Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 06-16-2013, 02:12 PM   #1 (permalink)
Default Compass SZ 4926 - is this too much play?
In the process of putting a new ESC on my 7HV and I happened to pull up on the motor can (new motor with single magnets, the painted top and chrome can). There seems to be a lot of travel of the stator up and down on the shaft. Is this too much? Is it anything to worry about? The can isn't rubbing against the bottom plate.
SantosDumont is offline        Reply With Quote Quick reply to this message
Old 06-16-2013, 06:33 PM   #2 (permalink)
i would shim to where half that play is gone.
some is need for heat expansion.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 12:03 AM   #3 (permalink)
None is needed for heat expansion, at least not that you can measure, shim it so you have no play but no binding either so inadvertently you want to have thousands of a mm play not really noticeable. Think what a moving can do to amongst others a herringbone gear.
Tdr quantum 4530 1.4 yy h/ jive120 beastx, Vibe e 8 12s mx 700 1.32yy vbargov fusionhawk, Banshee nr 36 kosmik 200 pyro 800 1.4yy 455kv 14s beastx, xtreme 700 pyro 850 1.5yy 14s kosmik 200
Stolla is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 10:47 AM   #4 (permalink)
Thanks for the input, I'll shim it tighter.
Old 06-17-2013, 11:01 AM   #5 (permalink)
I think your c clip slipped up out of the slot in the shaft, check that
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 06-17-2013, 07:42 PM   #6 (permalink)
C clip is still in place. Wish I had another one to put on top of it because it would fill the gap nicely.
Old 07-03-2013, 04:36 PM   #7 (permalink)
Are you sure the c-clip is in the slot? I had a similar issue and the slot is not reachable below the bearings. The c-clip is just on the shaft but not properly installed.
Druekerfish is offline        Reply With Quote Quick reply to this message
Old 07-04-2013, 02:48 AM   #8 (permalink)
Had one too.could only get the tips of the clip to get onto the slot , but not "seat" into the slot fully.
Warp, 6HV LED,6HV, Alien 450 MR, 250 mini Quad racer(4s monster) FPV rules the roost!
Airworks is offline        Reply With Quote Quick reply to this message
Old 07-04-2013, 03:23 AM   #9 (permalink)
OK, I am getting a new one (very good service from the distributor) and will check the differences. It is a pity that they did not make a design that allows the main shaft to be shifted up/down with a set screw to adjust the tolerances and the play.
Logo 600 - Joker 3 - TDR - Diabolo - Gaui X5 - Compass 7HV
Old 07-04-2013, 10:36 PM   #10 (permalink)
Thanks for the input. The C clip is in place. Finding shims that will fit is a pain. I should send it back but I live in Rio and sending stuff back and forth is a nightmare.
Old 07-06-2013, 01:27 AM   #11 (permalink)
you said if you had another c-clip it would full in the gap? if so I got a spare c-clip shoot me your address in a pm I will send you one..
(***WARNING*** Stop Spamming Helifreak)
freedom is slavery.
Citizen 375
Fly it like you stole it
Money does bring happiness, never seen a sad person on a jet ski
redsoper is offline        Reply With Quote Quick reply to this message
Old 09-07-2013, 10:57 AM   #12 (permalink)
A big thank you to Redsoper for sending me a new c-clip. I still had to shim it anyway but couldn't have done it without the new c-clip. If anyone needs shims, AMainHobbies sells a Kyosho 8x10mm shim set (containing several 0.1, 0.2, and 0.3 shims) that works great. I found a similar problem on my 600 MX and 700 MX motors. Kyosho also make the 6x10mm shim sets.
Old 09-17-2013, 06:44 AM   #13 (permalink)
I have the same motor with the same amount of play, Did you got it replaced or did the shims work for you. The reason I ask is that I notice my other motor have play and would want to think this is normal.
Karim
KBaksh is offline        Reply With Quote Quick reply to this message
Old 09-17-2013, 04:26 PM   #14 (permalink)
The shims took care of it. I needed .3 mm total.
