Old 04-12-2015, 03:00 PM   #1 (permalink)
Default 500L tail servo
Hi All,
I wanted to get some input on what tail servo to get for my 500L . Higher end is good and little frame modification is great .
Thanks .
leokat001 is offline        Reply With Quote Quick reply to this message
Old 04-13-2015, 06:27 AM   #2 (permalink)
I was happy with the stock Align ds520 servo on a 500esp so I still keep it just in case. Now I am using a MKS 8910A+, a truly amazing servo!
Mateyhv is offline        Reply With Quote Quick reply to this message
Old 05-21-2015, 09:57 PM   #3 (permalink)
Also consider the bk ds7005. It is a full size servo with mini case adapting option.
nabl74 is offline        Reply With Quote Quick reply to this message
Old 05-22-2015, 02:07 AM   #4 (permalink)
...or the KST bls505x (brushless) and KST ds565x (coreless) tail servos.
Old 05-22-2015, 08:35 AM   #5 (permalink)
RJX FS0391T
NC Hillbilly is offline        Reply With Quote Quick reply to this message
Old 05-22-2015, 06:19 PM   #6 (permalink)
Rjx 391t looks suspiciously like the bk ds7005 and specs are almost identical.
Veryyyyyy inerreeestingggggg
Can't go wrong with either I guess
Old 05-22-2015, 06:54 PM   #7 (permalink)
I did have to take a sanding drum on the dremel to open the mount slightly to clear the motor on the servo. It was very little and looks like it was put there from the factory.
Old 05-22-2015, 08:57 PM   #8 (permalink)
that confirms it. had to to do the same with the bk.
in fact when you look at the data below.. they are identifical! and both full size servos
look below spec comparison
BK Servo Multi Size Digital Tail Servo Model 7005HV
Operation Voltage: 6V – 8.4V
Weight: 50g (1.7 Oz)
Torque:
8.4 kg/cm (116.7 oz/in) @ 6V | 9.6 kg/cm (133.3 oz/in) @ 7.4V | 10.6 kg/cm (147.2 oz/in) @ 8.4V
Speed:
0.035 sec/60 @ 6V | 0.032 sec/60 @ 7.4V | 0.03 sec/60 @ 8.4V
Dimensions: 15x36x35.5 mm
Frequency: 760us/333 hz
Gear Type: Metal
Motor Type: Coreless
Operation Voltage:6V-8.4V
Weight:50g(1.7oz)
Torque:8.4kg/cm(116.7oz/in)@6V
9.6kg/cm(133.3oz/in)@7.4V
10.6kg/cm(147.2oz/in)@8.4V
Speed :0.035(sec/60°)@6V
0.032(sec/60°)@7.4V
0.03(sec/60°)@8.4V
Dimension:15x36x35.5mm (W x L x H)
Frequence:760µs/333hz
Gear Type:Metal Gear
Motor Type:Coreless Motor
Old 05-23-2015, 06:46 AM   #9 (permalink)
I remember when I was searching for a servo, comparing specs and came to the same conclusion. They are great servos. I did have to remove the boom mount also to install as it would not go between the frames while together
Old 05-23-2015, 07:47 PM   #10 (permalink)
Whenever you find two (or more) different brand products with the same specs its 100% sure they are China made.
Old 05-23-2015, 08:03 PM   #11 (permalink)
Mks hv9780 fits with zero mod and is great. The mks 8910a+ is also a fantastic servo.
reich2004 is offline        Reply With Quote Quick reply to this message
Old 05-27-2015, 11:33 AM   #12 (permalink)
Closed Account
I use the KST DS515MG at 8.4 volts its faster and stronger than the Align ds525. It works great
xokia is offline        Reply With Quote Quick reply to this message
Old 06-02-2015, 07:00 PM   #13 (permalink)
Default Tail servo...
I looked at the KST. With running that at 8.4v won't you need the cyclic servos capable of running 8.4v also? Im trying to change out my tail servo with something decent but I really don't want to spend 100$ or near that. I saw RJX FS0391T compared to the BK. About the same price. I read some other servos that are cheaper but the Tq and Speed are slower then the align tail servo on the 500L so I don't know why someone would do that...
sunsetmaro is offline        Reply With Quote Quick reply to this message
Old 06-02-2015, 07:35 PM   #14 (permalink)
To get a faster acting higher torque servo you will pay more.
Any of the options in this thread will provide better than stock performance.
Just ensure what u get does perform better otherwise your not doing yourself.any favours.
Also if you do go full size servo pick one that needs zero or minimal mods.
Old 06-02-2015, 07:37 PM   #15 (permalink)
Default .
Will do Thanks
Old 06-02-2015, 07:40 PM   #16 (permalink)
I managed to install mine without taking boom mount off, what I did was mount the two parts separately, outer case to frame, then screwed in top plate.from the other side.
Old 06-02-2015, 07:49 PM   #17 (permalink)
Default so..
I could install a 7005 without the adapter? I read somewhere the only reason for putting the servo in two parts was due to the wiring not passing through the frame. id really rather not have to buy a adapter, for one its 15$ also I don't see any in stock, or if they are its over seas...
Old 06-02-2015, 08:05 PM   #18 (permalink)
The frame opening in the 500l is a mini servo opening. A full size servo will not fit this without significant mod.
The rjx and the bk are full size but offer you a top cover mini servo option. You simply unscrew full size cover plate and screw on min servo cover plate
You don't add the adapter to the full size cover it's.one or the other.
I only mounted as two pieces as it was hard to push the servo into place through the lower compartment as the tail servo mounts from inside not outside frame.
I'll post a pic.when I get,home later today to help.
Old 06-02-2015, 08:11 PM   #19 (permalink)
Default rgr
I understand. I will probably just pull the trigger on the bk servo
Old 06-02-2015, 08:18 PM   #20 (permalink)
Default real quick
What made the standard head not fit in the heli? Screw hole alignment?
