everything spins freely again.
Now if it will just stop raining so I can test fly it.
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 06-07-2013, 09:01 PM   #22 (permalink)
Default Precisely
Now you're in Raja Mod territory for the whiplash
Oh yeah. 2.94 inches of rain so far, coming down quick it will be over 3 inches very shortly!
P.S. Word to the wise, throttle up slowly, the clutch will bite more "suddenly" or should I say aggressively so let it bite before you spool up faster.
2.97 inches now, see, its moving fast!
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 06-08-2013, 06:37 AM   #23 (permalink)
Any measurement for those washers? I've got the bolts and everything else, but no washers.
Eury is offline        Reply With Quote Quick reply to this message
Old 06-08-2013, 05:06 PM   #24 (permalink)
Well got 5 flights in today and as a result I can say that flipping the clutch had ZERO effect on the wah wah problems I am having.
But I may have another solution in the works.
Old 06-08-2013, 10:51 PM   #25 (permalink)
Default Wah wah problem
Common causes from my experience:
1. The clutch slipping
2. Leaking oil in the clutch bell
3. Too much oil in the one-way
Let us know what you figure out.
-=>Raja.
Old 06-09-2013, 06:41 AM   #26 (permalink)
To help keep OWB lube out of the clutch
1) Install starter shaft in bell, slide a small oring onto the starter shaft, then install pinion.
2) Replace the 696zz shielded lower starter bearing with a 696 2rs sealed bearing
http://www.rcbearings.com/individual-bearings/6962rs
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 06-10-2013, 12:43 PM   #27 (permalink)
It would appear that my whole wah wah problem was nothing more then my gyro gain was way to low.
When I first set up the helicopter I was more worried about the engine tuning and and break in and did only the most basic gyro setup. It held the tail in flight and did not wage, so ok good to go for engine breakin.
As the wah wahs were there from day one, and as I leaned the engine they got better but did not go away I always thought the problem was engine tuning.
It should be noted that while the gyro gain was low it still held the tail fine and a couple other people that flew the helicopter did not notice it either.
Using ATV's in the radio to set gyro gain I started out at +40, this weekend I have upped it to +65 and for the most part the wah wahs are now gone. I will up the gain some more till I start getting tail wags and back it off just a little.
It sucks when it takes this long to find a basic problem.
