Old 04-15-2014, 02:15 PM   #1 (permalink)
Default New 300X Maiden and request for DX6i settings
So I maidened my 300x out of the box, and hovered it for about 3 minutes.
Flies ok but seems a bit touchy with the "Normal" settings from the manual (Throttle curve adjusted per addendum).
Anybody want to share any DX6i settings for the 300X for a more inexperienced pilot?
It's not near as touchy as my Nano CPX, but still not as calm as I would like it.
The ncpx is cheap to fix, this one won't be.
Looked, but didn't find anything specifically for the DX6i.
darowden is offline        Reply With Quote Quick reply to this message
Old 04-15-2014, 02:31 PM   #2 (permalink)
I went to the BX control behavior ... Parameter menu B and started at "Normal". Made it very easy to fly, I soon stepped up to "Sport".This takes D/R and expo away from your radio.I figured just one setting that's easy to change to next progression is the way to go.
James Recard is offline        Reply With Quote Quick reply to this message
Old 04-15-2014, 03:03 PM   #3 (permalink)
I used the suggestions from Helibus in post #3 of this thread.
https://www.helifreak.com/showthread...t=docile+setup
The single easiest thing to do: just dial in 30% positive expo to rudder, elevator, aileron. This should allow you to hold a nice steady hover.
thruster is offline        Reply With Quote Quick reply to this message
Old 04-15-2014, 04:05 PM   #4 (permalink)
Thanks guys. will give those a shot.
Old 05-25-2014, 08:24 AM   #5 (permalink)
Did the 30% work?
Nitrofish is offline        Reply With Quote Quick reply to this message
Old 06-05-2014, 05:54 PM   #6 (permalink)
I can list my 300x setting if still needed :thumbup
Sent from flying shrapnel that once was a heli
"If you aren't crashing...you aren't flying"
ZMR250-ZMR150-Custom 250 hex
-Nic, Team Mesa RC Foam Fighters Elite
Wildcat1214 is offline        Reply With Quote Quick reply to this message
Old 07-27-2014, 03:11 AM   #7 (permalink)
I got a used 300x on the way and curious about this too. Coming from a nano cpx also
Braddock54 is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 09:56 AM   #8 (permalink)
If you're somewhat technical at all then I'd say just stick with the default "transmitter mode" in parameter menu B and adjust your rates and expo to suit the level of sensitivity you can handle. This will be the most similar to what you're used to on the Nano. Rates control how quickly the heli will flip/roll/yaw for a given input and expo controls how soft the sticks will feel around center. 70% rates and 20% expo for ail/ele/rud are probably good for a beginner. Then just keep adjusting the rates up as you want the heli to react faster. Plus you can always switch between lower and higher rates from the transmitter to see what you like best or to try out new settings.
If all that sounds like Greek then maybe changing the control behavior in parameter menu B to "normal" or "sport" might help. If you do that, make sure you have the rates at 100% and expo at 0% in your transmitter. You can think of these as built in rates and expo. So you don't want to have rates and expo on the transmitter that would interfere.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 10:23 AM   #9 (permalink)
+1
Uriah is offline        Reply With Quote Quick reply to this message
