Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters
Scale Helicopters Discussions About Scale Helis, compatibility and and projects
Old 07-25-2014, 08:06 PM   #1 (permalink)
Default 600 tail on 700
So my 700 tail case is a tight fit in the Marvelcraft Agusta 109. I know the booms for a 600 and 700 are the same diameter so I assume a 600 tail case will slide right on. Question is, will the torque tube from the 700 slide into the 600 tail gears? A 600 tail case would make this fit so much easier. In fact, the instructions show a picture of a 700 tail with some hacking done to make it fit and also have a drawing (for hole locations) that shows a 600 tail case superimposed in the tail. much more room.
AMA# 902812
More stuff than there is time to fly it.
AFjetmech is offline        Reply With Quote Quick reply to this message
Old 07-25-2014, 10:15 PM   #2 (permalink)
It will fit.....
The only real difference is the amount or throw the 600 has compared to the 700.
JR9303 / JR9503 / Futaba10CHP
Old 07-25-2014, 10:42 PM   #3 (permalink)
Are you saying the 700 tail gives more pitch than a 600? I would think whatever it has is enough for a scale heli.
AMA# 902812
Old 07-26-2014, 05:03 AM   #4 (permalink)
For your purpose it will work fine.
And yes, the 700 tail box has greater travel than a 600 .... but unless your planning on some wild stick banging on a scaler, you won't see any difference in performance.
Old 07-26-2014, 09:38 AM   #5 (permalink)
Nightflyr is 100% correct , I have a 600 tail gearbox on my T700 scaler and it is super smaller in size but yet still does an outstanding job.
Cap231ex is offline        Reply With Quote Quick reply to this message
Old 07-26-2014, 02:07 PM   #6 (permalink)
Thanks for the replies guys. Guess I'll be ordering a 600 tail case.
AMA# 902812
Old 08-25-2014, 05:55 AM   #7 (permalink)
The 600 tail worked great. Barely fit so don't know how I could have ever used the 700 case.Click image for larger version
ID:	531406Click image for larger version
AMA# 902812
Old 08-25-2014, 07:54 AM   #8 (permalink)
The 600 case also is slightly longer than the 700, so the torque tube was just touching the umbrella gear and not engaging. I took an 800 TT and cut it down to the length I needed then pinned the end for a little piece of mind. Here you can see the difference between stock 700 tube and my modified one.Click image for larger version
AMA# 902812
Old 09-03-2014, 01:37 PM   #9 (permalink)
Oh trust me the 700 tail does fit. But it's really tight. I can post a pic later if you like
Goblin 700 Ikon 560ult cc160hv
Scale Bell 222 T700, Agusta A109 Grand 700
Blue Thunder 700 RCHN #365
G500,E5 12s,600np dfc, t500 dfc beater
Jackass1277 is offline        Reply With Quote Quick reply to this message
Old 09-03-2014, 02:03 PM   #10 (permalink)
Yeah I know it would squeeze in especially if I lowered its position but didn't want any slight vibration issues to create chafing and rub through. The only problem I might have is that the 600 rotor shaft isn't as long which might present blade clearance issues with the side of the fuse when at full pitch. Might need narrow cord blades.
AMA# 902812
Old 09-13-2014, 08:28 AM   #11 (permalink)
You may want to consider raising the mechanics up. I'm now running into the main shaft not being tall enough. I have the longest 700 main shaft and it still needs to be another 10 mms taller
Old 09-13-2014, 11:03 AM   #12 (permalink)
Are you using an E model? I've converted my 700n to electric. It sits pretty high. These were designed around the nitro version.
AMA# 902812
Old 09-13-2014, 11:07 AM   #13 (permalink)
No I'm using a v1/v2 E airframe
Old 09-13-2014, 09:36 PM   #14 (permalink)
I shouldn't have any issues.
AMA# 902812
