HeliDirect HeliDirect HDX300, 450, 500, 550, 600 Factory Sponsored Support Forum |
09-02-2006, 02:10 AM | #61 (permalink) |
I did in fact try to dial out the drift with a servo. Flying in my living room with absolutely no wind, it drifts just a but hair, much better then how it was when I first hooked it up.
I am still getting the gain correct though because outside in a breeze it can wag quite a bit with gain at 50% and then not hold well at all at 45% and I can't find a setting in between thats balanced. I also noticed if I lift hard it noses left. But overall its a big improvement over the 3-1 gyro. I've gained quite a bit of confidence with it, so much so that I will practice my hovering outside in the wind, and even today I flew down my hallway into my living room and then back, albiet all tail in Keep in mind though, this is my first flying model, first gyro etc etc. But I have a 450se that I am in the process of building.
www.tleone.com |
09-02-2006, 02:11 AM | #62 (permalink) | |
Jeroen - Just fly it! |
09-02-2006, 01:59 PM | #63 (permalink) |
In Bob's video on setting up the gyro, he adjusted the drift out with subtrim by watching the servo horns.
Well I have a similar gyro hooked up to my Blade Pro, but still using the tail motor. Well it drifted like crazy. So I used a servo and subtrim to get most of that drift out, then plugged it back into the 3-1.
www.tleone.com |
09-02-2006, 03:29 PM | #64 (permalink) |
But if you adjust the travel of the servo that won't change the output of the gyro, so you still have a problem. Or am I missing something here?
09-02-2006, 04:14 PM | #65 (permalink) |
I think what he's saying is,with his motor driven tail it would drift since he has no reference as the motor driven tail just does it's thing.he put a servo in place of the esc and set it up per the vid so the servo would hold center(reference item set for no drift) than reconnected the esc.
09-02-2006, 07:23 PM | #66 (permalink) |
thanks, exactly what I am trying to covey.
www.tleone.com |
09-03-2006, 02:01 AM | #67 (permalink) |
Ok, I don't know the setup of the Blade Pro electronics, but if it works for you, that's great!
09-03-2006, 05:06 AM | #68 (permalink) |
Yo Bob I also want to say that it is a very good thing that you are doing to help alot of people that are new to the wonderful world of Helis. I myself found the video disscussion on setting up servos and hitting on each topic only enough to put people on the right path. Now for my question I have two Helis now after I started upgradeing my Blade. Now it is a complete HDX 300. My problem is with the main shaft pully. I have the set screws very tight and the main gear has alot of slop it has probably 3/16 of play. I was very careful with the anti rotation sleve as it is still very tight as the day i got it. Can you think of anything that would cause the front drive pullly to never seat up with the s main shaft it just continuew
09-03-2006, 09:08 AM | #69 (permalink) |
Team Taco VP
I had to add a washer above the pulley to get it to seat tight against the lower bearing.
Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
09-03-2006, 10:36 AM | #70 (permalink) |
guys.. noticed that the video for the electronics are not here. i guess it might be that the setup is similar to another video. ummm.. which one should i look at? thanks.
09-03-2006, 11:05 AM | #71 (permalink) |
Team Taco VP
I will be finishing that next week.... Steve wants me to use and show the 18A ESC for it.
Bob
09-03-2006, 01:20 PM | #72 (permalink) |
I can now see how this maybe a frustrating build for you Finless(as you said earlier).Package this week another next week,etc.Kinda takes the "fun out of it"since you never know how the mfg wants the final product to look,unlike with the others you have done"here is a box of goodies,all inclusive,put it together".
Nothing like a work in progress "A" |
09-03-2006, 11:16 PM | #73 (permalink) |
This looks interesting, is it small enough to fly in the house or in a garage? I really want to get the pocket zoom heli but who knows when it will be out. Its so windy around here that it would be nice to have something that I can hover in the garage and learn a little bit, maybe do some flips and such if I get to that stage
09-06-2006, 09:39 AM | #74 (permalink) | |
300
09-11-2006, 08:55 PM | #75 (permalink) |
Any update on the videos?
Brian Bland Claremore, OK |
09-12-2006, 01:01 AM | #76 (permalink) |
Team Taco VP
I will be posting them TOmorrow night as stated above.... I should be complete unless I run into a snag which I dont forsee.
Bob
09-12-2006, 11:15 AM | #77 (permalink) | |
09-12-2006, 12:53 PM | #78 (permalink) |
Team Taco VP
It will be motor install, electronics, final setup.
Flying will be this weekend. Bob
09-13-2006, 01:12 AM | #79 (permalink) | |
09-13-2006, 09:54 AM | #80 (permalink) |
Team Taco VP
All done for now.... I will do a final overview out at the field and test flight.
I managed to bend my tail output shaft by accident so I am waiting for the part to fix it. Bob
